No source available for "0x3ff6c4"
1571|4
 楼主| 4027379 发表于 2014-8-12 22:33 | 显示全部楼层 |阅读模式
这是什么错误呢? 程序就跑进死循环了
hitbuyi1 发表于 2014-8-16 20:14 | 显示全部楼层
zhangmangui 发表于 2014-8-17 00:03 | 显示全部楼层
同问
错误是什么时候提示的   如Connect to Device等    下面是一些分析 供你参考
The No Source Available typically means that 1.) You have a program loaded  2.) You're in that program space when you're executing. 3.) The symbol table has tried to associate it with a file name, but there's no associated file found within your project, or where it's searching from within the project.
评分
参与人数 1威望 +3 收起 理由
4027379 + 3
查看全部评分
 楼主| 4027379 发表于 2014-8-25 09:58 | 显示全部楼层
解决了是供电的问题!
zhangmangui 发表于 2014-8-25 22:16 | 显示全部楼层
解决了是供电的问题!
是供电问题吗 ??
详细说明一下 啊
