[STM32F0] 讨论:串口接收数据完成标志,谢谢
9042|9
 楼主| cepoly 发表于 2014-6-23 15:28 | 显示全部楼层 |阅读模式
大体实现:GPS连接STM32F0单片机串口,利用中断接收,但不知道串口接收数据长度,GPS数据长度受卫星信号影响,我一直在找硬件寄存器标志,即数据接收结束后,这个寄存器标志响应,然后我就可以读个寄存器来判定数据接收完毕!
1.GPS数据长度不确定(最大可达1024个byte),如:
$GPRMC,,V,,,,,,,,,,N*53
$GPVTG,,,,,,,,,N*30
$GPGGA,,,,,,0,00,99.99,,,,,,*48
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
$GPGSV,1,1,00*79
$GPGLL,,,,,,V,N*64
我的程序如下:
void USBD_USR_Init(void)
  USART_InitTypeDef USART_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  RCC_AHBPeriphClockCmd (RCC_AHBPeriph_GPIOA,   ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource9, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
  *  USART1_TX -> PA9 , USART1_RX ->;PA10
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_10;
  USART_InitStructure.USART_BaudRate   = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits   = USART_StopBits_1;
  USART_InitStructure.USART_Parity     = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode       = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  USART_Cmd(USART1, ENABLE);
#include "usbd_cdc_core.h"
#include "stm32f0xx_tim.h"
#include "usbd_usr.h"
#include "string.h"
#define  BYTE_SIZE                          1024
#define  SEND_TO_USB                    1
#define  SEND_TO_USB_END           0
#define  CLR_REV_BYTE                   0
#define  CLR_REV_TIME                   0
#define  UART_REV_TIME                   1
USB_CORE_HANDLE  USB_Device_dev ;
typedef struct
  uint32_t bitrate;
  uint8_t  format;
  uint8_t  paritytype;
  uint8_t  datatype;
}LINE_CODING;
LINE_CODING serial ={9600, 0x00, 0x00,  0x08};
static uint8_t  RevChar[BYTE_SIZE];
static volatile uint16_t  RevSize,SendByte;;
static volatile uint8_t   rev_end;
static volatile uint8_t   rev_flag;
static volatile uint8_t   time_add;
static          uint8_t         Author[26] = "**** poly 2014.06.21 *****";
static          uint8_t         test[5] = {5,6,7,8,9};
void Delay_us(__IO uint32_t nCount);
void Delay_ms(__IO uint32_t nCount);
void NVIC_Config(void);
void TIM2_Config(void);
void USART1_TX_DataN (uint8_t *pData,uint16_t TX_NumByte);
int main(void)
        RevSize = 0;
        rev_end = 0;
        rev_flag = 0;
        NVIC_Config();
        TIM2_Config();
        memset(RevChar, '\0', BYTE_SIZE);
        USBD_Init(&USB_Device_dev, &USR_desc, &USBD_CDC_cb, &USBD_USR_Init);
  //USART1_TX_DataN (Author, 26);
  while (1)
                if((SendByte > 0) && (rev_end == SEND_TO_USB))
                        //USART1_TX_DataN (RevChar, SendByte);
                        DCD_EP_Tx (&USB_Device_dev, CDC_IN_EP, RevChar, SendByte);
                        rev_end  = SEND_TO_USB_END;
                        rev_flag = CLR_REV_TIME;
                }else{
                        if(time_add > 5)
                               //DCD_EP_Tx (&USB_Device_dev, CDC_CMD_EP, "a", 1);
  //中断传输,CDC协议说是传输串口状态,论坛上坛友说用户不能用这个中断传输,目前我直接写字节传        //输,主机HOST端也可以接收到
                                time_add = 0;
* Function Name          : USART1_IRQHandler
* Description            : USART1
void USART1_IRQHandler(void)
        if(rev_flag == CLR_REV_TIME)
                TIM_Cmd(TIM2,ENABLE);
