[PIC®/AVR®/dsPIC®产品] 哪位高手有PIC的NOKIA 5110 LCD的驱动,能否共享一下?
2298|1
 楼主| haorenyigea 发表于 2014-6-30 14:09 | 显示全部楼层 |阅读模式
以下是我写的 一直点不亮啊,用IO模拟SPI
#include "pic.h"
#include "htc.h"
__CONFIG(FOSC_INTOSC&CLKOUTEN_OFF&MCLRE_ON&WDTE_OFF);//&PWRTE_ON&BOREN_ON
#define _XTAL_FREQ      4000000L            //内部4MHz
#define uint unsigned int
#define uchar unsigned char
#define SCLK RD4
#define SDIN RD3
#define LCD_DC RD2
#define LCD_CE RD1
#define LCD_RST RD0
#define LCD_BL RD5
void System_Init(void);
void LCD_init(void);
void LCD_clear(void);
void LCD_move_chinese_string(uchar X, uchar Y, uchar T);
void LCD_write_english_string(uchar X,uchar Y,const char *s);
void LCD_write_chinese_string(uchar X, uchar Y,
                   uchar ch_with,uchar num,
                   uchar line,uchar row);
void chinese_string(uchar X, uchar Y, uchar T);
void LCD_write_char(uchar c);
void LCD_draw_bmp_pixel(uchar X,uchar Y,uchar *map,
                  uchar Pix_x,uchar Pix_y);
void LCD_write_byte(uchar dat, uchar dc);
void LCD_set_XY(uchar X, uchar Y);
/*void delay_1us(void);      */
//                          系统初始化
        OSCCON = 0b01101000;            //内部4MHz
        OSCTUNE= 0b00000000;            //出厂校准
        TRISA  = 0b00000000;            //RA0-RA3输出、RA5输入
        ANSELA = 0b00000000;            //RA5 模拟输入
        TRISB  = 0b00001111;            //RB0-RB3触摸按键
        ANSELB = 0b00000000;            //4个触摸按键
        WPUB   = 0b00000000;            //无上拉
        IOCBP  = 0b00000000;            //关电平变化中断
        IOCBN  = 0b00000000;
        TRISD  = 0b00000000;            //PORTD输出
        ANSELD = 0b00000000;            //数字  I/O
        TRISC  = 0b10011000;            //串口 I2C
        TRISE  = 0b00000000;            //PORTE输出
        ANSELE = 0b00000000;            //数字  I/O
        WPUE   = 0b00000000;            //无上拉
//                             主函数
void main(void)
        LCD_init(); //初始化液晶
        LCD_clear();
        while(1)
                LCD_write_english_string(0,0," Welcome to  ");
                LCD_write_english_string(0,1," Amy  studio ");
                LCD_write_english_string(0,2,"amy-studio.com");
                LCD_write_english_string(0,3," Nokia5110 LCD");
                LCD_write_chinese_string(12,4,12,4,0,5);
//                             nokia_5110函数
// 6 x 8 font
// 1 pixel space at left and bottom
// index = ASCII - 32
unsigned char font6x8[][6] =
    { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },   // sp
    { 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
    { 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
    { 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
unsigned char write_chinese[][24]={
//测
        {0x89,0xF2,0x00,0xFF,0x01,0xF9,0xFF,0x00,0xFC,0x00,0xFF,0x00,0x00,0x07,0x04,0x04,0x02,0x01,0x02,0x04,0x01,0x04,0x07,0x00},
//试
        {0x11,0xF6,0x00,0x04,0x24,0xE4,0x24,0x24,0xFF,0x05,0x06,0x00,0x00,0x07,0x02,0x01,0x02,0x03,0x01,0x01,0x01,0x02,0x07,0x00},
//程
