自己建的工程是按照以前建工程的方式来的,结果一直出现
Fatal Error[Pe035]: #error directive: "USB_OTG_HS_CORE or USB_OTG_FS_CORE should be defined" E:\PH\STM32examples\STM32F4-Discovery_FW\Project\Demonstration\usb_conf.h 113
这样的错误。这是之前已经编译通过的程序,过了几天再打开突然出错了,不知道怎么回事,只是实现一个简单的定时器中断程序而已。仿真没有报错,下载到32的时候报错的。求各位相助。- int main()
- SystemInit();//频率设定有system_stm32f4xx.c文件中的宏定义 开放某个宏 当调用SystemInit()时即可设置好频率
- RCC_ClockSecuritySystemCmd(ENABLE);//使能或者失能时钟安全系统
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);//使能或者失能 APB1外设时钟
- nvic_ready();
- // TIM_GPIOConfig();
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_14;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; /*端口模式为输出 */
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- //RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseStructure.TIM_Period = 199;
- TIM_TimeBaseStructure.TIM_Prescaler = 7199;
- TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
- TIM_ClearFlag(TIM4,TIM_FLAG_Update); //必须先清除配置时候产生的更新标志
- TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE); //使能中断,中断事件为定时器更新事件
- TIM_Cmd(TIM4,ENABLE); //使能定时器
- GPIO_SetBits(GPIOD,GPIO_Pin_12);
- GPIO_SetBits(GPIOD,GPIO_Pin_14);
- while(1);
- void TIM4_IRQHandler(void)
- if(TIM_GetITStatus(TIM4,TIM_IT_Update)!=RESET)
- TIM_ClearFlag(TIM4,TIM_FLAG_Update);//进入中断先清除更新标志
- flag++;
- if(flag==50)
- GPIO_ResetBits(GPIOD,GPIO_Pin_12);
- GPIO_ResetBits(GPIOD,GPIO_Pin_14);
- flag=0;
