[C语言] 求一程序
2075|6
 楼主| 微笛 发表于 2014-8-12 18:48 | 显示全部楼层 |阅读模式
主程序://set pll out freq 1529mhz using HMC830 hmc mode
#include "hmc830.h"
#include "pic16F688_reg.h"
//#fuses INTRC_IO,NOWDT,NOPROTECT,NOBROWNOUT,MCLR,NOCPD,NOPUT,NOIESO,NOFCMEN,BROWNOUT_NOSL
#use fast_io(C)
#BIT  PLL_SEN  = PORTC.2
#BIT  PLL_SCK  = PORTA.2
#BIT  PLL_SDI = PORTC.0
#BIT  LD_SDD = PORTC.3
void delay (int length)
        while (length >0)
            length--;
void WriteToHMC830(unsigned char count, unsigned char buf0,unsigned char buf1,unsigned char buf2,unsigned char buf3)
        unsigned        char        ValueToWrite = 0;
    unsigned        char        i = 0;
        unsigned        char        j = 0;
        delay(1);
        PLL_SCK=0;
        PLL_SEN=0;
        delay(1);
        PLL_SEN=1;
        PLL_SDI=0;
        delay(1);
        PLL_SCK=1;
        delay(1);
        PLL_SCK=0;
        for(i=0;i<count;i++)
                if (i==0)
                 ValueToWrite = buf0;
                if (i==1)
                 ValueToWrite = buf1;
                if (i==2)
                 ValueToWrite = buf2;
                if (i==3)
                 ValueToWrite = buf3;
                 if(i == 0)
                        ValueToWrite <<= 2;
                  for(j=0; j<6; j++)
                        if(0x80 == (ValueToWrite & 0x80))
                                PLL_SDI=1;
                        else
                                PLL_SDI=0;
                        delay(1);
                        PLL_SCK=1;
                        delay(1);
                        ValueToWrite <<= 1;
                        PLL_SCK=0;
    else
                for(j=0; j<8; j++)
                                PLL_SDI=1;
                        else
                                PLL_SDI=0;
                        delay(1);
                        PLL_SCK=1;
                        delay(1);
                        ValueToWrite <<= 1;
                        PLL_SCK=0;
        delay(1);
        PLL_SCK=1;
        delay(1);
        PLL_SCK=0;
        delay(1);
        PLL_SEN=0;
        delay(1);
//#ZERO_RAM
void main()
    OSCCON = 0x47;
    OSCTUNE = 0x00;
    OPTION = 0;
    ANSEL = 0x00;
    TRISA = 0x00;
    TRISC = 0x08;
    CMCON0= 0x07;
          delay_ms(50);
//Reference frequency: 10MHz;Output frequency: 1252MHz; interger mode
do{
        WriteToHMC830(4,0x00,0x00,0x00,0x20);
  WriteToHMC830(4,0x00,0x00,0x00,0x00);
        delay(1);
        WriteToHMC830(4,0x01,0x00,0x00,0x02);   //
        WriteToHMC830(4,0x02,0x00,0x00,0x0A);   // Reference Divider R=10=Ah              ****change
        WriteToHMC830(4,0x05,0x00,0xC0,0x90);   // Biases -3dB,fo/1                       ****change
        WriteToHMC830(4,0x05,0x00,0x28,0x18);   // Buffer autoRFO mode,diff out
        WriteToHMC830(4,0x05,0x00,0x00,0x00);   // VCO SPI
        WriteToHMC830(4,0x06,0x20,0x03,0xCA);   // SD CFG, set Integer mode, mode B
        WriteToHMC830(4,0x07,0x00,0x0A,0xCD);   // Lock Detect
        WriteToHMC830(4,0x08,0xC1,0xBE,0xFF);   // Analog EN
        WriteToHMC830(4,0x09,0x00,0x3F,0xFF);   // Charge Pump 2.54mA, offset off
        WriteToHMC830(4,0x0A,0x00,0x20,0x46);   // VCO AutoCal Cfg
        WriteToHMC830(4,0x0B,0x07,0xC0,0x61);   // PD
        WriteToHMC830(4,0x0F,0x00,0x00,0xC1);   // SDO as Lock Detect Output
        WriteToHMC830(4,0x03,0x00,0x05,0xF9);   // VCO divider Integer part 1529/1=5F9h   ****change
        delay_ms(100);
  } while (LD_SDD==0);
求给此程序加一功能模块,,
现有一开发板,想在上面加一LED灯,使得程序烧进去单片机以后灯亮        求高手!!!
coody 发表于 2014-8-12 20:36 | 显示全部楼层
坐等 看高手加程序点亮LED
 楼主| 微笛 发表于 2014-8-13 08:56 来自手机 | 显示全部楼层
高手在哪里、、、
高手在哪里、、、
很忙 发表于 2014-8-13 13:50 | 显示全部楼层
看不明白。
xbyu520 发表于 2014-8-14 10:56 | 显示全部楼层
什么型号的单片机?发这么多程序,一点注释都不加吗?
萧十一郎hot 发表于 2014-10-31 20:48 | 显示全部楼层
确实,没一点注释。
