在DSP上实现DCT的三角波/方波/正弦波的显示代码(1)
1468|4
 楼主| 拿起书本 发表于 2014-11-12 15:48 | 显示全部楼层 |阅读模式
*      (C)  COPYRIGHT TEXAS INSTRUMENTS, INC. 1996            *
*  FILE NAME:  FDCT.ASM                                       *
*  HISTORY:  This program is originally written in TMS320C5x  *
*            assembly language by G. Peake of Texas           *
*            Instruments, Inc.                                *
*  TRANSLATORS:  Rushani Wirasinghe                           *
*                Xiaozhen Zhang                               *
*  DESCRIPTION:                                               *
*  -  Forward DCT algorithm.                                  *
*  -  Code written in TMS320C54x assembly language.           *
*  -  Files:  Fdct.asm      (This file)                       *
*             Dct.doc       (DCT Documentation)               *
*             fdct.cmd      (Linker Command File)             *
*             Fdct_dat.inc                                    *
*  -  Import Functions:      none                             *
*  -  Import Data:           none                             *
*  -  Export Functions:      none                             *
*  -  Export Data:           none                             *
*  LAST DAY MODIFIED:  August 23, 1996                        *
        .mmregs
        .def    entry
        .sect   "INIT"
*               Initialise
entry   NOP
        NOP
        SSBX    SXM                 ; set sign extension mode
        SSBX    OVM                 ; enable saturation
        LD      #0, DP              ; set data page
        STM     0FFE0h, PMST        ; Init PMST reg.
*                        ----+   | |||||+- BRAF - reset block RPT active
*                            |   | ||||+-- TRM  - C5X T-reg mode
*                            |   | |||+--- NDX  - C5x Index reg mode
*                            |   | ||+---- MP/MC - MC mode
*                            |   | |+----- RAM  - SPRAM = @prog
*                            |   | +------ OVLY - SPRAM = @data
*                            |   +-------- AVIS - no addr line visibility
*                            +------------ IPTR - Interrupt vectors at 000h
        RSBX    FRCT
        .include "fdct_dat.inc"     ; FDCT data storage declaration
MODE    .SET  1                     ; MODE=1 TEST ON SIMULATOR
PAGE0   .SET  0
PAGE4   .SET  4
PAGE24  .SET  24d
PAGE25  .SET  25d
B0      .SET  0200h
B1      .SET  0300h
B2      .SET  060h
PA1BIS  .SET  1
PA2BIS  .SET  2
PA3BIS  .SET  3
PA4BIS  .SET  4
PA5BIS  .SET  5
PA6BIS  .SET  6
* Initialization of the registers
  .sect "FDCT"
INIT    LD      #PAGE24, DP
        ST      #21407, E_P6
        ST      #8867, F_P6
        ST      #2000H, ROUND1
TBL:    LD      #PAGE25, DP
        ST      #21407, E_P7
        ST      #8867, F_P7
        ST      #4000H, ROUND2
        ST      #40H, ROUND3
START
*      READ A 8x8 BLOCK AND PLACE IT IN X(M,N)                        *
* IF MODE = SIMULATOR
        .IF     MODE=1
        STM     #63, AR0            ; AR0= # of inputs to be taken - 1
        STM     #X, AR1             ; AR1= address of first input
BEG     PORTR   #PA1BIS, *AR1+      ; Read and store to addr(AR1)
  NOP
  NOP
        BANZ    BEG, *AR0-          ; Repeat above code 64 times
                                    ; till all 64 pixels are read
.ENDIF
;       *    FIRST STEP :               *
;       *       CALCULATE INNER TRANSFORM        *
;         *         (PROCESS INPUT ROWS)           *
        STM    #3, AR0
        STM    #X, AR1              ; Reset AR1 to first input
        STM    #Y00, AR2            ; Set AR2 to first Y block
; PROCESS FIRST 8 INPUTS.     X(0,0)...X(0,7)  ->  Y(0,0)...Y(0,7)  *
DCT1    NOP
        NOP
        LD     #PAGE24, DP
        LD     *AR1+, 4, A           ; + (16)*(X0)
        ADD    *AR1+, 4, A           ; + (16)*(X1)
        ADD    *AR1+, 4, A           ; + (16)*(X2)
        ADD    *AR1+, 4, A           ; + (16)*(X3)
        ADD    *AR1+, 4, A           ; + (16)*(X4)
        ADD    *AR1+, 4, A           ; + (16)*(X5)
        ADD    *AR1+, 4, A           ; + (16)*(X6)
        ADD    *AR1,  4,A            ; + (16)*(X7)
STL    A, Y00                ; = Y00
        RPTZ   A, #7
        MACP   *AR1-, COEF_F1, A
        SFTA   A, 4
        MAR    *AR1+                 ; (64)[A*X0+B*X1+C*X2-D*X3-D*X4
        ADD    ROUND1, A             ; -C*X5-B*X6-A*X7] + 4*ROUND1
