“current-sinking regulator”和“current-sourcing regulator”?
1616|3
 楼主| ElectronF0 发表于 2014-9-12 15:28 | 显示全部楼层 |阅读模式
见下图,请教
这里的“ current-sinking regulator ” 和 “ current-sourcing regulator ”是什么意思 ?
谢谢!
JobShare 发表于 2014-9-12 17:03 | 显示全部楼层
A sink of anything (at least in the information world) is a
destination. So a telephone handset is an audio sink (the earpiece,
anyway - the microphone would be a source).
sink, 是一个目的。因此,电话的耳机,是一个 andio sink(听筒,无论如何,mic会是一个audio 源),
A Bluetooth headset is an audio sink. A hands free kit is an audio sink. [on the earpiece/speaker sides, at least].
蓝牙耳机是一个 audio sink。免提是一个audio sink。
A gateway is a translation, mapping or [re]director (or some mixture of the three) point in a network.
网关是网络中的一个翻译,映射或者定向(重定向)(或者三者混合)的点。
A cell phone with a bluetooth interface (capable of supporting a headset, for instance) is an audio gateway. It takes a GSM signal and formats it suitably for Bluetooth (translation) and provides the connection control to the headset (mapping and redirect).
带有蓝牙接口(例如,支持耳机)的电话,是一个 audio 网关。它拿到GSM信号,并为蓝牙进行适当的格式化(翻译),并为耳机提供链接控制(映射和重定向)。
JobShare 发表于 2014-9-12 17:58 | 显示全部楼层
简单理解, 就是, 谁放(给予), 谁就是 audio source, 谁听(接受), 谁就是 audio sink
评分
参与人数 1威望 +4 收起 理由
ElectronF0 + 4 很给力!
查看全部评分
 楼主| ElectronF0 发表于 2014-9-16 16:37 | 显示全部楼层
学习了,谢谢 !
个人签名:永远的助理工程师
273