                rev_flag = UART_REV_TIME;
  if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
                if (serial.datatype == 7)
                        RevChar[RevSize] = USART_ReceiveData(USART1) & 0x7F;
                else if (serial.datatype == 8)
                        RevChar[RevSize] = USART_ReceiveData(USART1);
  RevSize++;
// USART_SendData(USART1,RevChar[RevSize]);
void TIM2_IRQHandler(void)
          if(TIM_GetITStatus(TIM2,TIM_IT_Update) != RESET)
       TIM_ClearITPendingBit(TIM2,TIM_FLAG_Update);
          TIM_Cmd(TIM2,DISABLE);
          rev_end  = SEND_TO_USB;
                SendByte = RevSize;
                RevSize  = CLR_REV_BYTE;
                time_add ++;
void Delay(__IO uint32_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
                nCount--;
  /* 10uS=>10.8uS,100uS=>104uS*/
  while (nCount != 0)
                nCount--;
                Delay(10);
  while (nCount != 0)
                nCount--;
                Delay(11000);
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
        TIM_DeInit(TIM2);
        TIM_TimeBaseStructure.TIM_Period = 65536;
        TIM_TimeBaseStructure.TIM_Prescaler = 550;//n * 1.5ms
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
        TIM_ClearFlag(TIM2,TIM_FLAG_Update);
        TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
void USART1_TX_DataN(uint8_t *pData,uint16_t TX_NumByte)
        uint16_t i;
        for(i=0;i<TX_NumByte;i++)
                        USART_SendData(USART1,*pData++);
//                #if(USART1_BaudRate==115200)
//                Delay_us(90);
//                #if(USART1_BaudRate==19200)
//                Delay_us(500);
//                #if(USART1_BaudRate==9600)
//                Delay_us(1000);
                        Delay_us(1000);
                        USART_ClearFlag(USART1,USART_FLAG_TXE);
终于解决了数据完整帧接收,以上代码分享交流下,看看各位有没有更好的办法,继续优化
目前的办法是:中断接收GPS数据,后台开一个定时器来判断数据完整帧的结束
TIM_TimeBaseStructure.TIM_Prescaler = 150;这里会影响到数据完整帧的判断,如果开的过小,比如2ms- 100ms检查一次
我这边每一帧数据中(286 byte以上),总是会丢掉2个字节,而且丢掉的字节都相同位置的
比如完整帧如下:
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,00*79
$GPGLL,,,,,,V,N*64
接收到的时候是:
$RMC,,V,,,,,,,,,,N*53    丢掉两个字节
$GPVTG,,,,,,,,,N*30
$GPGSV,1,1,00*79
$GPGLL,,,,,,V,N*64
实在找不到具体是什么原因,只能更改定时器检测时间 TIM_TimeBaseStructure.TIM_Prescaler = 150;
大概1500ms检测一次就不会丢字节,已知GPS是每秒发送一帧数据
Leeone 发表于 2014-6-23 17:32 | 显示全部楼层
意思就是接收不定长度的数据吧,这个论坛上讨论过不少方法,可以用定时器做超时判断或者用空闲中断去处理,你可以搜下
mmuuss586 发表于 2014-6-23 19:58 | 显示全部楼层
你可以在中断程序加个判断是否大于250,在弄个变量;
大于250个后,变量置1,主程序判断变量值;
 楼主| cepoly 发表于 2014-6-23 20:14 | 显示全部楼层
意思就是接收不定长度的数据吧,这个论坛上讨论过不少方法,可以用定时器做超时判断或者用空闲中断去处理, ...
我先试一下  开个定时器来检测字节与字节之间的超时,看看效果
 楼主| cepoly 发表于 2014-6-23 20:18 | 显示全部楼层
谢谢版主的回答
这样处理办法不是很理想,由于GPS的数据长度与卫星信号强弱有关系
250只是我估计的值,我看到论坛上说可以有中断空闲处理,但我不知道怎么应用
ar_m_cu 发表于 2014-6-23 22:43 | 显示全部楼层
为什么一定要有结束标志呢,开个缓冲区,收到数据就往里面扔。处理的时候,从缓冲区读出来处理,缓冲区有数据就可以处理。当然,一定要有结束标志的话,可以用一个定时器判断串口空闲时间,大于一定值就可以认为接收结束。
 楼主| cepoly 发表于 2014-7-2 19:21 | 显示全部楼层
为什么一定要有结束标志呢,开个缓冲区,收到数据就往里面扔。处理的时候,从缓冲区读出来处理,缓冲区有数 ...
嗯  谢谢
SLHSu37 发表于 2014-7-3 08:33 | 显示全部楼层
个人感觉用IDLE中断就可以
东风小黑 发表于 2014-9-16 22:32 | 显示全部楼层
学习了
diweo 发表于 2014-9-17 21:50 | 显示全部楼层
STM32F030的USART有timeout功能的,设置RTOR寄存器,超过一定时间后就可以产生中断。
