我加了LCD显示后发现整个程序大于16K了,编辑出错,但我的程序最多只有3K,为什么会超过16K的,我用的是18F4423,请大哥指教一下, 部分程序如下:<br />#pragma code<br /><br />unsigned char StepCount; <br /><br /><br />unsigned char receive_buff; <br /><br />unsigned char ad_chanel; <br /> <br /><br />unsigned short long a164; //0x98 0x99 0x9a<br /><br />unsigned int AD_total;<br />unsigned char rx_232_cnt; //@0xa0<br />char rx_232_buf; //0x102<br />unsigned short long a164_buf;<br />signed long kb;<br />int MixPrecent;<br />int MaxPrecent;<br />int Res;<br />char Sign;<br />unsigned char Time0_cnt;<br /><br />char ResResult[6];<br /><br />unsigned char Disp_Data_Buff[16];<br />unsigned char ResultSign[13];<br />unsigned char ReadBCD[18];<br />unsigned int AD_Up_DATA[4];<br />unsigned int AD_DOWN_DATA[4];<br />unsigned int AD_LEFT_DATA[4];<br />unsigned int AD_RIGHT_DATA[4];<br /><br />unsigned char sin[6]=<br />{97,98,99,100,101,35};<br />#pragma code<br />/*-- 文字: 上 --*/<br />/*-- 宋体11; 此字体下对应的点阵为:宽x高=14x14 --*/<br />/*-- 高度不是8的倍数,现调整为:宽度x高度=14x16 --*/<br /><br />unsigned rom far char up_array[28]={<br />0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x10,0x10,0x10,0x10,0x00,0x00,0x00,<br />0x10,0x10,0x10,0x10,0x10,0x10,0x1f,0x10,0x10,0x10,0x10,0x10,0x10,0x00<br />};<br />unsigned rom far char seun_array[28]={<br />0xFf,0x01,0x11,0x2d,0xc3,0x00,0xff,0x49,0x49,0x49,0xc9,0x7f,0x00,0x00,<br />0x1f,0x02,0x04,0x02,0x01,0x00,0x1f,0x09,0x02,0x05,0x08,0x18,0x08,0x00<br />};<br />unsigned rom far char down_array[28]={<br />0x01,0x01,0x01,0x01,0x01,0xff,0x01,0x11,0x21,0x41,0xc1,0x01,0x01,0x00,<br />0x00,0x00,0x00,0x00,0x00,0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00<br />};<br /><br />unsigned rom far char dot_array[12]={<br />0x00,0x00,0x18,0x18,0x00,0x00,<br />0x00,0x00,0x03,0x03,0x00,0x00<br />};<br /><br />unsigned rom far char Big_0_array[14]={<br />0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,<br />0x03,0x04,0x08,0x08,0x04,0x03,0x00<br /><br />};<br /><br />unsigned rom far char Big_1_array[14]={<br />0x00,0x10,0x10,0xF8,0x00,0x00,0x00,<br />0x00,0x08,0x08,0x0F,0x08,0x08,0x00<br />};<br />unsigned rom far char Big_2_array[14]={<br />0x00,0x30,0x08,0x08,0x88,0x70,0x00,<br />0x00,0x0C,0x0A,0x09,0x08,0x0C,0x00<br />};<br />unsigned rom far char Big_3_array[14]={<br />0x00,0x30,0x08,0x48,0x48,0xB0,0x00,<br />0x00,0x06,0x08,0x08,0x08,0x07,0x00<br />};<br />unsigned rom far char Big_4_array[14]={<br />0x00,0xC0,0x20,0x10,0xFC,0x00,0x00,<br />0x01,0x02,0x02,0x0A,0x0F,0x0A,0x00<br />};<br />unsigned rom far char Big_5_array[14]={<br />0x00,0xF8,0x48,0x48,0x48,0x88,0x00,<br />0x00,0x06,0x08,0x08,0x08,0x07,0x00<br />};<br />unsigned rom far char Big_6_array[14]={<br />0xE0,0x90,0x48,0x48,0x48,0x98,0x00,<br />0x07,0x08,0x08,0x08,0x08,0x07,0x00<br />};<br />unsigned rom far char Big_7_array[14]={<br />0x00,0x38,0x08,0x88,0x68,0x18,0x00,<br />0x00,0x00,0x00,0x0F,0x00,0x00,0x00<br />};<br />unsigned rom far char Big_8_array[14]={<br />0x30,0xC8,0x88,0x88,0xC8,0x30,0x00,<br />0x07,0x08,0x08,0x08,0x08,0x07,0x00<br />};<br />unsigned rom far char Big_9_array[14]={<br />0xF0,0x08,0x08,0x08,0x88,0xF0,0x00,<br />0x0C,0x09,0x09,0x09,0x04,0x03,0x00<br />};<br />unsigned rom far char Big_dot_array[6]={<br />0x00,0x00,0x00,<br />0x00,0x0C,0x0C<br />};<br />unsigned rom far char Big_small_array[4]={<br />0x00,0x60,0x60,0x00<br />};<br />unsigned rom far char Small_N1_array[8]={<br />0x00,0x84,0xfe,0x80,0x00,0x00,0x00,0x7F};<br />unsigned rom far char Small_N2_array[8]={<br />0x00,0xC4,0xA2,0x92,0x8C,0x00,0x00,0x7F};<br />unsigned rom far char Small_N3_array[8]={<br />0x00,0x44,0x92,0x92,0x6c,0x00,0x00,0x7f};<br />unsigned rom far char Small_N4_array[8]={<br />0x30,0x28,0x24,0xfe,0x20,0x00,0x00,0x7f};<br />unsigned rom far char Small_0_array[6]={<br />0x00,0x7c,0x82,0x82,0x7c,0x00};<br />unsigned rom far char Small_1_array[6]={<br />0x00,0x84,0xfe,0x80,0x0,0x00};<br />unsigned rom far char Small_2_array[6]={<br />0x00,0xc4,0xa2,0x92,0x8c,0x00};<br />unsigned rom far char Small_3_array[6]={<br />0x00,0x44,0x92,0x92,0x6c,0x00};<br />unsigned rom far char Small_4_array[6]={<br />0x30,0x28,0x24,0xfe,0x20,0x00};<br />unsigned rom far char Small_5_array[6]={<br />0x00,0x4e,0x8a,0x8a,0x72,0x00};<br />unsigned rom far char Small_6_array[6]={<br />0x7c,0x92,0x92,0x92,0x60,0x00};<br />unsigned rom far char Small_7_array[6]={<br />0x00,0x02,0xf2,0x0a,0x06,0x00};<br />unsigned rom far char Small_8_array[6]={<br />0x00,0x6c,0x92,0x92,0x6c,0x00};<br />unsigned rom far char Small_9_array[6]={<br />0x00,0x0c,0x92,0x92,0x7c,0x00};<br /><br /><br /><br />#pragma code <br /><br />void main(void){<br /> Delay1KTCYx(200); //40ms<br /> Init(); <br /> GetBCD();<br /> GetBCD();<br /> GetBCD(); <br /> LCD_Init();<br /> while(1){ <br /> StartSing();<br /><br /> if(F0.Bit.START)ad_action();<br /><br /> if(F0.Bit.Send_PC)SendRS232();<br /> <br /> if(F1.Bit.Send_PLC)SendPLC();<br /><br /> // Disp_Result();<br /> }<br />}<br /><br />。。。。。。。<br />。。。。。。。<br />下面一共有2000行的程序。。程序应该不可能会超过16K的,请高手指点。。。<br /><br /> <br /> |
