[STM32F1] 采用ADC+DMA进行三通道AD转换时AD值不对,求助!
3202|6
 楼主| wukon 发表于 2014-5-7 11:15 | 显示全部楼层 |阅读模式
void TIM2_IRQHandler(void)
  TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  ADC_SoftwareStartConvCmd(ADC1,ENABLE);
   while(!(DMA_GetFlagStatus(DMA1_FLAG_TC1)));
  ADC_SoftwareStartConvCmd(ADC1,DISABLE);
    adc_current[i]=adc_value[0];
    adc_voltagea[i]=adc_value[1];
    adc_voltageb[i]=adc_value[2];
     DMA_ClearFlag(DMA1_FLAG_TC1);
  i++;
   if(i==7)
   i=0;
   Max_cu=adc_current[0];
      Min_cu=adc_current[0];
      sum_cu=adc_current[0];
   Max_voa=adc_voltagea[0];
      Min_voa=adc_voltagea[0];
      sum_voa=adc_voltagea[0];
   Max_vob=adc_voltageb[0];
      Min_vob=adc_voltageb[0];
      sum_vob=adc_voltageb[0];
      for(i=1;i<7;i++)
         sum_cu=sum_cu+adc_current[i];
         if(adc_current[i]>Max_cu) Max_cu=adc_current[i];
         if(adc_current[i]<Min_cu) Min_cu=adc_current[i];
      sum_voa=sum_voa+adc_voltagea[i];
         if(adc_voltagea[i]>Max_voa) Max_voa=adc_voltagea[i];
         if(adc_voltagea[i]<Min_voa) Min_voa=adc_voltagea[i];
      sum_vob=sum_vob+adc_voltageb[i];
         if(adc_voltageb[i]>Max_vob) Max_vob=adc_voltageb[i];
         if(adc_voltageb[i]<Min_vob) Min_vob=adc_voltageb[i];
   adc_cu=(sum_cu-Max_cu-Min_cu)/5;
   adc_voa=(sum_voa-Max_voa-Min_voa)/5;
   adc_vob=(sum_vob-Max_vob-Min_vob)/5;
   i=0;
void ADC_RegularChannelConfiguration(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode=ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode=ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel=3;
ADC_Init(ADC1,&ADC_InitStructure);
ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_1Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_11,2,ADC_SampleTime_1Cycles5);
ADC_RegularChannelConfig(ADC1,ADC_Channel_12,3,ADC_SampleTime_1Cycles5);
ADC_DMACmd(ADC1,ENABLE);
ADC_Cmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1));
ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
void DMA_Configuration(void)
DMA_InitTypeDef DMA_InitStructure;
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//adc1的数据寄存器设备地址,数据手册上有
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//一个有3个元素数组的首地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 3;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    //循环模式开启,Buffer写满后,自动回到初始地址开始传输
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    //配置完成后,启动DMA通道
  DMA_ClearITPendingBit(DMA1_IT_TC1);
  DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);
    DMA_Cmd(DMA1_Channel1, ENABLE);
void Timer2_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_DeInit(TIM2);
TIM_TimeBaseStructure.TIM_Period=9;
TIM_TimeBaseStructure.TIM_Prescaler=35999;
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM2,TIM_FLAG_Update);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM2,ENABLE);
 楼主| wukon 发表于 2014-5-7 11:16 | 显示全部楼层
在改变对应AD引脚后,相同电平对应的AD值和没改变引脚前是不一样的,这是什么引起的啊!!!
mmuuss586 发表于 2014-5-7 17:56 | 显示全部楼层
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1);这些加了吗
cdshkf 发表于 2014-5-8 11:51 | 显示全部楼层
只说以下几点:
1、楼猪的问题描述得不够具体,多通道采集ADC值不对太模糊,到底是采集值为0、还是采集值正确但通道出现了错位。
2、 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//一个有3个元素数组的首地址  楼猪的这句代码虽然对问题解决影响不大,但是adc_value已经是地址了,前面加个&没什么意义,可以去掉。
3、看楼猪程序思路比较明确,定时器2的中断中手动软件触发ADC多通道转换,逻辑很清楚,但是既然是每次进定时器中断后手动启动转换,为什么还要设置ADC为连续转换模式:ADC_InitStructure.ADC_ContinuousConvMode=ENABLE; 单次转换就可以了。
4、楼猪选取了ADC的10、11、12三个通道,对应PC0、PC1、PC2三个引脚,建议楼猪检查硬件电路,这三个引脚是不是有对应的采样信号输入。
一家之言,仅供参考!
