[51单片机] C8051PCA测频求助
1111|2
 楼主| xiaohai95 发表于 2014-11-19 12:26 | 显示全部楼层 |阅读模式
//  Generated Initialization File  //
#include "C8051F020.h"
unsigned long FRQ;
sfr16 PCA0CP0=0XFB;
// Peripheral specific initialization functions,
// Called from the Init_Device() function
void PCA_Init()
    PCA0CN    = 0x40;
    PCA0MD    = 0x02;
    PCA0CPM0  = 0x11;
    PCA0CPM1  = 0x46;
    PCA0CPH1  = 0x64;
void Port_IO_Init()
    // P0.0  -  CEX0 (PCA),  Open-Drain, Digital
    // P0.1  -  CEX1 (PCA),  Push-Pull,  Digital
    // P0.2  -  Unassigned,  Open-Drain, Digital
    // P0.3  -  Unassigned,  Open-Drain, Digital
    // P0.4  -  Unassigned,  Open-Drain, Digital
    // P0.5  -  Unassigned,  Open-Drain, Digital
    // P0.6  -  Unassigned,  Open-Drain, Digital
    // P0.7  -  Unassigned,  Open-Drain, Digital
    // P1.0  -  Unassigned,  Open-Drain, Digital
    // P1.1  -  Unassigned,  Open-Drain, Digital
    // P1.2  -  Unassigned,  Open-Drain, Digital
    // P1.3  -  Unassigned,  Open-Drain, Digital
    // P1.4  -  Unassigned,  Open-Drain, Digital
    // P1.5  -  Unassigned,  Open-Drain, Digital
    // P1.6  -  Unassigned,  Open-Drain, Digital
    // P1.7  -  Unassigned,  Open-Drain, Digital
    // P2.0  -  Unassigned,  Open-Drain, Digital
    // P2.1  -  Unassigned,  Open-Drain, Digital
    // P2.2  -  Unassigned,  Open-Drain, Digital
    // P2.3  -  Unassigned,  Open-Drain, Digital
    // P2.4  -  Unassigned,  Open-Drain, Digital
    // P2.5  -  Unassigned,  Open-Drain, Digital
    // P2.6  -  Unassigned,  Open-Drain, Digital
    // P2.7  -  Unassigned,  Open-Drain, Digital
    // P3.0  -  Unassigned,  Open-Drain, Digital
    // P3.1  -  Unassigned,  Open-Drain, Digital
    // P3.2  -  Unassigned,  Open-Drain, Digital
    // P3.3  -  Unassigned,  Open-Drain, Digital
    // P3.4  -  Unassigned,  Open-Drain, Digital
    // P3.5  -  Unassigned,  Open-Drain, Digital
    // P3.6  -  Unassigned,  Open-Drain, Digital
    // P3.7  -  Unassigned,  Open-Drain, Digital
    P0MDOUT   = 0x02;
    XBR0      = 0x10;
    XBR2      = 0x40;
void CloseWDT(void)//系统配置
WDTCN = 0xDE;// 关闭 WDT
WDTCN = 0xAD; //关闭看门狗
void Oscillator_Init()
    OSCICN    = 0x07;
void getfrq(void) interrupt 9//捕获下降沿中断,第一次捕捉把PCA0计数器清空,第二次捕捉时根据PCA0CP0中存放的PCA0的值乘以时间就是周期,
EA=0;
PCA0L=0x00;
PCA0H=0x00;
  FRQ=1000000.0/(PCA0CP0*0.25);//16MHZ,1/4f,t=0.25us//我测出两次下降沿的时间,即一个周期的时间,此时系统走了计数器*1/4MHZ(秒)
  EA=1;
  CCF0=0;
// Initialization function for device,
// Call Init_Device() from your main program
void Init_Device(void)
{    CloseWDT();
Oscillator_Init();
    PCA_Init();
    Port_IO_Init();
void main(void)
Init_Device();
EA=1;
while(1);
用Configuration Wizard生成的程序,自己加了看门狗关闭和中断程序,PCA0开启,CEX0用于测频捕捉,CEX1产生20Khz的信号且推挽输出,用线把这两个直接连起来,但是调试的时候FRQ的值始终为0
受不了了 发表于 2014-11-20 14:30 | 显示全部楼层
好久不用了,这个需要把PCA的时钟走起来才行的,即不只是单纯开通捕捉,还需要有个能看时间的表
JasonWon 发表于 2014-11-24 20:12 | 显示全部楼层
PCA也有自己的运行时钟,这个可以根据系统时钟来分配,对输入脉冲捕捉计数,同时要考虑溢出的情况
