[STM32F1] 请教: ADC DMA方式采集到的数据总是0, 何故?
2057|3
 楼主| ipman 发表于 2014-4-11 23:32 | 显示全部楼层 |阅读模式
代码:
#define ADC1_DR_Address    ((u32)0x4001244C)
#define ADC3_DR_Address    ((u32)0x40013C4C)
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
unsigned int ADCConvertedValue;
void ADC_Configuration(void)
        //NVIC_Configuration();
   /* DMA1 channel1 configuration ----------------------------------------------*/
   DMA_DeInit(DMA1_Channel1);
   DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; /*(u32)&ADC1->DR;*/
   DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;
   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
   DMA_InitStructure.DMA_BufferSize = 2;
   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
   DMA_Init(DMA1_Channel1, &DMA_InitStructure);
   /* Enable DMA1 channel1 */
   DMA_Cmd(DMA1_Channel1, ENABLE);
   /* ADC1 configuration ------------------------------------------------------*/
   /* Initialize ADC structure */
   //ADC_StructInit(&ADC_InitStructure);
   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
   ADC_InitStructure.ADC_NbrOfChannel = 1;
   ADC_Init(ADC1, &ADC_InitStructure);
   /* ADC1 regular channel14 configuration */
   ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 1, ADC_SampleTime_55Cycles5); // ADC_Channel_16 ADC_Channel_TempSensor
   /* Enable the temperature sensor and vref internal channel */
  // ADC_TempSensorVrefintCmd(ENABLE);
  // ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
  // ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
   RCC_ADCCLKConfig(RCC_PCLK2_Div6);
   /* Enable ADC1 DMA */
   ADC_DMACmd(ADC1, ENABLE);
   /* Enable ADC1 */
   ADC_Cmd(ADC1, ENABLE);
   /* Enable ADC1 reset calibaration register */
   ADC_ResetCalibration(ADC1);
   /* Check the end of ADC1 reset calibration register */
   while(ADC_GetResetCalibrationStatus(ADC1));
   /* Start ADC1 calibaration */
   ADC_StartCalibration(ADC1);
   /* Check the end of ADC1 calibration */
   while(ADC_GetCalibrationStatus(ADC1));
   /* Start ADC1 Software Conversion */
   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
mmuuss586 发表于 2014-4-12 11:36 | 显示全部楼层
这是我407写的,你参考下,看了下还是有区别的;
ADC1_DMA_Config();  //AD初始化
  ADC_SoftwareStartConv(ADC3);
  * @brief  ADC1 Channel Vbat configuration (DMA, ADC, CLK)
  * @param  None
  * @retval None
void ADC1_DMA_Config(void)
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
  /* DMA2 Stream0 channel2 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC3ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* Configure ADC3 Channel7 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_10Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC3, &ADC_InitStructure);
  /* ADC3 regular channel7 configuration *************************************/
  ADC_RegularChannelConfig(ADC3, ADC_Channel_1, 1, ADC_SampleTime_56Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC3, ENABLE);
  /* Enable ADC3 */
  ADC_Cmd(ADC3, ENABLE);
cdshkf 发表于 2014-4-12 11:56 | 显示全部楼层
楼猪,你ADC1和DMA的外设时钟开了吗?
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
 楼主| ipman 发表于 2014-4-12 14:13 | 显示全部楼层
谢谢,找到原因了,RCC_AHB2PeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);  将DAM时钟设到AHB2了!
个人签名:汽车电子
89
