ARM调试利器--JLINK V7
2339|4
 楼主| meteor01 发表于 2009-5-15 12:57 | 显示全部楼层 |阅读模式
这款是全功能V7版本,支持RDI,&nbsp;FlashDL,&nbsp;FlashBP,&nbsp;JFlash,&nbsp;GDBFull<br /><br />除拥有上一版本V6.0的全部功能外,对于Cortex-M3的Serial&nbsp;Wire&nbsp;Viewer(SWV)速度是V6的12倍。<br /><br /><br />SWV介绍页面:http://www.segger.com/jlink_swv.html<br /><br />The&nbsp;supported&nbsp;&nbsp;SWV&nbsp;speeds&nbsp;depend&nbsp;on&nbsp;the&nbsp;connected&nbsp;emulator.&nbsp;They&nbsp;can&nbsp;be&nbsp;retrieved&nbsp;from&nbsp;the&nbsp;emulator.<br />Currently,&nbsp;the&nbsp;following&nbsp;are&nbsp;supported:<br /><br />Emulator&nbsp;Speed&nbsp;,&nbsp;formular&nbsp;Resulting&nbsp;max.&nbsp;speed<br />J-Link&nbsp;V6&nbsp;6MHz/n,&nbsp;n&nbsp;&gt=&nbsp;12&nbsp;500kHz<br />J-Link&nbsp;V7&nbsp;6MHz/n,&nbsp;n&nbsp;&gt=&nbsp;1&nbsp;6MHz<br /><br />USB&nbsp;2.0接口;<br />支持任何ARM7/ARM9&nbsp;核Cortex&nbsp;M3&nbsp;supported,&nbsp;包括ithumb&nbsp;模式;<br />下载速度达到600k&nbsp;byte/s;<br />DCC速度到达800k&nbsp;byte/s;<br />与IAR&nbsp;Workbench可无缝集成;<br />通过USB供电,无需外接电源;<br />JTAG最大时钟达到12M;<br />自动内核识别;<br />自动速度识别;<br />支持自适应时钟;<br />所有JTAG信号能被监控,目标板电压能被侦测;<br />支持JTAG链上多个设备的调试;<br />完全即插即用;<br />20Pin标准JTAG连接器;<br />多核调试;<br />包括软件:<br />&nbsp;J-Mem,可查询可修改内存;<br />&nbsp;J-Link&nbsp;Server:(可通过TCP/IP连接到J-Link);<br />&nbsp;J-Flash,支持独立的Flash编程,可以作为量产解决方案;<br />&nbsp;RDI插件使J-Link适合任何RDI兼容的调试器如IAR、ADS、Relview和Keil等;<br />&nbsp;RDI&nbsp;Flash&nbsp;BP,可以实现在RDI下,在Flash中设置无限断点;<br />&nbsp;RDI&nbsp;Flash&nbsp;DLL,可以实现在RDI下的对Flash的独立编程;<br />&nbsp;GDB&nbsp;server,可以实现在GDB环境下的调试。<br /><br />Supported&nbsp;ARM&nbsp;Cores:<br />J-Link&nbsp;has&nbsp;been&nbsp;tested&nbsp;with&nbsp;the&nbsp;following&nbsp;cores,&nbsp;but&nbsp;should&nbsp;work&nbsp;with&nbsp;any<br />ARM7/ARM9&nbsp;and&nbsp;Cortex-M3&nbsp;core.<br />*&nbsp;ARM7TDMI&nbsp;(Rev&nbsp;1)<br />*&nbsp;ARM7TDMI&nbsp;(Rev&nbsp;3)<br />*&nbsp;ARM7TDMI-S&nbsp;(Rev&nbsp;4)<br />*&nbsp;ARM720T<br />*&nbsp;ARM920T<br />*&nbsp;ARM922T<br />*&nbsp;ARM926EJ-S<br />*&nbsp;ARM946E-S<br />*&nbsp;ARM966E-S<br />*&nbsp;Cortex-M3<br /> 相关链接:<a href='http://item.taobao.com/auction/item_detail.jhtml?item_id=811134c5a4b3b3b4e0489a380b0e8d8c&x_id=0db1'>http://item.taobao.com/auction/item_detail.jhtml?item_id=811134c5a4b3b3b4e0489a380b0e8d8c&x_id=0db1</a>
 楼主| meteor01 发表于 2009-5-15 13:01 | 显示全部楼层
ARM调试利器--JLINK V7
JLINK&nbsp;V7&nbsp;全功能版本&nbsp;&nbsp;http://shop.edn21.cn <br /> 相关链接:<a href='http://shop.edn21.cn'>http://shop.edn21.cn</a>
guet 发表于 2009-5-15 13:01 | 显示全部楼层
前阵买了一个,真的挺好用
 楼主| meteor01 发表于 2009-5-15 13:04 | 显示全部楼层
ARM调试利器--JLINK V7 85元
是的跟原版的一样哦,固件可以升级的。
 楼主| meteor01 发表于 2009-7-9 22:59 | 显示全部楼层
欢迎选购
