pic30f2020,我做了一个程序大家帮忙看看
3329|1
视力不良|  楼主 | 2008-5-14 17:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我想弄一个SPWM的波,但是现在duty随周期在变,不知道PWM输出后还要加什么东西滤波或者怎么样,直接加个电容连接一个电阻看到的波很不理想也不是正弦波,这个是面积等效法作的50HZ的实验。PTPER中256个数是1微秒。所用调试环境MPLAB ICD2 v8.10 编译器是C30,外部有4M的晶振,再有就是PTPER时间怎么算,希望各位不吝赐教,程序如下:
#include <stdio.h>
#include <p30f2020.h>
#include <math.h>
#define PI 3.141592
_FOSC(CSW_FSCM_OFF & HS) //HS振荡器,禁止时钟切换
_FWDT(FWDTEN_OFF); //禁止看门狗定时器
//_FBORPOR(PBOR_OFF & MCLR_EN); //禁止掉电复位,使能MCLR复位
_FGS(CODE_PROT_OFF);
int N,f=20;
double Pul;
int BUFcos[98]={5,5,24,35,44,54,64,73,86,93,101,111,120,130,138,147,156,164,
172,181,188,197,204,211,219,226,232,239,245,251,257,263,268,272,278,282,287,
290,294,297,300,303,306,308,309,311,312,313,314,314,313,312,311,309,308,306,
303,300,297,294,290,287,282,278,272,268,263,257,251,245,239,232,226,219,211,
204,197,188,181,172,164,156,147,138,130,120,111,101,93,86,73,64,54,44,35,24,
5,5},
BUFcos1[64]={12,36,60,84,108,131,154,176,199,221,242,262,283,302,320,340
,355,372,387,401,415,427,438,449,458,466,473,479,484,487,489,491
,491,489,487,484,479,473,466,458,449,438,427,415,401,387,372,355
,340,320,302,283,262,242,221,199,176,154,131,108,84,60,36,12};
void Delay(int x)
{ //延时程序
while(x--);
void SCAN()
{ int i; //键盘扫描程序
// k=0;
//double M=1.0,w=2*PI*f;
PORTB=0x03;
if(PORTB!=0x03)
for(i=0;i<10;i++)
Delay(25600);
if(PORTBbits.RB0==0) //S2定义为增
f=f+20;
if(f>=300)
f=20;
else if(PORTBbits.RB1==0) //S3定义为减
f=f-20;
if(f<=20)
f=300;
void Pulse_Width(void)
int k=0;
for(k=10;k<90;k++)
PTPER=25700;
/*~~~~~~ Load PDC1 register with initial Duty Cycle value ~~~~~~~~~~*/
//Pul=(M/w)*(cos((k-1)*PI/N)-cos(k*PI/N));
PDC1=Pul*256*1000000;
//PDC1=(0.3183*BUFcos1[k]*256);
Delay(25600);
void Pulse_Config()
TRISE=0x00;
FCLCON1=0X0003;
/*~~~~~~~~~~~~~~~~~~~~~~~ PWM1 Configuration ~~~~~~~~~~~~~~~~~~~~~~~~~~~~*/
/* PWM1 I/O Control Register register /
IOCON1bits.PENH = 1; /* PWM1H is controlled by PWM module */
IOCON1bits.PENL = 1; /* PWM1L is co*ntrolled by PWM module */
IOCON1bits.PMOD = 0; /* Select Independent Output PWM mode */
IOCON1bits.POLH = 0;
/* Load PDTR1 and ALTDTR2 register with preset dead time value */
DTR1 = 64; /* Deadtime setting */
ALTDTR1 = 64; /* Deadtime setting */
/* PHASE1 register */
PHASE1 = 0; /* No phase shift */
/* Configure PTPER register to produce ??kHz PWM frequency */
// PTPER = 0x4e20; /* PWM Period @30 MIPS, 2.5usec?? == 400kHz?? */
/* PWM Time Base Control Register */
PTCONbits.PTEN = 1; // Enable the PWM Module
PTCONbits.EIPU = 1; //立即更新有效周期寄存器
PWMCON1bits.IUE = 1; //立即对有效的pdc寄存器进行更新
int main(void)
N=100,f=50;
Pul=0;
T2CON=0X8000;
ADPCFG=0xffff;
TRISB=0x0003;
PORTB=0x00;
Pulse_Config();
while(1)
//SCAN();
Pulse_Width();
视力不良|  楼主 | 2008-5-15 12:08 | 只看该作者
回复主题:pic30f2020,我做了一个程序大家帮忙看看
有人回答么  出来的方波随周期在变化 从大到小 从小到大 但是 后级接什么样的滤波才能出现正弦波呢