        {0x8A,0x6A,0xFF,0x49,0x20,0xAF,0xA9,0xE9,0xA9,0xAF,0x20,0x00,0x01,0x00,0x07,0x00,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x00},
//序
        {0x00,0xFE,0x42,0x4A,0x4A,0x5B,0xEA,0x5A,0x4A,0xC2,0x42,0x00,0x06,0x01,0x00,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x00},
//电
        {0x00,0xFC,0x94,0x94,0x94,0xFF,0x94,0x94,0x94,0xFE,0x04,0x00,0x00,0x01,0x00,0x00,0x00,0x03,0x04,0x04,0x04,0x04,0x06,0x00},
//子
        {0x20,0x21,0x21,0x21,0x21,0xF9,0x29,0x25,0x23,0x31,0x20,0x00,0x00,0x00,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x00,0x00},
//制
        {0x18,0xD6,0x54,0xFF,0x54,0x56,0xD4,0x00,0xFC,0x00,0xFF,0x00,0x00,0x03,0x00,0x07,0x00,0x02,0x03,0x00,0x04,0x04,0x07,0x00},
//作
        {0x10,0x08,0xFC,0x13,0x08,0x04,0xFF,0x24,0x24,0x24,0x04,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x07,0x01,0x01,0x01,0x01,0x00},
//杂
        {0x40,0x62,0x52,0xCA,0x47,0xE2,0x42,0xDE,0x50,0x50,0x58,0x00,0x04,0x02,0x01,0x04,0x04,0x07,0x00,0x00,0x01,0x02,0x04,0x00},
//志
        {0x04,0xA4,0x24,0xA4,0x24,0xBF,0x24,0x24,0x24,0xA6,0x04,0x00,0x02,0x01,0x00,0x07,0x04,0x04,0x05,0x04,0x06,0x00,0x03,0x00},
//社
        {0x84,0x44,0xF5,0x2E,0x40,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,0x00,0x00,0x07,0x00,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x00},
LCD_init          : 3310LCD初始化
编写日期          :2004-8-10
最后修改日期      :2004-8-10
/*void delay_1us(void)                 //1us延时函数
   unsigned int i;
  for(i=0;i<1000;i++);
  void delay_1ms(void)                 //1ms延时函数
   unsigned int i;
   for (i=0;i<1140;i++);
void delay_nms(unsigned int n)       //N ms延时函数
   unsigned int i=0;
   for (i=0;i<n;i++)
   delay_1ms();
void LCD_init(void)
            // 产生一个让LCD复位的低电平脉冲
   LCD_RST = 0;
    __delay_us(1);
   LCD_RST = 1;
                // 关闭LCD
   LCD_CE = 0;
    __delay_us(1);
                // 使能LCD
   LCD_CE = 1;
    __delay_us(1);
    LCD_write_byte(0x21, 0);        // 使用扩展命令设置LCD模式
    LCD_write_byte(0xc8, 0);        // 设置偏置电压
    LCD_write_byte(0x06, 0);        // 温度校正
    LCD_write_byte(0x13, 0);        // 1:48
    LCD_write_byte(0x20, 0);        // 使用基本命令
    LCD_clear();                // 清屏
    LCD_write_byte(0x0c, 0);        // 设定显示模式,正常显示
           // 关闭LCD
   LCD_CE = 0;
LCD_clear         : LCD清屏函数
编写日期          :2004-8-10
最后修改日期      :2004-8-10
    unsigned int i;
    LCD_write_byte(0x80, 0);
    for (i=0; i<504; i++)
      LCD_write_byte(0, 1);
LCD_set_XY        : 设置LCD坐标函数
输入参数:X       :0-83
          Y       :0-5
编写日期          :2004-8-10
最后修改日期      :2004-8-10
void LCD_set_XY(unsigned char X, unsigned char Y)
    LCD_write_byte(0x40 | Y, 0);                // column
    LCD_write_byte(0x80 | X, 0);                  // row
LCD_write_char    : 显示英文字符
输入参数:c       :显示的字符;
编写日期          :2004-8-10
最后修改日期      :2004-8-10
void LCD_write_char(unsigned char c)
    unsigned char line;
    c -= 32;
    for (line=0; line<6; line++)
      LCD_write_byte(font6x8[c][line], 1);
LCD_write_english_String  : 英文字符串显示函数
