[运放]
【秀出我的 Linear模拟设计方案】+ LT1358
1219|0
Linear公司的运算放大器,种类虽没有ADIMAXIM那么多,但也有自己的特点,大概分为Precision AmplifiersLow Bias Current AmplifiersLow Power AmplifiersSpeed  Precision AmplifiersInstrumentation AmplifiersPGAs and Difference AmplifiersCurrent Sense Amplifiers等。总有一款适合你应用的产品。
用过一款放大器LT1358,根据datasheet做过一个四阶宽带滤波器。PCB如下图
LT1358,其特点:
l         25MHz Gain-Bandwidth
l         600V/µs Slew Rate
l         2.5mA Maximum Supply Current per Amplifier
l         Unity Gain Stable
l         C-Load™ Op Amp Drives All Capacitive Loads
l         8nV/rt Hz Input Noise Voltage
l         600µV Maximum Input Offset Voltage
l         500nA Maximum Input Bias Current
l         120nA Maximum Input Offset Current
l         20V/mV Minimum DC Gain, RL =1k
l         115ns Settling Time to 0.1%, 10V Step
l         220ns Settling Time to 0.01%, 10V Step
l         ±12.5V Minimum Output Swing into 500 ohms
l         ±3V Minimum Output Swing into 150 ohms
l         Specified at ±2.5V, ±5V, and ±15V
应用于:
l         Wideband Amplifiers
l         Buffers
l         Active Filters
l         Data Acquisition Systems
l         Photodiode Amplifiers
LT1358.pdf (477.89 KB)
个人签名:有阳光就灿烂,有知识就高兴!!
114