cdshkf 发表于 2014-5-8 14:17 | 显示全部楼层
我按照楼猪的程序改了改,仅供参考(三个通道我改成了11、12、13),测试没问题。
main函数里:
  1. #include "stm32f10x.h"
  2. #include <stdio.h>
  3. /* Private define ------------------------------------------------------------*/
  4. #define ADC1_DR_Address    ((u32)0x4001244C)
  5. /* Private function prototypes -----------------------------------------------*/
  6. void ADC_Configuration(void);
  7. void Timer2_Configuration(void);
  8. /* Private variables ---------------------------------------------------------*/
  9. vu16 adc_value[3];
  10. /*******************************************************************************
  11. * Function Name  : main
  12. * Description    : Main program
  13. * Input          : None
  14. * Output         : None
  15. * Return         : None
  16. * Attention                 : None
  17. *******************************************************************************/
  18. int main(void)
  19. {
  20.         ADC_Configuration();
  21.         Timer2_Configuration();
  22.
  23.
  24.   while (1)
  25.   {
  26.   }
  27. }
  28. /*******************************************************************************
  29. * Function Name  : ADC_Configuration
  30. * Description    : Configure the ADC.
  31. * Input          : None
  32. * Output         : None
  33. * Return         : None
  34. * Attention                 : None
  35. *******************************************************************************/
  36. void Timer2_Configuration(void)
  37. {
  38.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  39.         TIM_DeInit(TIM2);
  40.         TIM_TimeBaseStructure.TIM_Period=9;
  41.         TIM_TimeBaseStructure.TIM_Prescaler=35999;
  42.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  43.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  44.         TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  45.         TIM_ClearFlag(TIM2,TIM_FLAG_Update);
  46.         TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
  47.         TIM_Cmd(TIM2,ENABLE);
  48. }
  49. void ADC_Configuration(void)
  50. {
  51.
  52.           GPIO_InitTypeDef GPIO_InitStructure;
  53.           NVIC_InitTypeDef NVIC_InitStructure;
  54.           DMA_InitTypeDef DMA_InitStructure;
  55.           ADC_InitTypeDef ADC_InitStructure;
  56.           RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  57.           RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC| RCC_APB2Periph_AFIO, ENABLE);
  58.           RCC_ADCCLKConfig(RCC_PCLK2_Div6);
  59.           RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  60.                     /* Configure PC0 ()as analog input -------------------------*/
  61.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  62.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  63.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  64.           GPIO_Init(GPIOC, &GPIO_InitStructure);  //选择端口PC0,最大输出速度50MHZ,模拟输入
  65.
  66.           /* Configure PC4 (ADC12 Channel4)as analog input -------------------------*/
  67.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  68.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  69.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  70.           GPIO_Init(GPIOC, &GPIO_InitStructure);  //选择端口PC1,最大输出速度50MHZ,模拟输入
  71.
  72.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  73.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  74.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  75.           GPIO_Init(GPIOC, &GPIO_InitStructure);  //选择端口PC2,最大输出速度50MHZ,模拟输入
  76.
  77.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  78.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  79.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  80.           GPIO_Init(GPIOC, &GPIO_InitStructure);  //选择端口PC3,最大输出速度50MHZ,模拟输入
  81.
  82.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  83.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  84.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  85.           GPIO_Init(GPIOC, &GPIO_InitStructure);  //选择端口PC4,最大输出速度50MHZ,模拟输入
  86.
  87.           /* Configure one bit for preemption priority */
  88.           NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  89.
  90.           /* Enable the TIM2 Interrupt */
  91.           NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  92.           NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  93.           NVIC_InitStructure.NVIC_IRQChannelSubPriority = 4;
  94.           NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  95.           NVIC_Init(&NVIC_InitStructure);
  96.                                                 /* DMA channel1 configuration ----------------------------------------------*/
  97.                 DMA_DeInit(DMA1_Channel1);
  98.             DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//adc1的数据寄存器设备地址,数据手册上有
  99.             DMA_InitStructure.DMA_MemoryBaseAddr = (u32)adc_value;//一个有3个元素数组的首地址
  100.             DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  101.             DMA_InitStructure.DMA_BufferSize = 3;
  102.             DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  103.             DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  104.             DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  105.             DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  106.             //循环模式开启,Buffer写满后,自动回到初始地址开始传输
  107.             DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  108.             DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  109.             DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  110.             DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  111.
