[CAN/LIN/FlexRay收发器]
使用LPC11C14FBD48/301的CAN与STM32的CAN通信的问题
1875|0
wang12zhe|  楼主 | 2014-9-5 15:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用LPC11C14FBD48/301的CAN与STM32的CAN通信,
我首先使用两块STM32试验,完成两块STM32在500k通信速率下的正常通信
然后设置LPC11C14FBD48/301的CAN,由于对LPC单片机不是特别熟悉,
一直没能实现LPC11C14FBD48/301与STM32的正常通信。
LPC11C14FBD48/301的CAN初始化过程如下
#define USE_DEFAULT_BIT_TIMING  1
#define TRANSMIT_ONLY           0
#define POLLING                 0
#define LOOPBACK_MODE           0
#define BASIC_MODE              1
** Function name:                CAN_Init
** Descriptions:                CAN clock, port initialization
** parameters:                        None
** Returned value:                None
void CAN_Init( uint32_t CANBitClk )
  LPC_SYSCON->PRESETCTRL |= (0x1<<3);  //C_CAN 复位无效
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<17);  //允许C_CAN的时钟
  /* The USB D- and CAN RX share the dedicated pin. The USB D+
  and CAN TX share the dedicated pin. so, no IO configuration is
  needed for CAN. */
  if ( !(LPC_CAN->CNTL & CTRL_INIT) )
        /* If it's in normal operation already, stop it, reconfigure
          everything first, then restart. */
          LPC_CAN->CNTL |= CTRL_INIT;                /* Default state */
#if USE_DEFAULT_BIT_TIMING
  /* AHB clock is 48Mhz. The CAN clock divider is within CAN block,
  set it to 8Mhz for now. Thus, default bit timing doesn't need to
  be touched. */
  LPC_CAN->CLKDIV = 0x05;                        /* Divided by 6 */
   /* Start configuring bit timing */
  LPC_CAN->CNTL |= CTRL_CCE; //配置更改允许  ---允许更改
  LPC_CAN->BT = 0x2301;
  LPC_CAN->BRPE = 0x0000;    // 波特率预分频器扩展
  /* Stop configuring bit timing */
  LPC_CAN->CNTL &= ~CTRL_CCE; //配置结束  --禁止更改
#else
  /* Be very careful with this setting because it's related to
  the input bitclock setting value in CANBitClk. */
  /* popular CAN clock setting assuming AHB clock is 48Mhz:
  CLKDIV = 1, CAN clock is 48Mhz/2 = 24Mhz
  CLKDIV = 2, CAN clock is 48Mhz/3 = 16Mhz
  CLKDIV = 3, CAN clock is 48Mhz/4 = 12Mhz
  CLKDIV = 5, CAN clock is 48Mhz/6 = 8Mhz */
  /* AHB clock is 48Mhz, the CAN clock is 1/6 AHB clock = 8Mhz */
  LPC_CAN->BT = CANBitClk;  //0x00000103
#endif
  /* Initialization finishes, normal operation now. */
  LPC_CAN->CNTL &= ~CTRL_INIT; //退出初始化模式。恢复正常模式
  while ( LPC_CAN->CNTL & CTRL_INIT );
#if (LOOPBACK_MODE | BASIC_MODE)
  //  LPC_CAN->CNTL  &= ~ CTRL_TEST;   //正常模式。
    LPC_CAN->CNTL |= CTRL_TEST;
    LPC_CAN->TEST &= ~((0x1<<2)|(0x1<<3)|(0x1<<4));
#if LOOPBACK_MODE
  LPC_CAN->TEST |= (0x1<<4);
#endif
#if BASIC_MODE
  LPC_CAN->TEST |= (0x01<<2);
  LPC_CAN->TEST &= ~ (0x01<<3)|(0x01<<4);
#endif
#endif
#if !BASIC_MODE
  /* Below is a critical module to configure all the messages */
  /* It's organized in such a way that:
            obj(x+1)        standard        receive
            obj(x+2)        standard        transmit
            obj(x+3)        extended        receive
            obj(x+4)        extended        transmit        where x is 0 to 7
            obj31 is not used.