输入参数:*s      :英文字符串指针;
          X、Y    : 显示字符串的位置,x 0-83 ,y 0-5
编写日期          :2004-8-10
最后修改日期      :2004-8-10
void LCD_write_english_string(unsigned char X,unsigned char Y,const char *s)
    LCD_set_XY(X,Y);
    while (*s)
         LCD_write_char(*s);
         s++;
LCD_write_chinese_string: 在LCD上显示汉字
输入参数:X、Y    :显示汉字的起始X、Y坐标;
          ch_with :汉字点阵的宽度
          num     :显示汉字的个数;
          line    :汉字点阵数组中的起始行数
          row     :汉字显示的行间距
编写日期          :2004-8-11
最后修改日期      :2004-8-12
测试:
        LCD_write_chi(0,0,12,7,0,0);
        LCD_write_chi(0,2,12,7,0,0);
        LCD_write_chi(0,4,12,7,0,0);
void LCD_write_chinese_string(unsigned char X, unsigned char Y,
                   unsigned char ch_with,unsigned char num,
                   unsigned char line,unsigned char row)
    unsigned char i,n;
    LCD_set_XY(X,Y);                             //设置初始位置
    for (i=0;i<num;)
              for (n=0; n<ch_with*2; n++)              //写一个汉字
                  if (n==ch_with)                      //写汉字的下半部分
                      if (i==0) LCD_set_XY(X,Y+1);
                      else
                         LCD_set_XY((X+(ch_with+row)*i),Y+1);
                  LCD_write_byte(write_chinese[line+i][n],1);
              i++;
              LCD_set_XY((X+(ch_with+row)*i),Y);
LCD_draw_map      : 位图绘制函数
输入参数:X、Y    :位图绘制的起始X、Y坐标;
          *map    :位图点阵数据;
          Pix_x   :位图像素(长)
          Pix_y   :位图像素(宽)
编写日期          :2004-8-13
最后修改日期      :2004-8-13
void LCD_draw_bmp_pixel(unsigned char X,unsigned char Y,unsigned char *map,
                  unsigned char Pix_x,unsigned char Pix_y)
    unsigned int i,n;
    unsigned char row;
    if (Pix_y%8==0) row=Pix_y/8;      //计算位图所占行数
      else
        row=Pix_y/8+1;
    for (n=0;n<row;n++)
              LCD_set_XY(X,Y);
        for(i=0; i<Pix_x; i++)
            LCD_write_byte(map[i+n*Pix_x], 1);
        Y++;                         //换行
LCD_write_byte    : 使用SPI接口写数据到LCD
输入参数:data    :写入的数据;
          command :写数据/命令选择;
编写日期          :2004-8-10
最后修改日期      :2004-8-13
void LCD_write_byte(unsigned char dat, unsigned char command)
    unsigned char i;
    //PORTB &= ~LCD_CE ;                        // 使能LCD
    LCD_CE = 0;
    if (command == 0)
     // PORTB &= ~LCD_DC ;                // 传送命令
     LCD_DC = 0;
    else
     // PORTB |= LCD_DC ;                        // 传送数据
     LCD_DC = 1;
                for(i=0;i<8;i++)
                        if(dat&0x80)
                                SDIN = 1;
                        else
                                SDIN = 0;
                        SCLK = 0;
                        dat = dat << 1;
                        SCLK = 1;
   // SPDR = data;                        // 传送数据到SPI寄存器
    //while ((SPSR & 0x80) == 0);         // 等待数据传送完毕
    //PORTB |= LCD_CE ;                        // 关闭LCD
     LCD_CE = 1;
aeqw 发表于 2014-7-2 12:06 | 显示全部楼层
乍看之下跟我用的差不多哩...
是不是少了ascii的表可以查?
LCD_write_byte(font6x8[c][line], 1); <--這邊的font6x8
宣告只有
你要顯示的字都沒有喔!!