  112.                 DMA_ClearFlag(DMA1_FLAG_TC1);
  113.                     //配置完成后,启动DMA通道
  114.                 DMA_ClearITPendingBit(DMA1_IT_TC1);
  115.                 DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);
  116.                 DMA_Cmd(DMA1_Channel1, ENABLE);
  117.
  118.                 ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;
  119.                 ADC_InitStructure.ADC_ScanConvMode=ENABLE;
  120.                 ADC_InitStructure.ADC_ContinuousConvMode=DISABLE;
  121.                 ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;
  122.                 ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right;
  123.                 ADC_InitStructure.ADC_NbrOfChannel=3;
  124.                 ADC_Init(ADC1,&ADC_InitStructure);
  125.
  126.                 ADC_RegularChannelConfig(ADC1,ADC_Channel_11,1,ADC_SampleTime_1Cycles5);
  127.                 ADC_RegularChannelConfig(ADC1,ADC_Channel_12,2,ADC_SampleTime_1Cycles5);
  128.                 ADC_RegularChannelConfig(ADC1,ADC_Channel_13,3,ADC_SampleTime_1Cycles5);
  129.
  130.                 ADC_DMACmd(ADC1,ENABLE);
  131.                 ADC_Cmd(ADC1,ENABLE);
  132.
  133.                 ADC_ResetCalibration(ADC1);
  134.                 while(ADC_GetResetCalibrationStatus(ADC1));
  135.                 ADC_StartCalibration(ADC1);
  136.                 while(ADC_GetCalibrationStatus(ADC1));
  137.                 ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
  138.                 ADC_SoftwareStartConvCmd(ADC1,DISABLE);
  139. }
cdshkf 发表于 2014-5-8 14:19 | 显示全部楼层
中断函数里:
  1. #include "stm32f10x_it.h"
  2. vu16 adc_current[7];
  3. vu16 ci=0;
  4. vu16 Max_cu=0;
  5. vu16 Min_cu=0;
  6. vu16 sum_cu=0;
  7. vu16 Max_voa=0;
  8. vu16 Min_voa=0;
  9. vu16 sum_voa=0;
  10. vu16 Max_vob=0;
  11. vu16 Min_vob=0;
  12. vu16 sum_vob=0;
  13. vu16 adc_cu=0;
  14. vu16 adc_voa=0;
  15. vu16 adc_vob=0;
  16. extern vu16 adc_value[3];
  17. vu16 adc_voltagea[7];
  18. vu16 adc_voltageb[7];
  19. /** @addtogroup STM32F10x_StdPeriph_Template
  20.   * @{
  21.   */
  22. /* Private typedef -----------------------------------------------------------*/
  23. /* Private define ------------------------------------------------------------*/
  24. /* Private macro -------------------------------------------------------------*/
  25. /* Private variables ---------------------------------------------------------*/
  26. /* Private function prototypes -----------------------------------------------*/
  27. /* Private functions ---------------------------------------------------------*/
  28. /******************************************************************************/
  29. /*            Cortex-M3 Processor Exceptions Handlers                         */
  30. /******************************************************************************/
  31. /**
  32.   * [url=home.php?mod=space&uid=247401]@brief[/url]  This function handles NMI exception.
  33.   * @param  None
  34.   * @retval None
  35.   */
  36. void NMI_Handler(void)
  37. {
  38. }
  39. /**
  40.   * @brief  This function handles Hard Fault exception.
  41.   * @param  None
  42.   * @retval None
  43.   */
  44. void HardFault_Handler(void)
  45. {
  46.   /* Go to infinite loop when Hard Fault exception occurs */
  47.   while (1)
  48.   {
  49.   }
  50. }
  51. /**
  52.   * @brief  This function handles Memory Manage exception.
  53.   * @param  None
  54.   * @retval None
  55.   */
  56. void MemManage_Handler(void)
  57. {
  58.   /* Go to infinite loop when Memory Manage exception occurs */
  59.   while (1)
  60.   {
  61.   }
  62. }
  63. /**
  64.   * @brief  This function handles Bus Fault exception.
  65.   * @param  None
  66.   * @retval None
  67.   */
  68. void BusFault_Handler(void)
  69. {
  70.   /* Go to infinite loop when Bus Fault exception occurs */
  71.   while (1)
  72.   {
  73.   }
  74. }
  75. /**
  76.   * @brief  This function handles Usage Fault exception.
