picc v9.65调用深度查看问题
 楼主| 发表于 2009-5-18 23:06 | 显示全部楼层 |阅读模式
pic, ABS, TE, AN
有没有谁注意过这个问题,PICC&nbsp;V9.65(FOR&nbsp;pic12/16)生成的*.map文件看不到调用深度:(Call&nbsp;graph:&nbsp;(short&nbsp;form)处)&nbsp;<br />HI-TECH&nbsp;Software&nbsp;C&nbsp;Compiler&nbsp;&nbsp;<br /><br />Linker&nbsp;command&nbsp;line:&nbsp;<br /><br />--edf=C:Program&nbsp;FilesHI-TECH&nbsp;SoftwarePICCPRO9.65daten_msgs.txt&nbsp;-cs&nbsp;&nbsp;<br />&nbsp;&nbsp;-h+TEST.sym&nbsp;-z&nbsp;-Q16F723&nbsp;-ol.obj&nbsp;-MTEST.map&nbsp;-E1&nbsp;-ACODE=00h-07FFhx2&nbsp;&nbsp;<br />&nbsp;&nbsp;-ACONST=00h-0FFhx16&nbsp;-AENTRY=00h-0FFhx16&nbsp;-ASTRING=00h-0FFhx16&nbsp;&nbsp;<br />&nbsp;&nbsp;-ARAM=020h-06Fh,0A0h-0EFh,0120h-012Fh&nbsp;&nbsp;<br />&nbsp;&nbsp;-AABS1=020h-07Fh,0A0h-0EFh,0120h-012Fh&nbsp;-ABANK0=020h-07Fh&nbsp;&nbsp;<br />&nbsp;&nbsp;-ABANK1=0A0h-0EFh&nbsp;-ABANK2=0120h-012Fh&nbsp;-ACOMMON=070h-07Fh&nbsp;&nbsp;<br />&nbsp;&nbsp;-preset_vec=00h,intentry,intcode,intret,init,init23,end_init,clrtext,maintext,pstrings&nbsp;&nbsp;<br />&nbsp;&nbsp;-pstrings=CODE&nbsp;-ppowerup=CODE&nbsp;-ptemp=-COMMON&nbsp;-pcommon=-COMMON&nbsp;&nbsp;<br />&nbsp;&nbsp;-prbss_0=BANK0,rbit_0=BANK0,rdata_0=BANK0,idata_0=CODE&nbsp;-pnvram=BANK0&nbsp;&nbsp;<br />&nbsp;&nbsp;-prbss_1=BANK1,rbit_1=BANK1,rdata_1=BANK1,idata_1=CODE&nbsp;&nbsp;<br />&nbsp;&nbsp;-pnvram_1=BANK1,nvbit_1=BANK1&nbsp;&nbsp;<br />&nbsp;&nbsp;-prbss_2=BANK2,rbit_2=BANK2,rdata_2=BANK2,idata_2=CODE&nbsp;&nbsp;<br />&nbsp;&nbsp;-pnvram_2=BANK2,nvbit_2=BANK2&nbsp;-pidata=CODE&nbsp;-pfnautoc=COMMON&nbsp;&nbsp;<br />&nbsp;&nbsp;-pfnauto0=BANK0&nbsp;-pfnauto1=BANK1&nbsp;-pfnauto2=BANK2&nbsp;-ACONFIG=02007h-02008h&nbsp;&nbsp;<br />&nbsp;&nbsp;-pconfig=CONFIG&nbsp;-DCONFIG=2&nbsp;-AIDLOC=02000h-02003h&nbsp;-pidloc=IDLOC&nbsp;-DIDLOC=2&nbsp;&nbsp;<br />&nbsp;&nbsp;-pfloat_text0=CODE,float_text1=CODE,float_text2=CODE&nbsp;&nbsp;<br />&nbsp;&nbsp;-pfloat_text3=CODE,float_text4=CODE&nbsp;-DCODE=2&nbsp;startup.obj&nbsp;TEST.obj&nbsp;&nbsp;<br /><br />Object&nbsp;code&nbsp;version&nbsp;is&nbsp;3.10&nbsp;<br /><br />Machine&nbsp;type&nbsp;is&nbsp;16F723&nbsp;<br /><br />Call&nbsp;graph:&nbsp;(short&nbsp;form)&nbsp;<br /><br /><br /><br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Link&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Load&nbsp;&nbsp;&nbsp;Length&nbsp;Selector&nbsp;&nbsp;&nbsp;Space&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Scale&nbsp;<br />startup.obj&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end_init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br />TEST.obj&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;4&nbsp;&nbsp;&nbsp;&nbsp;4000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text37&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;7FA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;7FA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FF4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br /><br />COMMON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br /><br />TOTAL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Link&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Load&nbsp;&nbsp;&nbsp;Length&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Space&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;CODE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end_init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text37&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;7FA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;7FA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;CONST&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;ENTRY&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;STRING&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;RAM&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;ABS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;BANK0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;BANK1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;BANK2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;COMMON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;CONFIG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;IDLOC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;EEDATA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CLASS&nbsp;&nbsp;&nbsp;BANK3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br /><br /><br />SEGMENTS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Load&nbsp;&nbsp;&nbsp;&nbsp;Length&nbsp;&nbsp;&nbsp;Top&nbsp;&nbsp;&nbsp;&nbsp;Selector&nbsp;&nbsp;&nbsp;&nbsp;Space&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Class&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Delta&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;reset_vec&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000000&nbsp;&nbsp;000006&nbsp;&nbsp;000006&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;CODE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;temp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000070&nbsp;&nbsp;000001&nbsp;&nbsp;000071&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;70&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;&nbsp;COMMON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text37&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0007FA&nbsp;&nbsp;000006&nbsp;&nbsp;000800&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;FF4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;CODE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002000&nbsp;&nbsp;000004&nbsp;&nbsp;002004&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;4000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0&nbsp;&nbsp;IDLOC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;<br /><br /><br />UNUSED&nbsp;ADDRESS&nbsp;RANGES&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BANK0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020-006F&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071-007F&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BANK1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0-00EF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;BANK2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120-012F&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CODE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006-07F9&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0800-0FFF&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;COMMON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071-007F&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CONFIG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2007-2008&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CONST&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C-0FF3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ENTRY&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C-0FF3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;RAM&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020-006F&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0-00EF&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120-012F&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;STRING&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C-0FF3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;1&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Symbol&nbsp;Table&nbsp;<br /><br />??_delay&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;&nbsp;??_main&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />?_delay&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;&nbsp;?_main&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />_ADCON0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001F&nbsp;&nbsp;_ADCON1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;009F&nbsp;<br />_ADCS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04FC&nbsp;&nbsp;_ADCS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04FD&nbsp;<br />_ADCS2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04FE&nbsp;&nbsp;_ADDEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C3&nbsp;<br />_ADFVR0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04E8&nbsp;&nbsp;_ADFVR1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04E9&nbsp;<br />_ADGO&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00F9&nbsp;&nbsp;_ADIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0466&nbsp;<br />_ADIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0066&nbsp;&nbsp;_ADON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00F8&nbsp;<br />_ADREF0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04F8&nbsp;&nbsp;_ADREF1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04F9&nbsp;<br />_ADRES&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001E&nbsp;&nbsp;_ANSA0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C28&nbsp;<br />_ANSA1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C29&nbsp;&nbsp;_ANSA2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C2A&nbsp;<br />_ANSA3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C2B&nbsp;&nbsp;_ANSA4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C2C&nbsp;<br />_ANSA5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C2D&nbsp;&nbsp;_ANSB0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C30&nbsp;<br />_ANSB1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C31&nbsp;&nbsp;_ANSB2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C32&nbsp;<br />_ANSB3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C33&nbsp;&nbsp;_ANSB4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C34&nbsp;<br />_ANSB5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C35&nbsp;&nbsp;_ANSELA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0185&nbsp;<br />_ANSELB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0186&nbsp;&nbsp;_APFCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;009C&nbsp;<br />_BF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A0&nbsp;&nbsp;_BOR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0470&nbsp;<br />_BRG0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C8&nbsp;&nbsp;_BRG1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C9&nbsp;<br />_BRG2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CA&nbsp;&nbsp;_BRG3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CB&nbsp;<br />_BRG4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CC&nbsp;&nbsp;_BRG5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CD&nbsp;<br />_BRG6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CE&nbsp;&nbsp;_BRG7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04CF&nbsp;<br />_BRGH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C2&nbsp;&nbsp;_CARRY&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0018&nbsp;<br />_CCP1CON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0017&nbsp;&nbsp;_CCP1IE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0462&nbsp;<br />_CCP1IF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0062&nbsp;&nbsp;_CCP1M0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00B8&nbsp;<br />_CCP1M1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00B9&nbsp;&nbsp;_CCP1M2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00BA&nbsp;<br />_CCP1M3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00BB&nbsp;&nbsp;_CCP2CON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001D&nbsp;<br />_CCP2IE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0468&nbsp;&nbsp;_CCP2IF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0068&nbsp;<br />_CCP2M0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00E8&nbsp;&nbsp;_CCP2M1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00E9&nbsp;<br />_CCP2M2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00EA&nbsp;&nbsp;_CCP2M3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00EB&nbsp;<br />_CCP2SEL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04E0&nbsp;&nbsp;_CCPR1H&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0016&nbsp;<br />_CCPR1L&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0015&nbsp;&nbsp;_CCPR2H&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001C&nbsp;<br />_CCPR2L&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001B&nbsp;&nbsp;_CHS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00FA&nbsp;<br />_CHS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00FB&nbsp;&nbsp;_CHS2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00FC&nbsp;<br />_CHS3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00FD&nbsp;&nbsp;_CKE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A6&nbsp;<br />_CKP&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A4&nbsp;&nbsp;_CPSCH0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0848&nbsp;<br />_CPSCH1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0849&nbsp;&nbsp;_CPSCH2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;084A&nbsp;<br />_CPSCH3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;084B&nbsp;&nbsp;_CPSCON0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0108&nbsp;<br />_CPSCON1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0109&nbsp;&nbsp;_CPSON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0847&nbsp;<br />_CPSOUT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0841&nbsp;&nbsp;_CPSRNG0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0842&nbsp;<br />_CPSRNG1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0843&nbsp;&nbsp;_CREN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C4&nbsp;<br />_CSRC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C7&nbsp;&nbsp;_DA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A5&nbsp;<br />_DC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0019&nbsp;&nbsp;_DC1B0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00BC&nbsp;<br />_DC1B1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00BD&nbsp;&nbsp;_DC2B0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00EC&nbsp;<br />_DC2B1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00ED&nbsp;&nbsp;_EEADR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010D&nbsp;<br />_EEADRH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010F&nbsp;&nbsp;_EEDATA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010C&nbsp;<br />_EEDATH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010E&nbsp;&nbsp;_FERR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C2&nbsp;<br />_FSR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0004&nbsp;&nbsp;_FVRCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;009D&nbsp;<br />_FVREN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04EE&nbsp;&nbsp;_FVRRDY&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04EF&nbsp;<br />_GIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005F&nbsp;&nbsp;_GODONE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00F9&nbsp;<br />_ICSL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0483&nbsp;&nbsp;_ICSS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0482&nbsp;<br />_INDF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;_INTCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000B&nbsp;<br />_INTE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005C&nbsp;&nbsp;_INTEDG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040E&nbsp;<br />_INTF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0059&nbsp;&nbsp;_IOCB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0096&nbsp;<br />_IOCB0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B0&nbsp;&nbsp;_IOCB1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B1&nbsp;<br />_IOCB2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B2&nbsp;&nbsp;_IOCB3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B3&nbsp;<br />_IOCB4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B4&nbsp;&nbsp;_IOCB5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B5&nbsp;<br />_IOCB6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B6&nbsp;&nbsp;_IOCB7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04B7&nbsp;<br />_IRCF0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0484&nbsp;&nbsp;_IRCF1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0485&nbsp;<br />_IRP&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001F&nbsp;&nbsp;_OERR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C1&nbsp;<br />_OPTION&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0081&nbsp;&nbsp;_OSCCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0090&nbsp;<br />_OSCTUNE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0091&nbsp;&nbsp;_PCL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;<br />_PCLATH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000A&nbsp;&nbsp;_PCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;008E&nbsp;<br />_PD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001B&nbsp;&nbsp;_PEIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005E&nbsp;<br />_PIE1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;008C&nbsp;&nbsp;_PIE2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;008D&nbsp;<br />_PIR1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;_PIR2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000D&nbsp;<br />_PMADRH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010F&nbsp;&nbsp;_PMADRL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010D&nbsp;<br />_PMCON1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;018C&nbsp;&nbsp;_PMDATH&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010E&nbsp;<br />_PMDATL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;010C&nbsp;&nbsp;_POR&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0471&nbsp;<br />_PORTA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0005&nbsp;&nbsp;_PORTB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />_PORTC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0007&nbsp;&nbsp;_PORTE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0009&nbsp;<br />_PR2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0092&nbsp;&nbsp;_PS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0408&nbsp;<br />_PS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0409&nbsp;&nbsp;_PS2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040A&nbsp;<br />_PSA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040B&nbsp;&nbsp;_RA0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0028&nbsp;<br />_RA1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0029&nbsp;&nbsp;_RA2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002A&nbsp;<br />_RA3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002B&nbsp;&nbsp;_RA4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002C&nbsp;<br />_RA5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002D&nbsp;&nbsp;_RA6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002E&nbsp;<br />_RA7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;002F&nbsp;&nbsp;_RABIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005B&nbsp;<br />_RABIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0058&nbsp;&nbsp;_RABPU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040F&nbsp;<br />_RB0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0030&nbsp;&nbsp;_RB1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0031&nbsp;<br />_RB2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0032&nbsp;&nbsp;_RB3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0033&nbsp;<br />_RB4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0034&nbsp;&nbsp;_RB5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0035&nbsp;<br />_RB6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0036&nbsp;&nbsp;_RB7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0037&nbsp;<br />_RBIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005B&nbsp;&nbsp;_RBIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0058&nbsp;<br />_RBPU&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040F&nbsp;&nbsp;_RC0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0038&nbsp;<br />_RC1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0039&nbsp;&nbsp;_RC2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003A&nbsp;<br />_RC3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003B&nbsp;&nbsp;_RC4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003C&nbsp;<br />_RC5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003D&nbsp;&nbsp;_RC6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003E&nbsp;<br />_RC7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;003F&nbsp;&nbsp;_RCIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0465&nbsp;<br />_RCIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0065&nbsp;&nbsp;_RCREG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001A&nbsp;<br />_RCSTA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0018&nbsp;&nbsp;_RD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0C60&nbsp;<br />_RE3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;004B&nbsp;&nbsp;_RP0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001D&nbsp;<br />_RP1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001E&nbsp;&nbsp;_RW&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A2&nbsp;<br />_RX9&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C6&nbsp;&nbsp;_RX9D&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C0&nbsp;<br />_SMP&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A7&nbsp;&nbsp;_SPBRG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0099&nbsp;<br />_SPEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C7&nbsp;&nbsp;_SREN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00C5&nbsp;<br />_SSPADD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0093&nbsp;&nbsp;_SSPBUF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0013&nbsp;<br />_SSPCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0014&nbsp;&nbsp;_SSPEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A5&nbsp;<br />_SSPIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0463&nbsp;&nbsp;_SSPIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0063&nbsp;<br />_SSPM0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;&nbsp;_SSPM1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A1&nbsp;<br />_SSPM2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A2&nbsp;&nbsp;_SSPM3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A3&nbsp;<br />_SSPMSK&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0093&nbsp;&nbsp;_SSPOV&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A6&nbsp;<br />_SSPSTAT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0094&nbsp;&nbsp;_SSSEL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04E1&nbsp;<br />_START&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A3&nbsp;&nbsp;_STATUS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0003&nbsp;<br />_STOP&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A4&nbsp;&nbsp;_SYNC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C4&nbsp;<br />_T0CS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040D&nbsp;&nbsp;_T0IE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005D&nbsp;<br />_T0IF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;005A&nbsp;&nbsp;_T0SE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;040C&nbsp;<br />_T0XCS&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0840&nbsp;&nbsp;_T1CKPS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0084&nbsp;<br />_T1CKPS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0085&nbsp;&nbsp;_T1CON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0010&nbsp;<br />_T1GCON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;008F&nbsp;&nbsp;_T1GGO&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047B&nbsp;<br />_T1GPOL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047E&nbsp;&nbsp;_T1GSPM&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047C&nbsp;<br />_T1GSS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0478&nbsp;&nbsp;_T1GSS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0479&nbsp;<br />_T1GTM&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047D&nbsp;&nbsp;_T1GVAL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047A&nbsp;<br />_T1OSCEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0083&nbsp;&nbsp;_T1SYNC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0082&nbsp;<br />_T2CKPS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0090&nbsp;&nbsp;_T2CKPS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0091&nbsp;<br />_T2CON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0012&nbsp;&nbsp;_TMR0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0001&nbsp;<br />_TMR1CS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0086&nbsp;&nbsp;_TMR1CS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0087&nbsp;<br />_TMR1GE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;047F&nbsp;&nbsp;_TMR1GIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0467&nbsp;<br />_TMR1GIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0067&nbsp;&nbsp;_TMR1H&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000F&nbsp;<br />_TMR1IE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0460&nbsp;&nbsp;_TMR1IF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;<br />_TMR1L&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000E&nbsp;&nbsp;_TMR1ON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0080&nbsp;<br />_TMR2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0011&nbsp;&nbsp;_TMR2IE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0461&nbsp;<br />_TMR2IF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0061&nbsp;&nbsp;_TMR2ON&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0092&nbsp;<br />_TO&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001C&nbsp;&nbsp;_TOUTPS0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0093&nbsp;<br />_TOUTPS1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0094&nbsp;&nbsp;_TOUTPS2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0095&nbsp;<br />_TOUTPS3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0096&nbsp;&nbsp;_TRISA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0085&nbsp;<br />_TRISA0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0428&nbsp;&nbsp;_TRISA1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0429&nbsp;<br />_TRISA2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042A&nbsp;&nbsp;_TRISA3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042B&nbsp;<br />_TRISA4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042C&nbsp;&nbsp;_TRISA5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042D&nbsp;<br />_TRISA6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042E&nbsp;&nbsp;_TRISA7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;042F&nbsp;<br />_TRISB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0086&nbsp;&nbsp;_TRISB0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0430&nbsp;<br />_TRISB1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0431&nbsp;&nbsp;_TRISB2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0432&nbsp;<br />_TRISB3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0433&nbsp;&nbsp;_TRISB4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0434&nbsp;<br />_TRISB5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0435&nbsp;&nbsp;_TRISB6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0436&nbsp;<br />_TRISB7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0437&nbsp;&nbsp;_TRISC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0087&nbsp;<br />_TRISC0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0438&nbsp;&nbsp;_TRISC1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0439&nbsp;<br />_TRISC2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043A&nbsp;&nbsp;_TRISC3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043B&nbsp;<br />_TRISC4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043C&nbsp;&nbsp;_TRISC5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043D&nbsp;<br />_TRISC6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043E&nbsp;&nbsp;_TRISC7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;043F&nbsp;<br />_TRISE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0089&nbsp;&nbsp;_TRISE3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;044B&nbsp;<br />_TRMT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C1&nbsp;&nbsp;_TUN0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0488&nbsp;<br />_TUN1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0489&nbsp;&nbsp;_TUN2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;048A&nbsp;<br />_TUN3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;048B&nbsp;&nbsp;_TUN4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;048C&nbsp;<br />_TUN5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;048D&nbsp;&nbsp;_TX9&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C6&nbsp;<br />_TX9D&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C0&nbsp;&nbsp;_TXEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04C5&nbsp;<br />_TXIE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0464&nbsp;&nbsp;_TXIF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0064&nbsp;<br />_TXREG&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0019&nbsp;&nbsp;_TXSTA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0098&nbsp;<br />_UA&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A1&nbsp;&nbsp;_WCOL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A7&nbsp;<br />_WPUB&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0095&nbsp;&nbsp;_WPUB0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A8&nbsp;<br />_WPUB1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04A9&nbsp;&nbsp;_WPUB2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AA&nbsp;<br />_WPUB3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AB&nbsp;&nbsp;_WPUB4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AC&nbsp;<br />_WPUB5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AD&nbsp;&nbsp;_WPUB6&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AE&nbsp;<br />_WPUB7&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;04AF&nbsp;&nbsp;_ZERO&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;001A&nbsp;<br />__Bnvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Bnvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Bnvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Bnvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Bptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Brbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020&nbsp;<br />__Brbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;&nbsp;__Brbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;<br />__Brbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Hclrtext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;clrtext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;<br />__Hcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;code&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Hcommon&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;common&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />__Hconfig&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;config&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2007&nbsp;&nbsp;__Heeprom_data&nbsp;eeprom_data&nbsp;0006&nbsp;<br />__Hend_init&nbsp;&nbsp;&nbsp;&nbsp;end_init&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;&nbsp;__Hfloat_text0&nbsp;float_text0&nbsp;0006&nbsp;<br />__Hfloat_text1&nbsp;float_text1&nbsp;0006&nbsp;&nbsp;__Hfloat_text2&nbsp;float_text2&nbsp;0006&nbsp;<br />__Hfloat_text3&nbsp;float_text3&nbsp;0006&nbsp;&nbsp;__Hfloat_text4&nbsp;float_text4&nbsp;0006&nbsp;<br />__Hfnauto0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071&nbsp;&nbsp;__Hfnauto1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Hfnauto2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Hfnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071&nbsp;<br />__Hidata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Hidata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Hidata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Hidata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Hidata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Hidloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2004&nbsp;<br />__Hinit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Hinit23&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init23&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__Hintcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Hintentry&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__Hintret&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intret&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Hintsave&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intsave&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Hintsave_1&nbsp;&nbsp;&nbsp;intsave_1&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Hintsave_2&nbsp;&nbsp;&nbsp;intsave_2&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Hintsave_3&nbsp;&nbsp;&nbsp;intsave_3&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Hmaintext&nbsp;&nbsp;&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Hnvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;&nbsp;__Hnvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0500&nbsp;<br />__Hnvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0900&nbsp;&nbsp;__Hnvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;<br />__Hnvram&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020&nbsp;&nbsp;__Hnvram_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Hnvram_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Hnvram_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Hpowerup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;powerup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Hpstrings&nbsp;&nbsp;&nbsp;&nbsp;pstrings&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Hptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;&nbsp;__Hramdata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0001&nbsp;<br />__Hrbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0100&nbsp;&nbsp;__Hrbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0500&nbsp;<br />__Hrbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0900&nbsp;&nbsp;__Hrbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;<br />__Hrbss_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020&nbsp;&nbsp;__Hrbss_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Hrbss_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Hrbss_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Hrdata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0001&nbsp;&nbsp;__Hrdata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Hrdata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Hrdata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Hreset_vec&nbsp;&nbsp;&nbsp;reset_vec&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Hstrings&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;strings&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0100&nbsp;<br />__Hstruct&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;struct&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071&nbsp;&nbsp;__Htemp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;temp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />__Htext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Lclrtext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;clrtext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;<br />__Lcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;code&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Lcommon&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;common&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />__Lconfig&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;config&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2007&nbsp;&nbsp;__Leeprom_data&nbsp;eeprom_data&nbsp;0006&nbsp;<br />__Lend_init&nbsp;&nbsp;&nbsp;&nbsp;end_init&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Lfloat_text0&nbsp;float_text0&nbsp;0006&nbsp;<br />__Lfloat_text1&nbsp;float_text1&nbsp;0006&nbsp;&nbsp;__Lfloat_text2&nbsp;float_text2&nbsp;0006&nbsp;<br />__Lfloat_text3&nbsp;float_text3&nbsp;0006&nbsp;&nbsp;__Lfloat_text4&nbsp;float_text4&nbsp;0006&nbsp;<br />__Lfnauto0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071&nbsp;&nbsp;__Lfnauto1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Lfnauto2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnauto2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Lfnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />__Lidata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Lidata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Lidata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Lidata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Lidata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Lidloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;<br />__Linit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Linit23&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init23&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__Lintcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intcode&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Lintentry&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__Lintret&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intret&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Lintsave&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intsave&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Lintsave_1&nbsp;&nbsp;&nbsp;intsave_1&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Lintsave_2&nbsp;&nbsp;&nbsp;intsave_2&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Lintsave_3&nbsp;&nbsp;&nbsp;intsave_3&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__Lmaintext&nbsp;&nbsp;&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;<br />__Lnvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;&nbsp;__Lnvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0500&nbsp;<br />__Lnvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0900&nbsp;&nbsp;__Lnvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;<br />__Lnvram&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020&nbsp;&nbsp;__Lnvram_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Lnvram_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Lnvram_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;nvram_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Lpowerup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;powerup&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__Lpstrings&nbsp;&nbsp;&nbsp;&nbsp;pstrings&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__Lptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ptbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;&nbsp;__Lramdata&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__Lrbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0100&nbsp;&nbsp;__Lrbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0500&nbsp;<br />__Lrbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0900&nbsp;&nbsp;__Lrbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbit_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0060&nbsp;<br />__Lrbss_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0020&nbsp;&nbsp;__Lrbss_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Lrbss_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Lrbss_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rbss_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Lrdata_0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Lrdata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;00A0&nbsp;<br />__Lrdata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__Lrdata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;rdata_3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;<br />__Lreset_vec&nbsp;&nbsp;&nbsp;reset_vec&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;__Lstrings&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;strings&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0100&nbsp;<br />__Lstruct&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;struct&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0071&nbsp;&nbsp;__Ltemp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;temp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;<br />__Ltext&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;000C&nbsp;&nbsp;__S0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2007&nbsp;<br />__S1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0120&nbsp;&nbsp;__databank&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />__end_of_delay&nbsp;text38&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;&nbsp;__end_of_main&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;0006&nbsp;<br />__tempreg&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(abs)&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;&nbsp;_delay&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;text37&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;07FA&nbsp;<br />_delay_i&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;fnautoc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0070&nbsp;&nbsp;_exit&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />_main&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;maintext&nbsp;&nbsp;&nbsp;&nbsp;0002&nbsp;&nbsp;idloc_word&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;idloc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2000&nbsp;<br />intlevel0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;intlevel1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />intlevel2&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;intlevel3&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />intlevel4&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;intlevel5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;intentry&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />reset_vec&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;reset_vec&nbsp;&nbsp;&nbsp;0000&nbsp;&nbsp;start&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;init&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0000&nbsp;<br />
发表于 2009-5-19 09:03 | 显示全部楼层
其实调用了多深,最清楚的就是软件设计者自己
如果你自己对此没有开销预算的话,能否成功那只能看运气了。。。
发表于 2009-5-19 09:57 | 显示全部楼层
设置
打开Build&nbsp;Option,在Linker界面的右侧,选择Callgraph的模式为Expanded即可。
发表于 2010-3-11 16:23 | 显示全部楼层
你的PICC有16F723的chipinfo吗?
发表于 2010-3-12 13:40 | 显示全部楼层
晕死
快速回复 返回顶部 返回列表
