[STM8] STM8S103F使用EEPROM死机问题
7470|11
 楼主| berry56 发表于 2014-12-2 14:54 | 显示全部楼层 |阅读模式
使用芯片内部自带的EEPROM,STVD,Cosmic的Toolset,不管是用函数库中的FLASH_ProgramBlock,FLASH_WaitForLastOperation还是使用寄存器地址直接赋值,都会死机,如果是使用FLASH_WaitForLastOperation,则会死在该语句,如果是使用寄存器,则会死在 while(!(FLASH_IAPSR&0x04)); ,已经按照函数中说的那样,一、在Stm8s.h中定义了#define RAM_EXECUTION  (1) ,并在input设置中,在RAM的SECTION中加了FLASH_CODE,仍然当机,求高手解决,谢谢~~~
 楼主| berry56 发表于 2014-12-2 16:00 | 显示全部楼层
没有人用过103的EEPROM吗?
 楼主| berry56 发表于 2014-12-2 16:05 | 显示全部楼层
/* MAIN.C file
* Copyright (c) 2002-2005 STMicroelectronics
#include "stm8s.h"
#include "stm8s_flash.h"
#include "stm8s_gpio.h"
#include "stm8s_clk.h"
@eeprom unsigned char  EePromData[10]={0,1,2,3,4,5,6,7,8,9};
/* Private typedef -----------------------------------------------------------*/
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define BLOCK_OPERATION    0    /* block 0 in data eeprom memory: address is 0x4000 */
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint8_t GBuffer[FLASH_BLOCK_SIZE];
__IO TestStatus OperationStatus;
#ifdef _RAISONANCE_
/* needed by memcpy for raisonance */
#include <string.h>
extern int __address__FLASH_EraseBlock;
extern int __size__FLASH_EraseBlock;
extern int __address__FLASH_ProgramBlock;
extern int __size__FLASH_ProgramBlock;
#endif /*_RAISONANCE_*/
/* Private function prototypes -----------------------------------------------*/
/* Declare _fctcpy function prototype as it is packaged by default in the Cosmic
   machine library */
#ifdef _COSMIC_
int _fctcpy(char name);
#endif /*_COSMIC_*/
void Delay (uint16_t nCount);
static void CLK_Config(void);
static void GPIO_Config(void);
static void FLASH_Config(void);
typedef struct
  unsigned char ODR0        : 1;
  unsigned char ODR1        : 1;
  unsigned char ODR2        : 1;
  unsigned char ODR3        : 1;
  unsigned char ODR4        : 1;
  unsigned char ODR5        : 1;
  unsigned char ODR6        : 1;
  unsigned char ODR7        : 1;
} __BITS_ODR;
#define PB_ODR ((__BITS_ODR *) 0x5005)
#define LED                PB_ODR->ODR5
void delayms(unsigned int t)
        unsigned int tloop,ttloop;
        for(tloop=0;tloop<t;tloop++)
                for(ttloop=0;ttloop<200;ttloop++)
                _asm("nop");
#define u8        unsigned char
#define U16 unsigned int
#define U8         unsigned char
#define         EEPMASS1     0xAE                   //密码钥匙1
#define         EEPMASS2     0x56                   //密码钥匙2
#define         EEPADDR      0x4000                  //eep地址起始
#define FLASH_DUKR        FLASH->DUKR
#define FLASH_IAPSR        FLASH->IAPSR
#define FLASH_CR1        FLASH->CR1
#define FLASH_CR2        FLASH->CR2
#define FLASH_NCR2        FLASH->NCR2
#define FLASH_PUKR        FLASH->PUKR
#define FLASH_NFPR        FLASH->NFPR
void eep_word_write(U16 u16Addr, U8 *pdatas, U8 len)
  U8 *eep=(U8*)u16Addr;
  U8 j;
  FLASH_DUKR=EEPMASS1;                //锁1密钥
  FLASH_DUKR=EEPMASS2;                //锁2密钥
  while(!(FLASH_IAPSR&0x08));         //等待解密就绪
//  DISABLE_MAC_INTERRUPTS();
  FLASH_CR2 |= 0x40;     //
  FLASH_NCR2 &= ~0x40;   //设置字编程
  for(j=0; j<len; j++)
    eep[j] = pdatas[j];
        delayms(100);
// while(!(FLASH_IAPSR&0x04));
// FLASH_IAPSR &=0xf7;    // off the eeprom program
//  ENABLE_MAC_INTERRUPTS();
void eeprom_read(U16 u16Addr, U8 *pdatas, U8 len)
  U8 *eep=(U8 *)u16Addr;
  U8 j;
    pdatas[j]=eep[j];
main()
        u8        tval;
        u8 *p=(u8 *)0x4000;
        u8 buff[128];
        GPIOB->CR1=0xF0;
        GPIOB->CR2=0xF0;
        GPIOB->DDR=0xF0;
        //eep_word_write(0x4000,buff,3);
        //eeprom_read(0x4000,buff,3);
        buff[0]=0x33;buff[1]=0x33;buff[2]=0x33;buff[3]=0x33;buff[4]=0x33;
FLASH_SetProgrammingTime(FLASH_PROGRAMTIME_STANDARD);
