[Atmel] 新一代maXTouch U系列新鲜推出
1055|1
 楼主| ddllxxrr 发表于 2015-1-21 21:45 | 显示全部楼层 |阅读模式
Just in time for CES 2015, Atmel has launched its next-generation maXTouch U family, bringing the world’s first capacitive touchscreen solution to allow no compromise for designing new state-of-the-art displays and true 3D user experiences. OEMs will no longer have to worry about touch and display performance when selecting thinner stacks such as on-cell, hybrid in-cell, full in-cell touchscreens utilizing very thin film and glass substrates.
The proliferation of smart devices along with the innovation in display technologies have put many new challenging requirements on touchscreen technology. These touchscreens not only have to operate with thin noisier displays, cheaper noisier chargers and numerous environmental noise sources, but also have to work with thick gloves in cold climates, moisture in humid environments and stylus for content creation.
The maXTouch Uarchitecture is designed from the ground-up to service these requirements, enabling the highest hover distance of 25mm while cutting the touch power by 50%. This family provides full in-cell integration without requiring costly display synchronization for the OEM, enabling the fastest touch response for users compared to any competing solution today. maXTouch U series allows multi-finger operation with moisture on the screen and supports side-buttons for an easy-to-use user experience especially in camera mode. The high signal-to-noise ratio (SNR) supports very thin 1mm passive and active stylus handwriting with full palm rejection for a flawless content creation experience.
“Competing touch solutions do not have the fundamental building blocks required to support the technical demands of thinner and flexible advanced displays,” said Binay Bajaj, Atmel Senior Director of Touch Marketing. “Meeting these technological demands, the new maXTouch U family is truly a testament to the team’s innovative engineering techniques. Leading OEMs are extremely excited to use this new architecture to achieve unprecedented touch performance for next-generation products.”
The mXT874U, which will be the first sampling product in this new family, puts the latest maXTouch technology into action by adding high-voltage differential signal and a powerful maXDSP in the analog front-end. The result is unparalleled signal-to-noise ratio (SNR) that enables advanced touchscreen experiences beyond just finger touching. The mXT874U supports 25-30mm finger hover tracking, up to 5.0mm gloved touch, 1.0mm passive stylus writing, touch sensing with moisture and robust common charger noise rejection. This comprehensive array of touch features will allow you to deliver flagship next-generation mobile devices with the ultimate user interface experiences consumers crave.
https://www.youtube.com/watch?v=RkTwMaU9N58
原文链接:http://blog.atmel.com/2015/01/06/introducing-the-next-generation-maxtouch-u-family/
sgh2 发表于 2015-1-27 17:51 | 显示全部楼层
中文产品介绍,不是对上文的翻译哈,这是另一篇**。
Atmel®公司近日推出了下一代maXTouch® U系列产品,也是全球首个不会因显示设备的新颖设计而牺牲其性能的电容触摸屏解决方案。OEM厂商在选用诸如on-cell、混合in-cell、完全in-cell触摸屏等更薄的层叠结构时,再也无需担心触控和显示性能。
智能设备数量的激增结合显示技术的创新,向触摸屏技术提出了众多全新的挑战。触摸屏不仅要求能够不受噪声更大的薄显示屏、噪声更大的廉价充电器和众多环境噪声源影响正常工作,还必须能够在寒冷气候条件下满足手套触控需要、适应潮湿环境,并能支持使用触控笔书写。
maXTouch U架构可完全满足这些要求,其实现了高达25毫米的悬停操作距离,同时将触控功率削减了50%。此系列产品为OEM厂商提供了完全in-cell的集成方式,且无需成本高昂的显示同步;相比任何现有竞争解决方案,此方案可为用户提供最快速的触控响应。maXTouch U系列可在屏幕濡湿状态下实现多点触控,提供方便易用的侧方按键用户体验,特别是在摄像头模式下。其高信噪比(SNR)特性支持具有1毫米精细笔尖的有源和无源触控手写笔,并全面具备防误触功能,为用户提供流畅的书写体验。
Atmel公司触控营销高级总监Binay Bajaj表示:“其他同类触控解决方案并不具备支持更薄和柔性先进显示设备的技术需要所必须的基础构建模块。通过满足这些技术需求,全新maXTouch U系列充分证明了开发团队所具备的创新工程设计技术。领先OEM厂商非常高兴能够使用这种全新系架构,帮助其下一代触控产品实现前所未有的触控性能。”
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
