ICD2调试时出现ICD2 0116错误怎样解决
4084|10
 楼主| youss 发表于 2008-5-20 17:09 | 显示全部楼层 |阅读模式
ICD2调试时出现ICD2 0116错误,每运行一次就出现,但能工作!
jetson001 发表于 2008-5-21 09:19 | 显示全部楼层
11111111111
双击一下错误行,可以调出帮助菜单
richardvip 发表于 2008-5-21 09:33 | 显示全部楼层
把错误写出来呀,我们也好帮你看看
 楼主| youss 发表于 2008-5-21 10:18 | 显示全部楼层
ICD0116: MPLAB ICD 2 is busy
<br />ICD0116:&nbsp;MPLAB&nbsp;ICD&nbsp;2&nbsp;is&nbsp;busy<br />ICD0116:&nbsp;MPLAB&nbsp;ICD&nbsp;2&nbsp;is&nbsp;busy<br /><br />调试模式每运行一个命令就出现,但能工作!编程模式没有,<br /><br />好象是通信不正常,不知哪里引起,我将usb驱动都重装了,还是不行!
 楼主| youss 发表于 2008-5-21 10:37 | 显示全部楼层
怎么解决
ICD0116:&nbsp;MPLAB&nbsp;ICD&nbsp;2&nbsp;is&nbsp;busy&nbsp;<br /><br />MPLAB&nbsp;ICD&nbsp;2&nbsp;has&nbsp;been&nbsp;asked&nbsp;to&nbsp;perform&nbsp;an&nbsp;operation&nbsp;while&nbsp;it&nbsp;is&nbsp;busy&nbsp;servicing&nbsp;a&nbsp;prior&nbsp;request.&nbsp;For&nbsp;example,&nbsp;you&nbsp;may&nbsp;start&nbsp;a&nbsp;program&nbsp;operation&nbsp;and&nbsp;then&nbsp;attempt&nbsp;to&nbsp;step&nbsp;before&nbsp;the&nbsp;program&nbsp;operation&nbsp;is&nbsp;completed.&nbsp;<br /><br />Close&nbsp;the&nbsp;SFR&nbsp;or&nbsp;GPR&nbsp;windows.&nbsp;This&nbsp;situation&nbsp;will&nbsp;not&nbsp;normally&nbsp;happen&nbsp;as&nbsp;the&nbsp;MPLAB&nbsp;ICD&nbsp;2&nbsp;user&nbsp;interfaces&nbsp;will&nbsp;be&nbsp;disabled&nbsp;while&nbsp;servicing&nbsp;requests.&nbsp;The&nbsp;most&nbsp;common&nbsp;occurrence&nbsp;of&nbsp;this&nbsp;error&nbsp;is&nbsp;when&nbsp;MPLAB&nbsp;ICD&nbsp;2&nbsp;is&nbsp;being&nbsp;restarted&nbsp;(perhaps&nbsp;because&nbsp;a&nbsp;project&nbsp;has&nbsp;been&nbsp;opened)&nbsp;as&nbsp;both&nbsp;a&nbsp;programmer&nbsp;and&nbsp;a&nbsp;debugger&nbsp;simultaneously.&nbsp;<br />
richardvip 发表于 2008-5-21 12:35 | 显示全部楼层
这个应该属于正常,我也遇到过
我觉得是你在调试时,察看变量或是寄存器,一般就会这样,不影响调试
 楼主| youss 发表于 2008-5-21 16:23 | 显示全部楼层
编译时不正常
在对同一项目调试时,重新打开项目不对芯片编程(程序没改,不理会0015错误)就不会有问题,一旦对芯片进行编程操作后就出现!<br /><br />关键是对项目编译后&nbsp;BUSY&nbsp;灯要闪30几秒后才能正常工作!
hongye7390 发表于 2008-5-21 16:59 | 显示全部楼层
试试
调出帮助菜单
 楼主| youss 发表于 2008-5-22 10:47 | 显示全部楼层
问题解决,想不明白!
每执行一个调试命令,都有二行ICD0116提示,可正常工作,<br />&nbsp;&nbsp;&nbsp;&nbsp;在对同一个项目调试时,重新打开项目不对芯片下载编程(程序没有改变,不理会0015错误),不会有该问题,下载后就有这个错误,但可正常工作,关键是对项目编译后&nbsp;BUSY&nbsp;灯要闪40秒后才能正常工作!<br />&nbsp;&nbsp;&nbsp;&nbsp;关闭“Special&nbsp;Function&nbsp;Registers”观察窗口后正常,&nbsp;&nbsp;&nbsp;可打开数据量更大的“File&nbsp;Registers”观察窗口倒不会出现问题,ICD换了一个同样,是IDE软件文题?<br />&nbsp;&nbsp;&nbsp;&nbsp;现使用版本8.02,&nbsp;在7.62版本用也有同样文题!&nbsp;&nbsp;&nbsp;&nbsp;请大家测试一下有同样问题么?<br />
兰天白云 发表于 2008-5-22 19:53 | 显示全部楼层
哪里生产的ICD2?
su_mj000 发表于 2008-5-25 06:15 | 显示全部楼层
用示波器看看线上的信号波形,