        STH    A, 2, Y01             ; = Y01
        LD     ROUND1, -4, A         ; (ROUND1)/16
        LD     E_P6, T
        MAC    *AR1+0, A             ; + X0*E_P6
        MAS    *AR1+, A              ; - X3*E_P6
        MAS    *AR1+0, A             ; - X4*E_P6
        MAC    *AR1-, A              ; + X7*E_P6
        LD     F_P6, T
MAC    *AR1-, A              ; + X6*F_P6
        MAS    *AR1-0, A             ; - X5*F_P6
        MAS    *AR1-, A              ; - X2*F_P6
        MAC    *AR1-, A              ; + X1*F_P6
        STH    A, 6, Y02             ; Multiply prev summation by 16
                                     ; = Y02
        RPTZ   A, #7
        MACP   *AR1+, COEFF2, A      ; 64(B*X0-D*X1-A*X2-C*X3+C*X4+A*X5
        SFTA   A, 4
        MAR    *AR1-
        ADD    ROUND1, A             ; +D*X6-B*X7) + 4*ROUND1
        STH    A, 2, Y03             ; = Y03
        LD    *AR1-, 4, A            ;   X7*16
        SUB   *AR1-, 4, A            ; - X6*16
        SUB   *AR1-, 4, A            ; - X5*16
        ADD   *AR1-, 4, A            ; + X4*16
        ADD   *AR1-, 4, A            ; + X3*16
        SUB   *AR1-, 4, A            ; - X2*16
        SUB   *AR1-, 4, A            ; - X1*16
        ADD   *AR1, 4, A             ; + X0*16
        STL   A, Y04                 ; = Y04
        RPTZ  A, #7
        MACP  *AR1+, COEFF3, A       ; 8(D*X0-C*X1+B*X2-A*X3+A*X4-B*X5
        SFTA  A, 4                   ; +C*X6-D*X7)
        MAR   *AR1-
        ADD   ROUND1, A              ; + 4*ROUND1
        STH   A, 2, Y05              ; = Y05
        LD    F_P6, T
        MAC   *AR1-0, A              ; + F_P6*X7
        MAS   *AR1-, A               ; - F_P6*X4
        MAS   *AR1-0, A              ; - F_P6*X3
        MAC   *AR1+, A               ; + F_P6*X0
        LD    E_P6, T
        MAS   *AR1+, A               ; - E_P6*X1
        MAC   *AR1+0, A              ; + E_P6*X2
        MAC   *AR1+, A               ; + E_P6*X5
        MAS   *AR1+, A               ; - E_P6*X6
        STH   A, 6, Y06              ; Multiply prev summation by 16
                                     ; = Y06
        RPTZ   A, #7
        MACP  *AR1-, COEF_F4, A      ; 64(D*X0-C*X1+B*X2-A*X3+A*X4-B*X5
        MAR   *AR1+
        STH   A, 2, Y07              ; = Y07
        MAR   *+AR1(8)               ; Set AR1 to point to the next set
                                     ; of 8 inputs
; PROCESS SECOND 8 INPUTS.    X(1,0)...X(1,7)  ->  Y(1,0)...Y(1,7)  *
ADD    *AR1, 4, A            ; + (16)*(X7)
STL    A, Y10                ; = Y10
        RPTZ   A, #7
        SFTA   A, 4
        STH    A, 2, Y11             ; = Y11
        LD     E_P6, T
        LD     F_P6, T
        STH    A, 6, Y12             ; Multiply prev summation by 16
                                     ; = Y12
        RPTZ   A, #7
        SFTA   A, 4
        MAR    *AR1-
        STH    A, 2, Y13             ; = Y13
        STL   A, Y14                 ; = Y14
        RPTZ  A, #7
        MAR   *AR1-
        STH   A, 2, Y15              ; = Y15
        LD    F_P6, T
        LD    E_P6, T
        STH   A, 6, Y16              ; Multiply prev summation by 16
                                     ; = Y16
        RPTZ   A, #7
        MAR   *AR1+
        STH   A, 2, Y17              ; = Y17
                                     ; of 8 inputs
; PROCESS THIRD 8 INPUTS.     X(2,0)...X(2,7)  ->  Y(2,0)...Y(2,7)  *
STL    A, Y20                ; = Y20
        RPTZ   A, #7
        SFTA   A, 4
        STH    A, 2, Y21             ; = Y21
        LD     E_P6, T
        LD     F_P6, T
 楼主| 拿起书本 发表于 2014-11-12 15:49 | 显示全部楼层
        STH    A, 6, Y22             ; Multiply prev summation by 16
                                     ; = Y22
        RPTZ   A, #7
        SFTA   A, 4
        MAR    *AR1-
        STH    A, 2, Y23             ; = Y23
        STL   A, Y24                 ; = Y24
        RPTZ  A, #7
        MAR   *AR1-
        STH   A, 2, Y25              ; = Y25
        LD    F_P6, T
        LD    E_P6, T
        STH   A, 6, Y26              ; Multiply prev summation by 16
                                     ; = Y26
        RPTZ   A, #7
        MAR   *AR1+
        STH   A, 2, Y27              ; = Y27
                                     ; of 8 inputs
huangfeng33 发表于 2014-11-19 11:26 | 显示全部楼层
在DSP上实现DCT的三角波/方波/正弦波的显示代码,针对初学开发,绝对实用,
很值得参考。
elecintop 发表于 2014-11-30 13:21 | 显示全部楼层
:handshake
个人签名:好好学习,天天向上!
519
