[STM32F4] Nucleo_F411RE_如何进入串口中断(求助)
2836|6
 楼主| 181wh 发表于 2015-1-30 15:51 | 显示全部楼层 |阅读模式
求助_Nucleo_F411RE_如何进入串口中断
现象是:进不了串口中断(使用Uart2)
如下是main.c
#include "stm32f4xx_hal.h"
#include "usart.h"
#include "gpio.h"
void SystemClock_Config(void);
int main(void)
        uint8_t  Receive_data[100] ;
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  while (1)
                HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);                        //ÉÁ˸LED2
                HAL_Delay(50);
                HAL_UART_Receive(&huart2,Receive_data,10,1);                 //½ÓÊÕÊý¾Ý
                HAL_UART_Transmit(&huart2,Receive_data,10,2);                //»Ø´«ÊÕµ½µÄÊý¾Ý
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  __PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 6;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  HAL_RCC_OscConfig(&RCC_OscInitStruct);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
#endif
如下是:stm32f4XX_it.c
#include "stm32f4xx.h"
#include "stm32f4xx_it.h"
extern UART_HandleTypeDef huart2;
void SysTick_Handler(void)
  HAL_IncTick();
  HAL_SYSTICK_IRQHandler();
//USART2ÖжÏÈë¿Ú
void USART2_IRQHandler(void)
        HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10, GPIO_PIN_SET);                //Èç¹û±¾ÌõÖ¸ÁîÖ´ÐУ¬PA10Öøß
  HAL_UART_IRQHandler(&huart2);
void NMI_Handler(void)
  HAL_RCC_NMI_IRQHandler();
工程文件:
STM32F411_test.rar (3.09 MB, 下载次数: 44)
 楼主| 181wh 发表于 2015-2-4 11:19 | 显示全部楼层
问题解决了,启动串口中断就可以了,谢谢各位!
北极星405 发表于 2015-2-15 09:31 | 显示全部楼层
学习了,也正在研究这个串口中断收发
搞IT的 发表于 2015-2-15 18:43 | 显示全部楼层
进来学习了。。。
搞IT的 发表于 2015-2-26 12:06 | 显示全部楼层
#include "usart.h"
#include "gpio.h"
这种头文件怎么看到源文件呀??
#include "usart.h"
#include "gpio.h"
这种头文件怎么看到源文件呀??
zh113214 发表于 2015-2-28 20:46 | 显示全部楼层
下载看看再说!!