  77.   * @param  None
  78.   * @retval None
  79.   */
  80. void UsageFault_Handler(void)
  81. {
  82.   /* Go to infinite loop when Usage Fault exception occurs */
  83.   while (1)
  84.   {
  85.   }
  86. }
  87. /**
  88.   * @brief  This function handles SVCall exception.
  89.   * @param  None
  90.   * @retval None
  91.   */
  92. void SVC_Handler(void)
  93. {
  94. }
  95. /**
  96.   * @brief  This function handles Debug Monitor exception.
  97.   * @param  None
  98.   * @retval None
  99.   */
  100. void DebugMon_Handler(void)
  101. {
  102. }
  103. /**
  104.   * @brief  This function handles PendSVC exception.
  105.   * @param  None
  106.   * @retval None
  107.   */
  108. void PendSV_Handler(void)
  109. {
  110. }
  111. /**
  112.   * @brief  This function handles SysTick Handler.
  113.   * @param  None
  114.   * @retval None
  115.   */
  116. void TIM2_IRQHandler(void)
  117. {
  118.   TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
  119.   ADC_SoftwareStartConvCmd(ADC1,ENABLE);
  120.
  121.    while(!(DMA_GetFlagStatus(DMA1_FLAG_TC1)));
  122.   ADC_SoftwareStartConvCmd(ADC1,DISABLE);
  123.     adc_current[ci]=adc_value[0];
  124.     adc_voltagea[ci]=adc_value[1];
  125.     adc_voltageb[ci]=adc_value[2];
  126.      DMA_ClearFlag(DMA1_FLAG_TC1);
  127.   ci++;
  128.    if(ci==7)
  129.    {
  130.    ci=0;
  131.    Max_cu=adc_current[0];
  132.       Min_cu=adc_current[0];
  133.       sum_cu=adc_current[0];
  134.    Max_voa=adc_voltagea[0];
  135.       Min_voa=adc_voltagea[0];
  136.       sum_voa=adc_voltagea[0];
  137.    Max_vob=adc_voltageb[0];
  138.       Min_vob=adc_voltageb[0];
  139.       sum_vob=adc_voltageb[0];
  140.       for(ci=1;ci<7;ci++)
  141.        {
  142.          sum_cu=sum_cu+adc_current[ci];
  143.          if(adc_current[ci]>Max_cu) Max_cu=adc_current[ci];
  144.          if(adc_current[ci]<Min_cu) Min_cu=adc_current[ci];
  145.       sum_voa=sum_voa+adc_voltagea[ci];
  146.          if(adc_voltagea[ci]>Max_voa) Max_voa=adc_voltagea[ci];
  147.          if(adc_voltagea[ci]<Min_voa) Min_voa=adc_voltagea[ci];
  148.       sum_vob=sum_vob+adc_voltageb[ci];
  149.          if(adc_voltageb[ci]>Max_vob) Max_vob=adc_voltageb[ci];
  150.          if(adc_voltageb[ci]<Min_vob) Min_vob=adc_voltageb[ci];
  151.        }
  152.    adc_cu=(sum_cu-Max_cu-Min_cu)/5;
  153.    adc_voa=(sum_voa-Max_voa-Min_voa)/5;
  154.    adc_vob=(sum_vob-Max_vob-Min_vob)/5;
  155.    ci=0;
  156.    }
  157. }
cdshkf 发表于 2014-5-8 14:27 | 显示全部楼层
1、楼猪的程序里没有提供tim2的中断配置,没有提供ADC的时钟配置,没有提供PC0、PC1、PC2的GPIO口配置,我都给补上了。
2、有个问题,楼猪在中断处理函数和main函数中都调用了adc_value这个数组,不知道楼猪怎么定义的,我采取的方式是在main函数中定义,然后中断函数中用extern声明一下。
3、ADC的时钟频率不能超过14MHz,楼猪给的代码里没有ADC时钟配置,所以RCC_ADCCLKConfig(RCC_PCLK2_Div6);这句话不知道楼猪有没有用到。
4、AD采集IO口要设置成模拟输入。
5、建议楼猪用我帮楼猪改的程序试试,如果还有问题,建议楼猪把手里的板子砸了,或者在夜深人静的时候找个墙角好好的思考一下,人品出了问题是无药可救的!
