[STM8] STM8L的外部中断死循环问题
1641|0
 楼主| asd046012 发表于 2014-7-7 10:24 | 显示全部楼层 |阅读模式
我想起用外部中断0和外部中断6。经过我的设置,程序总是在外部中断6的服务程序里运行。PC6的电平一直是低电平。下面是我的设置:
I/O口设置:
void CC113L_SPI_GPIOInit(void)
  GPIO_Init(GPIOD, GPIO_Pin_0, GPIO_Mode_In_FL_IT);             //GDO0       外部中断0
  GPIO_Init(GPIOB, GPIO_Pin_5, GPIO_Mode_Out_PP_Low_Slow);        //SCK
  GPIO_Init(GPIOA, GPIO_Pin_3, GPIO_Mode_Out_PP_Low_Slow);        //MOSI
  GPIO_Init(GPIOA, GPIO_Pin_2, GPIO_Mode_In_PU_No_IT);            //MISO
  GPIO_Init(GPIOC, GPIO_Pin_4, GPIO_Mode_Out_PP_Low_Slow);        //CSN
GPIO_Init(GPIOC, GPIO_Pin_5, GPIO_Mode_In_FL_No_IT);
void USART_GpioInit(void)
        GPIO_Init(GPIOC, GPIO_Pin_6, GPIO_Mode_In_FL_IT);         //外部中断6
        GPIO_Init(GPIOC, GPIO_Pin_0, GPIO_Mode_Out_PP_High_Slow);     //PC0
void EXIT_Init(void)
        EXTI_DeInit();
        EXTI_SetPinSensitivity(GPIO_Pin_0,EXTI_Trigger_Rising);
        EXTI_SetPinSensitivity(GPIO_Pin_6,EXTI_Trigger_Falling);
        ITC_SetSoftwarePriority(EXTI6_IRQn,ITC_PriorityLevel_3);
        ITC_SetSoftwarePriority(EXTI0_IRQn,ITC_PriorityLevel_2);
        EXTI_ClearITPendingBit(EXTI_IT_Pin6);
        EXTI_ClearITPendingBit(EXTI_IT_Pin0);
        enableInterrupts();
下面是Vector.c里的设置:
#include "stm8l15x_it.h"
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
extern void _stext();     /* startup routine */
extern void EXTI0_IRQHandler(void);
extern void EXTI6_IRQHandler(void);
struct interrupt_vector const _vectab[] = {
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, EXTI0_IRQHandler}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, NonHandledInterrupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, EXTI6_IRQHandler}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
外部中断6的服务程序:
@far @interrupt void EXTI6_IRQHandler(void)
    /* In order to detect unexpected events during development,
       it is recommended to set a breakpoint on the following instruction.
        time_ok = 1;
        sleep_ok = 1;
