[STM32F1]
求助,TIM4通道1用于捕获一路信号频率,通道2用于捕获另一路信号高电平宽度
1765|8
sallychen|  楼主 | 2014-10-17 14:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
菜鸟一枚,用stm32f103同时捕获两路信号的频率和高电平宽度时,频率不对,脉冲宽度也偏小,不清楚是哪里问题,还请各位大神帮忙,程序如下:
void CAPTURE_GPIO_Configuration(void)
    GPIO_InitTypeDef GPIO_InitStructure; /
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        /*频率捕获IO口配置*/
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_ResetBits(GPIOB,GPIO_Pin_7);
  void SetTIM4_NVIC(void)
    NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
  void TIM4_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
           TIM_ICInitTypeDef TIM_ICInitStructure ;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
       TIM_TimeBaseStructure.TIM_Prescaler = 72-1;
        TIM_TimeBaseStructure.TIM_Period = 0XFFFF;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up ;
    TIM_TimeBaseStructure.TIM_ClockDivision =0 ;
    TIM_TimeBaseInit( TIM4, &TIM_TimeBaseStructure);
        /*频率捕获寄存器配置TIM1_Channel_1*/
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
        TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising ;
        TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI ;
        TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1 ;
        TIM_ICInitStructure.TIM_ICFilter = 0x0;
        TIM_ICInit( TIM4, &TIM_ICInitStructure);
        TIM_ARRPreloadConfig(TIM4,ENABLE);
        TIM_ITConfig(TIM4, TIM_IT_CC1, ENABLE) ;
        TIM_ClearFlag(TIM4, TIM_FLAG_Update);
        /*高电平脉宽寄存器配置TIM1_Channel_2*/
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
        TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE) ;
        TIM_ITConfig(TIM4, TIM_IT_CC2, ENABLE) ;
        TIM_Cmd(TIM4, ENABLE);
void TIM4_IRQHandler(void)
    if(TIM_GetITStatus( TIM4, TIM_IT_CC1)==SET)
         /* Clear TIM4 update interrupt */
               TIM_ClearITPendingBit(TIM4,TIM_IT_CC1);
        if(Capture_number==0)
              Ic1_Read_Value = TIM_GetCapture1(TIM4);
                  Capture_number = 1 ;
            if(Capture_number==1)
              Ic2_Read_Value= TIM_GetCapture1(TIM4) ;
                  if(Ic2_Read_Value>Ic1_Read_Value)
                    Capture = (Ic2_Read_Value-Ic1_Read_Value);
                else
                    Capture = (65536 -Ic1_Read_Value + Ic2_Read_Value) ;
                     Capture_number = 0 ;
         /*脉宽捕获*/
        else if((TIM4CH2_CAPTURE_STA&0X8000)==0)
                if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
                        if(TIM4CH2_CAPTURE_STA&0X4000)
                                if((TIM4CH2_CAPTURE_STA&0X3FFF)==0X3FFF
                                        TIM4CH2_CAPTURE_STA|=0X8000;
                                        TIM4CH2_CAPTURE_VAL=0XFFFF;
                                else
                                TIM4CH2_CAPTURE_STA++;
            else if (TIM_GetITStatus(TIM4, TIM_IT_CC2) != RESET)/
                                TIM4CH2_CAPTURE_VAL=TIM_GetCapture2(TIM4);
                                   TIM_OC2PolarityConfig(TIM4,TIM_ICPolarity_Rising);
                        else
                                TIM4CH2_CAPTURE_STA=0;
                                TIM4CH2_CAPTURE_VAL=0;
                                 TIM_SetCounter(TIM4,0);
                                TIM4CH2_CAPTURE_STA|=0X4000;
                                   TIM_OC2PolarityConfig(TIM4,TIM_ICPolarity_Falling);
                 TIM_ClearITPendingBit(TIM4,TIM_IT_Update); //中断结束后,清除中断标志位
                 TIM_ClearITPendingBit(TIM4,TIM_IT_CC2); //中断结束后,清除中断标志位
        /*脉宽捕获计算*/
        if(TIM4CH2_CAPTURE_STA&0X8000)
                        temp=TIM4CH2_CAPTURE_STA&0X3FFF;
                        temp*=65536;
                        temp+=TIM4CH2_CAPTURE_VAL;
mmuuss586| | 2014-10-17 18:46 | 只看该作者
关掉一路可以吗?
可以的话,就是2路同时开有影响,那只能提高代码效率了;
sallychen|  楼主 | 2014-10-20 10:42 | 只看该作者
mmuuss586 发表于 2014-10-17 18:46
关掉一路可以吗?
可以的话,就是2路同时开有影响,那只能提高代码效率了; ...
两路信号同时捕获时,脉宽偏小,频率显示inf;频率捕获的管脚不接信号时,高电平测出来是准确的,请问下如何提高代码效率?
mmuuss586| | 2014-10-20 18:18 | 只看该作者
sallychen 发表于 2014-10-20 10:42
两路信号同时捕获时,脉宽偏小,频率显示inf;频率捕获的管脚不接信号时,高电平测出来是准确的,请问下 ...
少用固件库,读写寄存器;
提高系统时钟频率;
sallychen|  楼主 | 2014-10-21 15:45 | 只看该作者
mmuuss586 发表于 2014-10-20 18:18
少用固件库,读写寄存器;
提高系统时钟频率;
请问一下,中断服务函数这样写有影响么?
mmuuss586| | 2014-10-21 20:06 | 只看该作者
你这中断函数,内容也太多了;
中断函数尽量短;
很多判断尽量放主程序判断;
比如你计算频率,可以放主程序计算;
sallychen|  楼主 | 2014-10-22 13:23 | 只看该作者
恩,是中断函数的问题,谢谢你的回复
sallychen|  楼主 | 2014-10-22 21:59 | 只看该作者
mmuuss586 发表于 2014-10-21 20:06
你这中断函数,内容也太多了;
中断函数尽量短;
很多判断尽量放主程序判断;
这个要怎么结贴啊?分数给不了呢
mmuuss586| | 2014-10-23 08:26 | 只看该作者
