[STM32F1]
软件延时综合意见贴,大家都贡献一下,都发下靠谱的资源
1142|3
xlsbz|  楼主 | 2014-9-27 18:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
先献丑了
在MDK帮助文档找到两个
(1
xlsbz|  楼主 | 2014-9-27 19:06 | 只看该作者
xlsbz|  楼主 | 2014-9-27 19:46 | 只看该作者
江枫渔火 提供:
//! Provides a small delay.
//! \param ulCount is the number of delay loop iterations to perform.
//! This function provides a means of generating a constant length delay.  It
//! is written in assembly to keep the delay consistent across tool chains,
//! avoiding the need to tune the delay based on the tool chain in use.
//! The loop takes 3 cycles/loop.
//! \return None.
#if defined(ewarm) || defined(DOXYGEN)
void
SysCtlDelay(unsigned long ulCount)
    __asm("    subs    r0, #1\n"
          "    bne.n   SysCtlDelay\n"
          "    bx      lr");
#endif
#if defined(codered) || defined(gcc) || defined(sourcerygxx)
void __attribute__((naked))
          "    bne     SysCtlDelay\n"
          "    bx      lr");
#endif
#if defined(rvmdk) || defined(__ARMCC_VERSION)
__asm void
    subs    r0, #1;
    bne     SysCtlDelay;
    bx      lr;
#endif
// For CCS implement this function in pure assembly.  This prevents the TI
// compiler from doing funny things with the optimizer.
#if defined(ccs)
    __asm("    .sect \".text:SysCtlDelay\"\n"
          "    .clink\n"
          "    .thumbfunc SysCtlDelay\n"
          "    .thumb\n"
          "    .global SysCtlDelay\n"
          "SysCtlDelay:\n"
          "    subs r0, #1\n"
          "    bx lr\n");
#endif sysctl.rar (16.32 KB)
小浣熊| | 2014-9-30 19:46 | 只看该作者
呵呵 不是很懂,希望有高手可以帮到你!!