                obj32 is for remote date request test only */
  CAN_ConfigureMessages();
#endif
#if !POLLING
  /* Enable the CAN Interrupt */
  NVIC_EnableIRQ(CAN_IRQn);
  /* By default, auto TX is enabled, enable all related interrupts */
  LPC_CAN->CNTL |= (CTRL_IE|CTRL_SIE|CTRL_EIE);
#endif
  return;
发送函数如下
** Function name:                CAN_Send
** Descriptions:                Send a block of data to the CAN port, the
**                                                first parameter is the message number, the 2nd
**                                                parameter is the received_flag whether it sends received
**                                                data as the TX data field, the third is the pointer to
**                                                the mgs field. When receive_flag is TRUE, the TX msg# is
**                                                RX msg#+1, the TX msg ID is twice of the RX msg ID,
**                                                when received_flag is FALSE, no change in msg#.
** parameters:                        msg #, received_flag, msg buffer pointer
void CAN_Send( uint8_t msg_no, uint8_t received_flag, uint32_t *msg_ptr )
  uint32_t msg_id, tx_id, Length;
  if ( msg_ptr == NULL )
        while( 1 );
  /* first is the ID, second is length, the next four are data */
  msg_id = *msg_ptr++;
  if ( received_flag )
        /* Mask off MsgVal, Xtd, and Dir, then make the TX msg ID twice the RX msg ID. */
        /* the msg id should be no large than half the max. extended ID allowed. */
        tx_id = (msg_id & 0x1FFFFFFF) << 1;
  else
        tx_id = msg_id;
  Length = *msg_ptr++;
  if ( Length > DLC_MAX )
        Length = DLC_MAX;
  if ( !(msg_id & (0x1<<30)) )                /* bit 30 is 0, standard frame */
        /* MsgVal: 1, Mtd: 0, Dir: 1, ID = 0x200 */
        LPC_CAN->IF1_ARB2 = ID_MVAL | ID_DIR | (tx_id << 2);
        LPC_CAN->IF1_ARB1 = 0x0000;
        /* Mxtd: 0, Mdir: 1, Mask is 0x7FF */
        LPC_CAN->IF1_MSK2 = MASK_MDIR | (ID_STD_MASK << 2);
        LPC_CAN->IF1_MSK1 = 0x0000;
  else
        /* MsgVal: 1, Mtd: 1, Dir: 1, ID = 0x200000 */
        LPC_CAN->IF1_ARB2 = ID_MVAL | ID_MTD | ID_DIR | (tx_id >> 16);
        LPC_CAN->IF1_ARB1 = tx_id & 0x0000FFFF;
        /* Mxtd: 1, Mdir: 1, Mask is 0x7FF */
        LPC_CAN->IF1_MSK2 = MASK_MXTD | MASK_MDIR | (ID_EXT_MASK >> 16);
        LPC_CAN->IF1_MSK1 = ID_EXT_MASK & 0x0000FFFF;
  LPC_CAN->IF1_MCTRL = UMSK|TXRQ|EOB|(Length & DLC_MASK);
  LPC_CAN->IF1_DA1 = *msg_ptr++;
  LPC_CAN->IF1_DA2 = *msg_ptr++;
  LPC_CAN->IF1_DB1 = *msg_ptr++;
  LPC_CAN->IF1_DB2 = *msg_ptr;
  LPC_CAN->IF1_CMDMSK = WR|MASK|ARB|CTRL|TREQ|DATAA|DATAB;
#if BASIC_MODE
  LPC_CAN->IF1_CMDREQ = IFCREQ_BUSY;
#else
  /* if receive_flag is FALSE, the TX uses the normal message object (msg_no+1)
  for transmit. When received_flag is TRUE, msg_no+1 is the message object for RX,
  TX uses the message object next to RX(msg_no+2) for transmit. */
        LPC_CAN->IF1_CMDREQ = msg_no+2;
  else
        LPC_CAN->IF1_CMDREQ = msg_no+1;
  while( LPC_CAN->IF1_CMDREQ & IFCREQ_BUSY );   /* Could spin here forever */
#endif
  return;
但是一直没有实现通信,求大侠帮助
下面是LPC的源码,
程序V2.0_20140904_1CAN.zip (567.19 KB)
我已经进入正常模式了,但是发送后自己受到,感觉还是在回环模式。
还有个问题,LPC程序使用的是MDK,仿真的时候怎么查看相关的寄存器?
CAN.zip
555.62 KB
