| 以前习惯写函数时,把初始化函数写成GPIO_Init()/UART_Init()的形式,这样一目了然,可是ST的库中有这样的定义
 所以,我们在写初始化函数的时候可以写成如下这样的形式void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct)
  uint32_t currentmode = 0x00, currentpin = 0x00, pinpos = 0x00, pos = 0x00;
  uint32_t tmpreg = 0x00, pinmask = 0x00;
  /* Check the parameters */
  assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
  assert_param(IS_GPIO_MODE(GPIO_InitStruct->GPIO_Mode));
  assert_param(IS_GPIO_PIN(GPIO_InitStruct->GPIO_Pin));
/*---------------------------- GPIO Mode Configuration -----------------------*/
  currentmode = ((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x0F);
  if ((((uint32_t)GPIO_InitStruct->GPIO_Mode) & ((uint32_t)0x10)) != 0x00) //输出模式
    assert_param(IS_GPIO_SPEED(GPIO_InitStruct->GPIO_Speed));
    /* Output mode */
    currentmode |= (uint32_t)GPIO_InitStruct->GPIO_Speed;
/*---------------------------- GPIO CRL Configuration ------------------------*/  //低8位
  /* Configure the eight low port pins */
  if (((uint32_t)GPIO_InitStruct->GPIO_Pin & ((uint32_t)0x00FF)) != 0x00) //引脚有定义
    tmpreg = GPIOx->CRL;
    for (pinpos = 0x00; pinpos < 0x08; pinpos++)
      pos = ((uint32_t)0x01) << pinpos;
      /* Get the port pins position */
      currentpin = (GPIO_InitStruct->GPIO_Pin) & pos;
      if (currentpin == pos)         //判断每一个脚
        pos = pinpos << 2;
        /* Clear the corresponding low control register bits */
        pinmask = ((uint32_t)0x0F) << pos;
        tmpreg &= ~pinmask;
        /* Write the mode configuration in the corresponding bits */
        tmpreg |= (currentmode << pos);
        /* Reset the corresponding ODR bit */
        if (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_IPD)   // 端口置为高电平
          GPIOx->BRR = (((uint32_t)0x01) << pinpos);
        else
          /* Set the corresponding ODR bit */
          if (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_IPU)        // 端口清0
            GPIOx->BSRR = (((uint32_t)0x01) << pinpos);
    GPIOx->CRL = tmpreg;
/*---------------------------- GPIO CRH Configuration ------------------------*/
  /* Configure the eight high port pins */
  if (GPIO_InitStruct->GPIO_Pin > 0x00FF)
    tmpreg = GPIOx->CRH;
      pos = (((uint32_t)0x01) << (pinpos + 0x08));
      currentpin = ((GPIO_InitStruct->GPIO_Pin) & pos);
        pos = pinpos << 2;
        /* Clear the corresponding high control register bits */
        tmpreg &= ~pinmask;
          GPIOx->BRR = (((uint32_t)0x01) << (pinpos + 0x08));
          GPIOx->BSRR = (((uint32_t)0x01) << (pinpos + 0x08));
    GPIOx->CRH = tmpreg;
 void GPIO_config(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);//
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//只初始化PC6
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//通用外推输出
  GPIO_Init(GPIOC, &GPIO_InitStructure);//PC6控制IO
