 6.5 建立工程
 建立一个应用,简单地进入应用工程文件夹(/gcc folder)并且键入make.
 例如:AT32UC3A0512 GPIO 接口总线例子在Atmel EVK1100开发板上,键入make在avr32/drivers/gpio/peripheral_bus_example/at32uc3a0512_evk1100/gcc文件夹下:
 将有如下结果:
 $ make
 MKDIR avr32/drivers/intc/
 CC avr32/drivers/intc/intc.o
 MKDIR avr32/drivers/gpio/
 CC avr32/drivers/gpio/gpio.o
 MKDIR avr32/drivers/gpio/peripheral_bus_example/
 CC avr32/drivers/gpio/peripheral_bus_example/gpio_periphe
 MKDIR avr32/utils/startup/
 AS avr32/utils/startup/startup_uc3.o
 AS avr32/utils/startup/trampoline_uc3.o
 AS avr32/drivers/intc/exception.o
 LN avr32_drivers_gpio_peripheral_bus_example_evk1100.elf
 SIZE avr32_drivers_gpio_peripheral_bus_example_evk1100.elf
 avr32_drivers_gpio_peripheral_bus_example_evk1100.elf :
 section size addr
 .reset 0x2004 0x80000000
 .text 0x134 0x80002004
 .exception 0x200 0x80002200
 .rodata 0xa0 0x80002400
 .dalign 0x4 0x4
 .bss 0xf0 0x8
 .heap 0xef08 0xf8
 .comment 0x30 0x0
 .debug_aranges 0x158 0x0
 .debug_pubnames 0x3ad 0x0
 .debug_info 0x11ca 0x0
 .debug_abbrev 0x554 0x0
 .debug_line 0x1b6f 0x0
 .debug_frame 0x294 0x0
 .debug_loc 0x408 0x0
 .debug_macinfo 0x2b7053 0x0
 .stack 0x1000 0xf000
 .debug_ranges 0x170 0x0
 Total 0x2cdce5
 text data bss dec hex filename
 0x23d8 0x0 0xfffc 74708 123d4 avr32_drivers_gpio_per
 e_evk1100.elf
 OBJDUMP avr32_drivers_gpio_peripheral_bus_example_evk1100.lss
 NM avr32_drivers_gpio_peripheral_bus_example_evk1100.sym
 OBJCOPY avr32_drivers_gpio_peripheral_bus_example_evk1100.hex
 OBJCOPY avr32_drivers_gpio_peripheral_bus_example_evk1100.bin
 The result of the build is located in the same folder as the makefile location:
 • Elf file (.elf)
 • Listing file (.lss)
 • Symbol file (.sym)
 • Hex file (.hex)
 • Binary file (.bin)
