[i.MX] 使用mfgtool烧录一直停在jumping to OS image
11797|33
 楼主| yueyesighhz 发表于 2014-10-27 16:20 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-10-27 15:12
如有问题再联系我~~
我在安装ltib的时候出现了问题,不知道该如何解决。问题如下
rpmdb: --force-debian: unknown option
Died at ./ltib line 2340.
traceback:
main::setup_rpmdb:2340
  main::check_rpm_setup:2403
   main::host_checks:1423
    main:542
以上是日志文件里面的,我的ubuntu版本是13.10
FSL_TICS_Rita 发表于 2014-10-27 16:43 | 显示全部楼层
楼主你好,建议你将整个log都给我看一下,看你给的这部分,不能确定是哪里的问题。
 楼主| yueyesighhz 发表于 2014-10-27 16:47 | 显示全部楼层
楼主你好,建议你将整个log都给我看一下,看你给的这部分,不能确定是哪里的问题。 ...
这就是整个啊,全部都在这里了,里面就这么一段
FSL_TICS_Rita 发表于 2014-10-29 14:11 | 显示全部楼层
那你是操作到哪一步骤会出现上述问题呢?
FSL_TICS_Rita 发表于 2014-10-29 14:41 | 显示全部楼层
楼主你好,这里应该是你Ubuntu版本的问题。可能与LTIB兼容会有些问题。
 楼主| yueyesighhz 发表于 2014-10-29 17:40 | 显示全部楼层
我用的是ubuntu 13.10,就是在./ltib -m config出现的错误
那我应该用哪个版本的ubuntu?
 楼主| yueyesighhz 发表于 2014-10-30 10:34 | 显示全部楼层
你好,我换成ubuntu10.04编译还是有问题:log如下
Processing platform: host support
Processing: rpm-fs
Build path taken because: no prebuilt rpm,
Testing network connectivity
No network download connection available
Can't get: rpm-4.0.4.tar.gz at ./ltib line 790.
could not glob rpm in: /tmp/rpm-usr/RPMS/i686/rpm-fs-* at ./ltib line 2411.
traceback:
main::check_rpm_setup:2411
  main::host_checks:1424
   main:542
Started: Wed Oct 29 19:30:46 2014
Ended:   Wed Oct 29 19:31:03 2014
Elapsed: 17 seconds
These packages failed to build:
rpm-fs
Build Failed
 楼主| yueyesighhz 发表于 2014-10-30 15:29 | 显示全部楼层
我编译到uboot的地方出错了
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /home/usr/Desktop/ltib/ltib/tmp/rpm-tmp.60532
+ umask 022
+ cd /home/usr/Desktop/ltib/ltib/rpm/BUILD
+ cd u-boot-2009.08
/home/usr/Desktop/ltib/ltib/tmp/rpm-tmp.60532: line 22: PKG_U_BOOT_CONFIG_TYPE: must be set, e.g. MPC8548CDS_config
error: Bad exit status from /home/usr/Desktop/ltib/ltib/tmp/rpm-tmp.60532 (%build)
RPM build errors:
Build time for u-boot: 0 seconds
Failed building u-boot
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Thu Oct 30 00:25:05 2014
Ended:   Thu Oct 30 00:25:06 2014
Elapsed: 1 seconds
u-boot
Build Failed
Exiting on error or interrupt
usr@ubuntu:~/Desktop/ltib/ltib$
这里是什么问题导致的呢,我按照文档把需要安装的库都安装了一遍
 楼主| yueyesighhz 发表于 2014-10-30 16:43 | 显示全部楼层
前面是我配置uboot选项的时候选择错误了,现在ltib已经编译好了
FSL_TICS_Rita 发表于 2014-10-30 17:48 | 显示全部楼层
请问是在哪个版本的Ubuntu上编译成功的?欢迎有问题继续在本论坛中交流哈~~
 楼主| yueyesighhz 发表于 2014-10-30 18:11 | 显示全部楼层
请问是在哪个版本的Ubuntu上编译成功的?欢迎有问题继续在本论坛中交流哈~~ ...
是ubuntu10.04,还有我想问一下initramfs.cpio.gz.uboot这个文件生成在哪里,还有我修改了uboot里面的文件,要如何只编译uboot呢,每次都是全部编译
FSL_TICS_Rita 发表于 2014-11-3 16:22 | 显示全部楼层
是ubuntu10.04,还有我想问一下initramfs.cpio.gz.uboot这个文件生成在哪里,还有我修改了uboot里面的文 ...
楼主你好,在文档 i.MX_6Dual6Quad_SABRE-SD_Linux_User\'s_Guide.pdf (373.5 KB, 下载次数: 52) 中的3.9 Building Manufacturing Firmware有介绍如何编译出initramfs.cpio.gz.uboot。
FSL_TICS_Rita 发表于 2014-11-3 16:24 | 显示全部楼层
在3.7 How to Build U-Boot and Kernel in Standalone Environment中有介绍如何单独编译u-boot和kernel。你可以看一下。
