[STM32F0] 请大神告诉我该如何才能调用stm32f0 IRQ的变量到主函数
2394|5
 楼主| jmworkspace 发表于 2014-5-19 15:00 | 显示全部楼层 |阅读模式
代码如下main.c:
/* Includes ------------------------------------------------------------------*/
#include "stm32f0xx.h"
TIM_ICInitTypeDef  TIM_ICInitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
/* Private function prototypes -----------------------------------------------*/
void TIM_Config(void);
void Output_TIM_Config(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    /* TIM Configuration */
  TIM_Config();
  Output_TIM_Config();
    TIM2 configuration: PWM Input mode
    In this example TIM2 input clock (TIM2CLK) is set to APB1 clock (PCLK1)
      TIM2CLK = PCLK1
      => TIM2CLK = HCLK = SystemCoreClock
    External Signal Frequency = TIM2 counter clock / TIM2_CCR2 in Hz.
    External Signal DutyCycle = (TIM2_CCR1*100)/(TIM2_CCR2) in %.
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIM2, &TIM_ICInitStructure);
  /* Select the TIM2 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM2, TIM_TS_TI2FP2);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIM2,TIM_MasterSlaveMode_Enable);
  /* TIM enable counter */
  TIM_Cmd(TIM2, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TIM_ITConfig(TIM2, TIM_IT_CC2, ENABLE);
          /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* TIM1 Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  /* Infinite loop */
  while (1)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOA clock enable */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  /* TIM2 chennel2 configuration : PA.01 */
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Connect TIM pin to AF2 */
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_2);
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* GPIOA Clocks enable */
  RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
  /* GPIOA Configuration: Channel 1, 2, 3 and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_2);
        /* TIM1 clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);
        /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        /* Channel 1, 2, 3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_Pulse = Channel1Pulse;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
        #ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
这下面的是stm32f0xx_it.c的IRQ函数:
#include "stm32f0xx_it.h"
/** @addtogroup STM32F0_Discovery_Peripheral_Examples
/** @addtogroup TIM_PWM_Input
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint16_t IC2Value = 0;
__IO uint16_t DutyCycle = 0;
__IO uint32_t Frequency = 0;
uint16_t        Channel1Pulse;
uint32_t        TimerPeriod;
/*            Cortex-M0 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
/*                 STM32F0xx Peripherals Interrupt Handlers                   */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_stm32f0xx.s).                                               */
  * @brief  This function handles TIM2 global interrupt request.
  * @param  None
  * @retval None
void TIM2_IRQHandler(void)
  RCC_ClocksTypeDef RCC_Clocks;
  RCC_GetClocksFreq(&RCC_Clocks);
  /* Clear TIM2 Capture compare interrupt pending bit */
  TIM_ClearITPendingBit(TIM2, TIM_IT_CC2);
  /* Get the Input Capture value */
  IC2Value = TIM_GetCapture2(TIM2);
  if (IC2Value != 0)
    /* Duty cycle computation */
    DutyCycle = (TIM_GetCapture1(TIM2) * 100) / IC2Value;
                Channel1Pulse = DutyCycle;
    /* Frequency computation
       TIM2 counter clock = (RCC_Clocks.HCLK_Frequency)/2 */
    Frequency = RCC_Clocks.HCLK_Frequency / IC2Value;
                TimerPeriod = Frequency;
  else
    DutyCycle = 0;
    Frequency = 0;
  * @brief  This function handles PPP interrupt request.
  * @param  None
  * @retval None
/*void PPP_IRQHandler(void)
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
我就是想将DutyCycle、Frequency这两个依靠IO输入数据变化不断改变输出图像
 楼主| jmworkspace 发表于 2014-5-19 15:38 | 显示全部楼层
没有人吗:'(
mmuuss586 发表于 2014-5-19 17:11 | 显示全部楼层
MAIN函数里, 声明的时候,加上:
extern Frequency……
icecut 发表于 2014-5-19 20:48 | 显示全部楼层
记得全局变量加volatile
 楼主| jmworkspace 发表于 2014-5-20 10:35 | 显示全部楼层
好了 解决了 extern就好了
