C++中的虚函数及其实现+代码
2035|5
 楼主| keer_zu 发表于 2014-8-26 17:28 | 显示全部楼层 |阅读模式
最近在做流媒体的应用,用的苹果的Darwin Streaming Server做二次开发,恶补一下C++。多态是C++的精髓。
C++中的虚函数是实现多态性的重要手段,它是通过虚函数表来实现的,虚函数表放在类的首地址位置,具体为:
*(int*)(&b) :其中b为一个类的实例(对象);
下面写的是对上面做出直观诠释的代码:
#include <iostream>
//单继承
class Base {
        public:
        int a,b,c;
        virtual void f() { std::cout << "Base::f" << std::endl; }
        virtual void g() { std::cout << "Base::g" <<std::endl; }
        virtual void h() { std::cout << "Base::h" << std::endl; }
class Derive:public Base
        public:
        virtual void f0() { std::cout << "Base::f0" << std::endl; }
        virtual void g0() { std::cout << "Base::g0" <<std::endl; }
        virtual void h0() { std::cout << "Base::h0" << std::endl; }
class Derive1:public Base
        public:
        virtual void f() { std::cout << "Base::f1" << std::endl; }
        virtual void g() { std::cout << "Base::g1" <<std::endl; }
        virtual void h() { std::cout << "Base::h1" << std::endl; }
//多继承的例子:
class Base1{
        public:
        int a,b,c;
        virtual void f() { std::cout << "Base1::f" << std::endl; }
        virtual void g() { std::cout << "Base1::g" <<std::endl; }
        virtual void h() { std::cout << "Base1::h" << std::endl; }
class Base2{
        public:
        int a,b,c;
        virtual void f() { std::cout << "Base2::f" << std::endl; }
        virtual void g() { std::cout << "Base2::g" <<std::endl; }
        virtual void h() { std::cout << "Base2::h" << std::endl; }
class Base3{
        public:
        int a,b,c;
        virtual void f() { std::cout << "Base3::f" << std::endl; }
        virtual void g() { std::cout << "Base3::g" <<std::endl; }
        virtual void h() { std::cout << "Base3::h" << std::endl; }
class DeriveMulti:public Base1,public Base2,public Base3
        virtual void f() { std::cout << "DeriveMulti::f" << std::endl; }
//        virtual void g() { std::cout << "DeriveMulti::g" <<std::endl; }
//        virtual void h() { std::cout << "DeriveMulti::h" << std::endl; }
        virtual void mm() { std::cout << "DeriveMulti::mm" << std::endl; }
typedef void(*Fun)(void);
int main(void)
        Base b;
        Derive d;
        Derive1 d1;
        Fun pFun = NULL;
        Base *pb;
        Base1 *pb1;
        Base2 *pb2;
        Base3 *pb3;
        DeriveMulti *pdm;
        std::cout <<"\n\n@@@@ Base TEST @@@@@" << std::endl;
        std::cout << "虚函数表地址:" << *(int*)(&b) << std::endl;
        std::cout << "虚函数表 — 第一个函数地址:" << *(int*)*(int*)(&b) << std::endl;
        pFun = (Fun)*((int*)*(int*)(&b));
        pFun();
        pFun = (Fun)*((int*)*(int*)(&b)+2); // Base::g()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&b)+4); // Base::h()
        pFun();
        b.f();
        b.g();
        b.h();
        std::cout <<"\n\n@@@@ Dervie TEST @@@@@" << std::endl;
        std::cout << "虚函数表地址:" << *(int*)(&d) << std::endl;
        std::cout << "虚函数表 — 第一个函数地址:" << *(int*)*(int*)(&d) << std::endl;
        pFun = (Fun)*((int*)*(int*)(&d));
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d)+2); // Base::g()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d)+4); // Base::h()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d)+6); // Base::g()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d)+8); // Base::h()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d)+10); // Base::g()
        pFun();
        d.f();
        d.g();
        d.h();
        d.f0();
        d.g0();
        d.h0();
        std::cout <<"\n\n@@@@ Dervie 1 TEST @@@@@" << std::endl;
        std::cout << "虚函数表地址:" << *(int*)(&d1) << std::endl;
        std::cout << "虚函数表 — 第一个函数地址:" << *(int*)*(int*)(&d1) << std::endl;
        pFun = (Fun)*((int*)*(int*)(&d1));
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d1)+2); // Base::g()
        pFun();
        pFun = (Fun)*((int*)*(int*)(&d1)+4); // Base::h()
        pFun();
        d1.f();
        d1.g();
        d1.h();
        std::cout <<"\n\n@@@@ Base pointer TEST @@@@@" << std::endl;
        pb = &b;
        pb->f();
        pb->g();
        pb->h();
        pb = &d;
        pb->f();
        pb->g();
        pb->h();
        pb = &d1;
        pb->f();
        pb->g();
        pb->h();
        std::cout <<"\n\n@@@@  multiple inheritance TEST @@@@@" << std::endl;
        pdm = new DeriveMulti();
        pb1 = pdm;
        pb1->f();
        pb1->g();
        pb1->h();
        pb2=pdm;
        pb2->f();
        pb2->g();
        pb2->h();
        pb3=pdm;
        pb3->f();
        pb3->g();
        pb3->h();
        return 0;
 楼主| keer_zu 发表于 2014-8-26 17:29 | 显示全部楼层
在linux下编译,运行结果为:
虚函数表地址:4200656
虚函数表 — 第一个函数地址:4198364
Base::f
Base::g
Base::h
Base::f
Base::g
Base::h
虚函数表地址:4200592
Base::f
Base::g
Base::h
Base::f0
Base::g0
Base::h0
Base::f
Base::g
Base::h
Base::f0
Base::g0
Base::h0
虚函数表地址:4200528
虚函数表 — 第一个函数地址:4198616
Base::f1
Base::g1
Base::h1
Base::f1
Base::g1
Base::h1
Base::f
Base::g
Base::h
Base::f
Base::g
Base::h
Base::f1
Base::g1
Base::h1
DeriveMulti::f
Base1::g
Base1::h
DeriveMulti::f
Base2::g
Base2::h
DeriveMulti::f
Base3::g
Base3::h
 楼主| keer_zu 发表于 2014-8-27 11:05 | 显示全部楼层
第一个函数地址: *(int*)*(int*)(&d)
感觉到指针在C++中的表现了吗?
 楼主| keer_zu 发表于 2014-8-27 15:42 | 显示全部楼层
Darwin streaming server里面事件和任务交互的类图。
warfid 发表于 2014-8-30 16:07 | 显示全部楼层
哥你写个注释呀,哥你写个注释呀!
 楼主| keer_zu 发表于 2014-9-1 09:24 | 显示全部楼层
哥你写个注释呀
把上面程序编译、调试一下就什么都明白了。注释实在是不需要啊
1497