  FLASH_Unlock(FLASH_MEMTYPE_PROG);
  /* Wait until Flash Program area unlocked flag is set*/
  while (FLASH_GetFlagStatus(FLASH_FLAG_PUL) == RESET)
        FLASH_ProgramByte(0x4005,0x55);
        //EePromData[0]=9;
        //eep_word_write(0x4000,buff,2);
        delayms(500);
        tval=EePromData[4];
        tval=p[4];
                while (1)
                        delayms(500);
                        LED=1;
                        delayms(500);
                        LED=0;
#if 0
main()
  uint32_t add = 0, startadd = 0, stopadd = 0;
  uint8_t newval = 0xAA;
  uint8_t i = 0;
#ifdef _COSMIC_
/* Call the _fctcpy() function with the first segment character as parameter
   "_fctcpy('F');"  for a manual copy of the declared moveable code segment
   (FLASH_CODE) in RAM before execution*/
  _fctcpy('F');
#endif /*_COSMIC_*/
#ifdef _RAISONANCE_
/* Call the standard C library: memcpy() or fmemcpy() functions available through
   the <string.h> to copy the inram function to the RAM destination address */
  MEMCPY(FLASH_EraseBlock,
         (void PointerAttr*)&__address__FLASH_EraseBlock,
         (int)&__size__FLASH_EraseBlock);
  MEMCPY(FLASH_ProgramBlock,
         (void PointerAttr*)&__address__FLASH_ProgramBlock,
         (int)&__size__FLASH_ProgramBlock);
  /* Clock configuration -----------------------------------------*/
  CLK_Config();
  /* GPIO Configuration ------------------------------------------*/
  GPIO_Config();
  /* FLASH Configuration ------------------------------------------*/
  FLASH_Config();
  /* Fill the buffer in RAM */
  for (i = 0; i < FLASH_BLOCK_SIZE; i++)
    GBuffer = newval;
  /* This function is executed from RAM */
  FLASH_ProgramBlock(BLOCK_OPERATION, FLASH_MEMTYPE_DATA, FLASH_PROGRAMMODE_STANDARD, GBuffer);
  /* Wait until End of high voltage flag is set*/
// while (FLASH_GetFlagStatus(FLASH_FLAG_HVOFF) == RESET)
  while (FLASH_GetFlagStatus(FLASH_FLAG_EOP) == RESET)
  /* Check the programmed block */
  startadd = FLASH_DATA_START_PHYSICAL_ADDRESS + ((uint16_t)BLOCK_OPERATION * (uint16_t)FLASH_BLOCK_SIZE);
  stopadd = startadd + (uint16_t)FLASH_BLOCK_SIZE;
  for (add = startadd; add < stopadd; add++)
        if (FLASH_ReadByte(add) != newval)
          /* Error */
          OperationStatus = FAILED;
          /* OperationStatus = PASSED, if the data written/read to/from Flash program memory is correct */
          /* OperationStatus = FAILED, if the data written/read to/from Flash program memory is corrupted */
          while (1)
            Delay(0xFFFF);
  /* Erase block 0 and verify it */
  FLASH_EraseBlock(BLOCK_OPERATION, FLASH_MEMTYPE_DATA);
        if (FLASH_ReadByte(add) != 0x00)
          /* Error */
          while (1)
            Delay(0xFFFF);
  /* Pass */
  OperationStatus = PASSED;
  while (1)
    Delay(0xFFFF);
GPIOB->CR1=0xF0;
GPIOB->CR2=0xF0;
GPIOB->DDR=0xF0;
        while (1)
                delayms(500);
                LED=1;
                delayms(500);
                LED=0;
#endif
  * @brief  Configure system clock to run at 16Mhz
  * @param  None
  * @retval None
    /* Initialization of the clock */
    /* Clock divider to HSI/1 */
    CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  * @brief  Configure GPIO for LEDs available on the evaluation board
  * @param  None
  * @retval None
    /* Initialize LEDs mounted on STM8-128 EVAL board */
  * @brief  Configure the FLASH for block programming
  * @param  None
  * @retval None
/* Define flash programming Time*/
  /* Unlock flash data eeprom memory */
  FLASH_Unlock(FLASH_MEMTYPE_DATA);
  /* Wait until Data EEPROM area unlocked flag is set*/
  while (FLASH_GetFlagStatus(FLASH_FLAG_DUL) == RESET)
  * @brief  Delay.
