[i.MX] 启动开发板在U-boot里下载uImage一直失败
3039|6
 楼主| xuehuabang 发表于 2014-10-27 17:30 | 显示全部楼层 |阅读模式
U-Boot 2009.08 (Sep 24 2012 - 13:05:47)
CPU: Freescale i.MX6 family TO1.0 at 792 MHz
Temperature:   can't get valid data!
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 22000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: RevC Board: 0x61310 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! device id=10
Net:   got MAC address from IIM: 00:04:9f:02:31:78
FEC0 [PRIME]
Hit any key to stop autoboot:  0
FEC: Link is Up 796d
Using FEC0 device
TFTP from server 192.168.1.101; our IP address is 192.168.1.103
Filename 'uImage'.
Load address: 0x10800000
Loading: T T T T T T T T T T T T T T T T T T T T T T
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
MX6SDL SABRESD U-Boot >
MX6SDL SABRESD U-Boot > destroyenv
invalidate the CRC
write invalidate enviroment data to storage
Writing to MMC(3)... done
MX6SDL SABRESD U-Boot > setenv bootargs console=ttymxc0,115200
MX6SDL SABRESD U-Boot > setenv loadaddr 0x10800000
MX6SDL SABRESD U-Boot > setenv serverip 10.192.225.216
MX6SDL SABRESD U-Boot > setenv bootfile uImage
MX6SDL SABRESD U-Boot > setenv ethaddr 00:01:02:03:04:05
MX6SDL SABRESD U-Boot > saveenv
Saving Environment to MMC...
MX6SDL SABRESD U-Boot > dhcp
BOOTP broadcast 1
DHCP client bound to address 190.5.1.104
Using FEC0 device
TFTP from server 10.192.225.216; our IP address is 190.5.1.104; sending through gateway 190.5.200.250
Filename 'uImage'.
Loading: T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
Abort
MX6SDL SABRESD U-Boot > etenv serverip 190.5.100.144
Unknown command 'etenv' - try 'help'
                                         0.5.100.144
MX6SDL SABRESD U-Boot > setenv serverip 190.5.100.143
BOOTP broadcast 1
Using FEC0 device
TFTP from server 190.5.100.143; our IP address is 190.5.1.104
Filename 'uImage'.
Loading: T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
BOOTP broadcast 1
Using FEC0 device
Filename 'uImage'.
FSL_TICS_Rita 发表于 2014-10-27 18:27 | 显示全部楼层
楼主你好,你在u-boot中print后,把你的参数给我看一下。
 楼主| xuehuabang 发表于 2014-10-28 09:56 | 显示全部楼层
我已经解决了,是主机的tftp没设置好
FSL_TICS_Rita 发表于 2014-10-28 15:18 | 显示全部楼层
我已经解决了,是主机的tftp没设置好
恭喜楼主问题已经解决,欢迎有问题继续在本论坛中交流讨论哈~~
FSL_TICS_Rita 发表于 2014-10-28 15:19 | 显示全部楼层
楼主问题解决了,麻烦帮忙结帖,非常感谢~~
 楼主| xuehuabang 发表于 2014-11-19 16:59 | 显示全部楼层
OK!好的:D
FSL_TICS_Rita 发表于 2014-11-20 16:53 | 显示全部楼层
OK!好的
欢迎有问题继续在本论坛中创帖交流哈~~
