/* --- STC MCU International Limited -------------------------------*/
/* --- STC 1T Series MCU RC Demo -----------------------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-755-82944243 ----------------------------------------*/
/* --- Tel: 86-755-82948412 ----------------------------------------*/
/* --- Web: www.**.com -----------------------------------------*/
/* If you want to use the program or the program referenced in the */
/* article, please specify in which data and procedures from STC */
测试方法:
根据您的主时钟和波特率修改下面的相关定义,编译后下载到MCU。
通过串口助手向MCU发送数据,MCU收到后原样返回。
#include <reg51.h>
sfr AUXR = 0x8E;
sfr BRT = 0x9C;
#define BUF_LENTH 128 //定义串口接收缓冲长度
unsigned char uart0_wr; //写指针
unsigned char uart0_rd; //读指针
unsigned char xdata RX0_Buffer[BUF_LENTH]; //接收缓冲
bit B_TI;
void uart0_init(void);
/*************** 用户定义参数 *****************************/
#define MAIN_Fosc 22118400UL //define main clock
#define Baudrate0 9600UL //define the baudrate,
//12T mode: 600~115200 for 22.1184MHZ, 300~57600 for 11.0592MHZ
//1T mode: 7200~1382400 for 22.1184MHZ, 3600~691200 for 11.0592MHZ
/****************** 编译器自动生成,用户请勿修改 ************************************/
#define BRT_Reload (256 - MAIN_Fosc / 16 / Baudrate0) //Calculate the timer1 reload value ar 1T mode
void main(void)
uart0_init();
while(1)
if(uart0_rd != uart0_wr) //串口转发
B_TI = 0;
SBUF = RX0_Buffer[uart0_rd];
while(!B_TI) ;
B_TI = 0;
if(++uart0_rd >= BUF_LENTH) uart0_rd = 0;
PCON |= 0x80; //UART0 Double Rate Enable
SCON = 0x50; //UART0 set as 10bit , UART0 RX enable
AUXR |= 0x01; //UART0 使用BRT
AUXR |= 0x04; //BRT set as 1T mode
BRT = BRT_Reload;
AUXR |= 0x10; //start BRT
ES = 1;
EA = 1;
void UART0_RCV (void) interrupt 4
if(RI)
RI = 0;
RX0_Buffer[uart0_wr] = SBUF;
if(++uart0_wr >= BUF_LENTH) uart0_wr = 0;
if(TI)
TI = 0;
B_TI = 1;
