[STM32F0] STM32F030的time外部上升沿复位计数器
1903|1
 楼主| czt520523 发表于 2015-1-7 20:54 | 显示全部楼层 |阅读模式
    各位大神,我刚用这款单片机,配置后老是出错,麻烦大神指点!
   TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0;
  TIM_ICInit(TIM3, &TIM_ICInitStructure);
TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2);
  TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Gated);
fanxsd 发表于 2015-1-8 10:22 | 显示全部楼层
  1.   /*PWM 脉冲捕获 */
  2. void TIM2_IN_Config(void)
  3. {
  4.         GPIO_InitTypeDef    GPIO_InitStruct;
  5.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  6.           /* Configure PA.00  as pwm input */
  7.   GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0;
  8.   GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF;
  9.   GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  10.   GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  11.   GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP ;
  12.   GPIO_Init(GPIOA, &GPIO_InitStruct);                                // PA0,输入时不用设置速率
  13.
  14.           /* Connect TIM pin to AF2 */
  15.   GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_2);
  16.
  17.           /* Time 定时器基础设置 */
  18.   TIM_TimeBaseStructure.TIM_Period = 65535;
  19.   TIM_TimeBaseStructure.TIM_Prescaler = 47;
  20.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  21.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  22.   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  23.
  24.   TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;                            //选择通道1
  25.   TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;                 //输入上升沿捕获
  26.   TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;  //配置通道与寄存器直接对应
  27.   TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;                       //输入捕获预分频值
  28.   TIM_ICInitStructure.TIM_ICFilter = 0x0;                                      //输入滤波器带宽设置
  29.   TIM_ICInit(TIM2, &TIM_ICInitStructure);                                     //输入通道配置
  30.
  31.   TIM_SelectInputTrigger(TIM2, TIM_TS_TI1FP1);                                //输入触发源选择
  32.
  33.   TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);                             //从模式选择
  34.   TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);                //主从模式选择
  35.
  36.         TIM_Cmd(TIM2, ENABLE);                           //使能TIM2计数器
  37.         TIM_ITConfig(TIM2, TIM_IT_Trigger, ENABLE);          //使能CC1中断请求
  38.
  39. }
这个是我 051 的配置,你参考一下
评分
参与人数 1威望 +1 收起 理由
czt520523 + 1 赞一个!
查看全部评分
