我使用stm32f207 老是出现串口死机 搞了好久了大家帮我看看
1654|1
 楼主| d350998385 发表于 2014-6-4 15:51 | 显示全部楼层 |阅读模式
大家帮我看看 有问题吗?下面是初始化函数
函数名称:初始化IO 串口1
函数功能:
出口参数:bound:波特率
void Uart1_Init(u32 bound)
         NVIC_InitTypeDef NVIC_InitStructure;
   USART_InitTypeDef USART_InitStructure;
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);        //配置GPIOA和USART1时钟
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
   GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);        //端口映射选择
   GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
   /*配置串口1的TX*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //最高输出速率50MHz
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;        //AF复用
   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;        //PP推挽式
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
   GPIO_Init(GPIOA, &GPIO_InitStructure);        // void GPIO_Init(GPIO_TypeDef *GPIOx, GPIO_InitTypeDef *GPIO_InitStruct)
   /*配置串口1的RX*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
   GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;        //OD Open-Drain 开漏
   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
   /*配置串口1的模式*/
   USART_InitStructure.USART_BaudRate = bound;
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
   USART_InitStructure.USART_StopBits = USART_StopBits_1;
   USART_InitStructure.USART_Parity = USART_Parity_No;
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
   USART_Init(USART1, &USART_InitStructure);   // void USART_Init(USART_TypeDef *USARTx,)
   USART_Cmd(USART1, ENABLE);  // void USART_Cmd(USART_TypeDef *USARTx, FunctionalState NewState)
    //Usart1 NVIC 配置
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;        //抢占优先级3
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;        //子优先级3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;        //IRQ通道使能
    NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);        //开启中断
    USART_ITConfig(USART1, USART_IT_TXE, DISABLE);        //开启中断
    USART_Cmd(USART1, ENABLE);        //使能串口
下面是中断处理函数。
函数名称:串口1中断服务函数
函数功能:
出口参数:
void USART1_IRQHandler(void)        // 串口1中断服务程序
                u8 Res;
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)                                   // 接收中断(接收到的数据必须是0x0d 0x0a结尾)
//if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) != RESET)
                         Res =USART_ReceiveData(USART1);        //(USART1->DR);
                         buffreadtourat1[len_buffreadtourat1]=Res;
                         len_buffreadtourat1++;
                         if((buffreadtourat1[len_buffreadtourat1-1]==0x29)||(len_buffreadtourat1>100))
                                        len_buffreadtourat1=0;
                                        Flag_Allow_Send_Net=1;
时间不定会死机  有时候几十分钟 有时候 几个小时
最终进入 硬件中断里面
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
一般我查看都是从这里进去的
ITStatus USART_GetITStatus(USART_TypeDef* USARTx, uint16_t USART_IT)
  uint32_t bitpos = 0x00, itmask = 0x00, usartreg = 0x00;
  ITStatus bitstatus = RESET;
  /* Check the parameters */
  assert_param(IS_USART_ALL_PERIPH(USARTx));
  assert_param(IS_USART_GET_IT(USART_IT));
  /* The CTS interrupt is not available for UART4 and UART5 */
  if (USART_IT == USART_IT_CTS)
    assert_param(IS_USART_1236_PERIPH(USARTx));
  /* Get the USART register index */
  usartreg = (((uint8_t)USART_IT) >> 0x05);
  /* Get the interrupt position */
  itmask = USART_IT & IT_MASK;
  itmask = (uint32_t)0x01 << itmask;
  if (usartreg == 0x01) /* The IT  is in CR1 register */
    itmask &= USARTx->CR1;
  else if (usartreg == 0x02) /* The IT  is in CR2 register */
    itmask &= USARTx->CR2;
  else /* The IT  is in CR3 register */
    itmask &= USARTx->CR3;
  bitpos = USART_IT >> 0x08;
  bitpos = (uint32_t)0x01 << bitpos;
  bitpos &= USARTx->SR;
  if ((itmask != (uint16_t)RESET)&&(bitpos != (uint16_t)RESET))
    bitstatus = SET;
  else
    bitstatus = RESET;
  return bitstatus;
其他定时器的优先级 都很低
//»ù±¾¶¨Ê±Æ÷6Öжϳõʼ»¯
//ÕâÀïʱÖÓÑ¡ÔñΪAPB1µÄ2±¶£¬¶øAPB1Ϊ36M
//arr£º×Ô¶¯ÖØ×°Öµ¡£
//psc£ºÊ±ÖÓÔ¤·ÖƵÊý
//ÕâÀïʹÓõÄÊǶ¨Ê±Æ÷3!
void TIM6_Int_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE); //ʱÖÓʹÄÜ
        TIM_TimeBaseStructure.TIM_Period = arr; //ÉèÖÃÔÚÏÂÒ»¸ö¸üÐÂʼþ×°Èë»î¶¯µÄ×Ô¶¯ÖØ×°ÔؼĴæÆ÷ÖÜÆÚµÄÖµ         ¼ÆÊýµ½5000Ϊ500ms
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //ÉèÖÃÓÃÀ´×÷ΪTIMxʱÖÓÆµÂʳýÊýµÄÔ¤·ÖƵֵ  10KhzµÄ¼ÆÊýƵÂÊ
        TIM_TimeBaseStructure.TIM_ClockDivision = 0; //ÉèÖÃʱÖÓ·Ö¸î:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIMÏòÉϼÆÊýģʽ
        TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure); //¸ù¾ÝTIM_TimeBaseInitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯TIMxµÄʱ¼ä»ùÊýµ¥Î»
        TIM_ITConfig( TIM6,TIM_IT_Update|TIM_IT_Trigger,ENABLE);//ʹÄܶ¨Ê±Æ÷6¸üд¥·¢ÖжÏ
        TIM_Cmd(TIM6, ENABLE);  //ʹÄÜTIMxÍâÉè
  NVIC_InitStructure.NVIC_IRQChannel = TIM6_DAC_IRQn;  //TIM6ÖжÏ
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;  //ÏÈÕ¼ÓÅÏȼ¶2¼¶
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  //´ÓÓÅÏȼ¶3¼¶
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQͨµÀ±»Ê¹ÄÜ
        NVIC_Init(&NVIC_InitStructure);  //¸ù¾ÝNVIC_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèNVIC¼Ä´æÆ÷
//»ù±¾¶¨Ê±Æ÷3Öжϳõʼ»¯
//arr£º×Ô¶¯ÖØ×°Öµ¡£
//psc£ºÊ±ÖÓÔ¤·ÖƵÊý
//ÕâÀïʹÓõÄÊǶ¨Ê±Æ÷3!
void TIM3_Int_Init(u16 arr,u16 psc)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //ʱÖÓʹÄÜ
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //ÉèÖÃʱÖÓ·Ö¸î:TDTS = Tck_tim
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //¸ù¾ÝTIM_TimeBaseInitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯TIMxµÄʱ¼ä»ùÊýµ¥Î»
        TIM_ITConfig( TIM3,TIM_IT_Update|TIM_IT_Trigger,ENABLE);//ʹÄܶ¨Ê±Æ÷6¸üд¥·¢ÖжÏ
        TIM_Cmd(TIM3, ENABLE);  //ʹÄÜTIMxÍâÉè
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM6ÖжÏ
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 14;  //ÏÈÕ¼ÓÅÏȼ¶2¼¶
不知道怎么回事 大家帮我看看啊?
zchong 发表于 2014-6-7 21:34 | 显示全部楼层
调试,看看进入硬件hardfault前执行的是什么代码,很快就能定位问题