  * @param  nCount
  * @retval None
void Delay(uint16_t nCount)
    /* Decrement nCount value */
    while (nCount != 0)
        nCount--;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
 楼主| berry56 发表于 2014-12-2 16:06 | 显示全部楼层
各种尝试各种等。。。
hopewise 发表于 2014-12-2 17:39 | 显示全部楼层
uchar   ledStateInEEPROM @0X4000; //设定温度值存放地址在0X4000
//判断是否为首次上电,如果不是,则读取上次设定的温度值
if(ledStateInEEPROM != 0X00)
         set_temp = ledStateInEEPROM;
else               //否则,是第1次上电,故要初始化为31度
          set_temp=31;
* 名称:     UnlockEEPROM()
* 功能:     解锁EEPROM
* 入口参数: 无
* 出口参数: 无
* 说明:
void  UnlockEEPROM(void)
     do
          FLASH_DUKR = 0xae;               // 写入第一个密钥
          FLASH_DUKR = 0x56;               // 写入第二个密钥
     } while((FLASH_IAPSR & 0x08) == 0);   // 若解锁未成功,则重新再来
if(set_temp>34) set_temp=20;                  //最大设定温度是34度
                                        UnlockEEPROM();                   //解锁EEPROM
                                        ledStateInEEPROM = set_temp;      //往EEPROM写入led灯状态
                                        while((FLASH_IAPSR & 0x04) == 0); //等待写操作成功
hopewise 发表于 2014-12-2 17:45 | 显示全部楼层
以上是我用在产品上的(103的EEPROM)
Xflyan 发表于 2014-12-2 17:46 | 显示全部楼层
库里整理出来的寄存器代码,还未死过....环境:EWSTM8
  1. /*===============================================
  2. *        EEPROM Configuration
  3. *        640 Bytes for STM8S103 & STM8S903
  4. *=============================================*/
  5. #define EEPROM_START_ADDR       ((u32)0x004000)
  6. #define EEPROM_END_ADDR         ((u32)0x00427F)
  7. #define OPERATION_TIMEOUT           ((u16)0x1000)
  8. void halEEWriteByte(u32 addr, u8 dat)
  9. {
  10.         u16 timeout = OPERATION_TIMEOUT;
  11.
  12.         /* Warning: keys are reversed on data memory !!! */
  13.     FLASH->DUKR = FLASH_RASS_KEY2;
  14.     FLASH->DUKR = FLASH_RASS_KEY1;
  15.
  16.         while ((addr < EEPROM_START_ADDR) || (addr > EEPROM_END_ADDR));
  17.     *((__far u8*) addr) = dat;
  18.
  19.         while ((FLASH->IAPSR & (FLASH_IAPSR_EOP | FLASH_IAPSR_WR_PG_DIS)) && (--timeout));
  20.
  21.         FLASH->IAPSR = (u8)(~FLASH_IAPSR_DUL);
  22. }
  23. void halEEWriteWord(u32 addr, u8 * dat)
  24. {
  25.         u16 timeout = OPERATION_TIMEOUT;
  26.
  27.         /* Warning: keys are reversed on data memory !!! */
  28.     FLASH->DUKR = FLASH_RASS_KEY2;
  29.     FLASH->DUKR = FLASH_RASS_KEY1;
  30.
  31.         /* Enable Word Write Once */
  32.     FLASH->CR2  |= FLASH_CR2_WPRG;
  33.     FLASH->NCR2 &= (u8)(~FLASH_NCR2_NWPRG);
  34.
  35.         while ((addr < EEPROM_START_ADDR) || (addr > EEPROM_END_ADDR));
  36.     *((__far u8*) addr) = dat[0];
  37.         *((__far u8*) (addr + 1)) = dat[1];
  38.         *((__far u8*) (addr + 2)) = dat[2];
  39.         *((__far u8*) (addr + 3)) = dat[3];
  40.
  41.         while ((FLASH->IAPSR & (FLASH_IAPSR_EOP | FLASH_IAPSR_WR_PG_DIS)) && (--timeout));
  42.
  43.         FLASH->IAPSR = (u8)(~FLASH_IAPSR_DUL);
  44. }
  45. u8 halEEReadByte(u32 addr)
  46. {
  47.         return (*((__far u8 *) addr));
  48. }
airwill 发表于 2014-12-2 21:15 | 显示全部楼层
我觉得你应该找例程对照着,让调试器来帮你,看看跑到什么地方过不去了。
应该很好找问题吧
jhp3909553 发表于 2014-12-3 10:25 | 显示全部楼层
以前我也是,有使用莫名其妙的飞了。现在也不知道为什么
lysfht123 发表于 2014-12-3 15:20 | 显示全部楼层
8楼是正解。调试,
Hecat 发表于 2017-2-17 15:28 | 显示全部楼层
EEPROM写入不会引起死机。
引起死机的原因估计是串口接收过载。
EEPROM写入比较耗时间,在写入期间,CPU是暂停操作的,串口如果有数据进来,非常容易引起过载。
如果接收过载,串口状态寄存器UART_SR的位OR被置位。
OR位置位会引起串口接收中断。正常的读UART_DR不会清除这个状态,于是引起串口RX反复中断,近似死机。
清除OR标志的方法是,先读取UART_SR,再读取UART_DR。
在原代码的UARTx_ReceiveDatax()函数前加一句(uint8_t)UART1->SR即可
(uint8_t)UART1->SR;                 //Clear OR flag
*rx_wp = UART1_ReceiveData8();
yiyigirl2014 发表于 2017-2-17 21:05 | 显示全部楼层
死机会不会硬件的问题?
