[ARM入门] KEIL中结构体和共用体的定义使用问题
10443|3
 楼主| hyelectron 发表于 2014-4-23 13:50 | 显示全部楼层 |阅读模式
问题:如下,为何LPC17XX.h中的定义没问题,而自己照着定义确要添加名字才可以编译通过,请问是什么问题?
1. LPC17XX.h中如下定义
typedef struct
  union {
    __IO uint32_t FIODIR;
    struct {
      __IO uint16_t FIODIRL;
      __IO uint16_t FIODIRH;
    struct {
      __IO uint8_t  FIODIR0;
      __IO uint8_t  FIODIR1;
      __IO uint8_t  FIODIR2;
      __IO uint8_t  FIODIR3;
}LPC_GPIO_TypeDef;
2.个人的定义 ----编译有问题
typedef struct
    union
        int u_wnk;
        struct {
        short int m_cos;
        short int m_sin;
}FFTWNK_TypeDef;
编译出现的问题:
warning:  #40-D: expected an identifier
  error:#618: struct or union declares no named members
3.如下改正编译才通过
typedef struct
    union
        int u_wnk;
        struct {
        short int m_cos;
        short int m_sin;
        }meb; //添加结构体名
    }uni; //添加共用体名
}FFTWNK_TypeDef;
ayb_ice 发表于 2014-4-24 10:02 | 显示全部楼层
main.c(41): error:  #3093: anonymous structs are only supported in --gnu mode, or when enabled with #pragma anon_unions
ayb_ice 发表于 2014-4-24 10:12 | 显示全部楼层
#pragma anon_unions
struct A
    struct
        int i, j;
    };               // Okay -- references to i and j
};                   // through class A are allowed.
int foo(int m)
    A a;
     a.i = m;
     return a.i;
 楼主| hyelectron 发表于 2014-4-25 15:12 | 显示全部楼层
#pragma anon_unions
struct A
拜谢! 看来还是要好好研究下KEIL的编译参考指南啊。
