急救:AD7705 调不出啊
2674|0
 楼主| dengyunfei 发表于 2007-8-5 16:48 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define AD_CLK_WIDTH 1 /*AD7705串口时钟脉冲宽度*/
unsigned char decimal_number[]={0x30,0xf5,0x58,0xd0,0x95,0x92,0x12,0xf4,0x10,0x90};   //0-9所对应的八段码
#define SomeNOP(); {_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();}
void Wait7705(unsigned int t) { for( ;t>0 ;t-- ); }
//void Init_disp();        // 显示板初始化
void Translate(void);        //结果处理函数
void delay();
sbit SDA=P0^4;
sbit CP=P0^5;
sbit P1_0=P1^0;
sbit ADC_DIN=P1^1;        //定义数据输入管脚
sbit ADC_DOUT=P1^2;        //定义数据输出管脚
sbit ADC_CS=P1^3;        //定义片选管脚
sbit ADC_DRDY=P1^4;        //AD转换结束标志位
sbit ADC_RESET=P1^5;                                                              //复位
sbit ADC_CLK=P1^6;        //时钟对应单片机管脚
unsigned char flag_disp;                                                           //显示完成标志位
unsigned int ADdata;                                                              //AD读数结果
float airpressf;        //0--350bar   气室AD读数对应的气压值 bar为单位
unsigned char data2disp[5]={0x30,0x30,0x30,0x30,0x20};                            //显示数据,4个显示板,各5位,共享
void Write_functionAD(unsigned char wridata)                                     //AD写函数,初始化AD
{ unsigned char AD8bit,Token,i;
  ADC_CLK=1; ADC_CS=0;
  Token=0X80; AD8bit=wridata;
  for(i=0;i<8;i++)
  { ADC_CLK=0;
    Wait7705(AD_CLK_WIDTH);
    if(AD8bit&Token)  ADC_DIN=1;                                                //MSB高位数据先移入AD7705
    else              ADC_DIN=0;
    Wait7705(AD_CLK_WIDTH );
    ADC_CLK=1;                                         //在SCLK的上升沿,DIN数据有效
    Token=Token>>1;
ADC_CS=1;
//ADC_CLK=1;ADC_DIN=1;
float Read_functionAD()                                                        //AD读函数,读取转换结果
{ unsigned int AD16bit;
  unsigned char i;
  Write_functionAD(0X38);
 //          while(ADC_DRDY==1){;}
  ADC_CLK=1;
  ADC_CS=0;
  AD16bit=0X00;
  for(i=0;i<16;i++)
     AD16bit=AD16bit<<1;
     ADC_CLK=0;
     Wait7705(AD_CLK_WIDTH);                                                       //在SCL K 的下降沿之后,DOUT数据有效
     if(ADC_DOUT==1)AD16bit=AD16bit|0X01;
     ADC_CLK=1;
  // ADC_CLK=1;ADC_DIN=1;
  return(AD16bit);                                                         //返回AD转换结果
void initial_functionAD()                                                 //初始化AD转换芯片
   unsigned char i;
   ADC_CS=0;
   ADC_RESET=0;
   SomeNOP();
   ADC_RESET=1;                                                          //AD复位完成
   //xchannel=channel;
   ADC_CLK=1;ADC_DIN=1;                                                   //防止接口迷失,通信寄存器返回到等待写状态,DIN为1的时间在32个以上的时钟周期
   for(i=0;i<40;i++)
   {  ADC_CLK=0;
      ADC_CLK=1;
   Write_functionAD(0x20);                                                //通道1 ,下一个写时钟寄存器
   Write_functionAD(0x06);                                               //写时钟寄存器设置更新速率为250Hz
   Write_functionAD(0x10);                                                // 通道1 ,下一个写设置寄存器
   Write_functionAD(0x44);                                              //写设置寄存器,设置成单极性、无缓冲、增益为1、滤波器工作、自校准
   delay();                                                         //延时
void delay()                                                        //延时函数
      unsigned char i,k,temp;
    for(i=0;i<38;i++)
    for(k=0;k<225;k++)
    for(temp=0;temp<25;temp++);                                          //延时,这里的延时和机器周期关系很大
void display(unsigned char datadisplay)                              //8位数LED显示函数
  unsigned char k,temp;
  temp=datadisplay;
  for(k=8;k>0;k--)
          temp=temp<<1;
          if(CY) ADC_DOUT=1;          else  ADC_DOUT=0;                //显示
          ADC_CLK=0;
          SomeNOP();                                                       //延时
          ADC_CLK=1;
void main()
{  unsigned char i;
   unsigned int a;
   flag_disp=0;                          //显示完成标志
   delay();
    initial_functionAD();                  //初始化AD转换器
   while(1)
        for(a=0;a<50000;a++);
        P1_0=0;
        P1_0=1;
        if(ADC_DRDY==0)
          {  ADdata=Read_functionAD();
             flag_disp=1;
          }                              //ADC_DEDY
         if(flag_disp==1)
         {  flag_disp=0;
            Translate();
            for(i=0;i<5;i++)
             { display(data2disp);
     }   //while 1
{ unsigned char j,k,b;
  unsigned char i=0;
  unsigned char a[6]={1,2,3,4,5,6};
  unsigned char airpressc,airpressc2,airpressc3;
  airpressf=(ADdata/51.0-1)/4.0;
  airpressc2=airpressc3=airpressc=(unsigned char)airpressf;
  for(k=0;k<6;k++)
  {  a[k]=airpressc3%10;
     if(a[k]!=0){ b=a[k];break;}
     airpressc3/=10;
      k++;
         do
             data2disp=airpressc%10;
            airpressc/=10; //此处处理整数部分
            i++;
         }while(airpressc);    //    至此,整数部分已转换为字符
        switch (i)        //将相应字符移位,
            case 1:
                data2disp[4]=data2disp[0];
                break;
            case 2:
                data2disp[4]=data2disp[1];
                data2disp[3]=data2disp[0];
                break;
            case 3:
               data2disp[4]=data2disp[2];
               data2disp[3]=data2disp[1];
               data2disp[2]=data2disp[0];
               break;
        airpressf-=airpressc2;//取出小数部分
        j=5-i;
        while(j>0)
            j--;
            airpressf*=10;
            (data2disp[j])=(unsigned char)airpressf;
            airpressf-=data2disp[j];
    data2disp[0]=b;                                                       //防止尾数不稳
    for(j=0;j<5;j++)                                                      //查找字形码
       {   data2disp[j]=decimal_number[data2disp][j]];
         data2disp[5-i]&=0x10;                                              //加上小数点
