[AVR单片机] 结构体数组初始化
2022|5
 楼主| 自由自在2013 发表于 2014-10-24 11:47 | 显示全部楼层 |阅读模式
typedef struct  /*12*12 汉字字模显示数据结构,一个汉字分为上下两层*/
  char Index[2];//一个汉字占两个字节
  char Msk[24];//一个汉字的编码由24个十六进制数组成
}GB_12;
__flash unsigned char GB_12[]=
{0xEF,0x09,0xF9,0x4F,0x40,0xFF,0x49,0x49,0x49,0x79,0x01,0x00,0x07,0x04,0x03,0x02,//"距"
0x02,0x07,0x04,0x04,0x04,0x04,0x04,0x00},
{0x02,0x82,0xBE,0xA2,0xB6,0xEB,0xB6,0xA2,0xBE,0x82,0x02,0x00,0x00,0x07,0x00,0x02,//"离",
0x03,0x02,0x02,0x03,0x04,0x07,0x00,0x00},
{0x89,0x72,0x00,0xC0,0x5F,0xD5,0x55,0xD5,0x55,0xDF,0x00,0x00,0x07,0x00,0x04,0x07,//"温",
0x04,0x07,0x04,0x07,0x04,0x07,0x04,0x00},
{0x00,0xFE,0x0A,0x8A,0xBE,0xAA,0xAB,0xAA,0xBE,0x0A,0x0A,0x00,0x06,0x01,0x04,0x04,//"度",
0x04,0x03,0x02,0x03,0x04,0x04,0x04,0x00},
{0x10,0x08,0xFC,0xAB,0xAA,0xFA,0xAE,0xAA,0xA8,0xF8,0x00,0x00,0x04,0x02,0x01,0x00,//"角",
0x00,0x07,0x00,0x04,0x04,0x07,0x00,0x00},
为什么这个初始化总报错?
Error[Pe067]: expected a "}" E:\京东\IAR+Nokia5110\settings\lcd_char.c 332
ningling_21 发表于 2014-10-24 11:59 | 显示全部楼层
不符合语法
wangch_sh 发表于 2014-10-24 20:26 | 显示全部楼层
你定义了一个结构体数组,可是初始化却不是结构体。
SD10A 发表于 2014-10-25 22:43 | 显示全部楼层
}GB_12[5]=
你照着这个样子试验下 看看能不能行
efen 发表于 2014-10-28 15:36 | 显示全部楼层
__flash GB_12 table_GB_12[]={};
