#include "msp430x41x.h" #include "string.h" #include "Def.h" #include "EepromAddr.h" #include "CommID.h" #include "Main.h" #include "Tariff.c" #include "Temperature.c" #include "Lcd.c" #include "I2C.c" #include "Comm.C" #include "Timer.C" void port_ini( void ) { P1OUT = P1T485; P1DIR = TX | P1T485; P1IES &=~P1IMPIN; P1IES |= P1DISPLAY; P1IE |= P1IMPIN | P1DISPLAY; P1IFG = 0; P1SEL = 0; P2DIR = 0; P2IES |= (P2UNCOVER | P2POWERCHECK | 0x20); P2IE |= (P2UNCOVER | P2POWERCHECK | 0x20); P6DIR = (P6E485 | P6LEDRATE2 | P6LEDRATE3 | P6LEDRATE4); P6OUT = (P6E485 | P6LEDRATE2 | P6LEDRATE3 | P6LEDRATE4); } void start_wdt( void ) { WDTCTL = WDT_ARST_1000; // Start WDT IFG1 &=WDTIFG; IE1 |=WDTIE; } /* void search_fee( void ) { bTmp=tar_que( &NowClk1, &TarList ); if( bTmp>3 ) bTmp=1; } */ void main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer FLL_CTL0 |= XCAP14PF; // 让 AD7416 进入掉电模式。 vars.tmpPtr[0] = 0x01; w_I2C_bytes(vars.tmpPtr,0x9E,0x01,1); new_e2prom_ini(); clk_ini(); // -- re_clk_ini(); lcd_ini(); port_ini(); vars.MetStatus=0; vars.MetStatus=BATTEST(vars.MetStatus); TimeA_ini(); vars.cFlag=0; vars.rt_Bit = 0; vars.lByte = 0; rx_cap_reseat(); start_wdt(); _EINT(); // Enable interrupts while(1) { if ( vars.Int_ID&ComInt ) // communication interrupt { ProcComm(); vars.Int_ID &=~ComInt; } if ( vars.Int_ID&BtInt ) // basic timer interrupt { ProcSec(); vars.Int_ID &=~BtInt; } if((vars.Int_ID&E2Int)&&!(vars.E2PROM_SAVE&E2BUSY)) { vars.E2PROM_SAVE |= E2BUSY; E2_Save(); vars.E2PROM_SAVE &=~E2BUSY; vars.Int_ID &=~E2Int; } _NOP(); LPM3; _NOP(); } } interrupt[BASICTIMER_VECTOR] void Basic_timer (void) { IFG1 &=WDTIFG; WDTCTL = WDT_ARST_1000; // Clear WDT if ( vars.bt_int>=63 ) { vars.bt_int=0; } else vars.bt_int++; // 以下程序为内部软件时钟温度补偿: if(vars.Flags & Temp_F) { vars.Flags &=~ Temp_F; if ( vars.bt_int>=63 ) vars.bt_int=0; else vars.bt_int++; } // if ( vars.bt_int==0 || vars.bt_int==32 ) vars.Int_ID |=BtInt; if(vars.Int_ID!=0) LPM3_EXIT; // wake CPU } interrupt[TIMERA0_VECTOR] void TA0_timer (void) { if((vars.timer0status&comovertime)==comovertime) { // vars.rt_Bit = 0; // vars.lByte = 0; rx_cap_reseat(); vars.timer0status &=~comovertime; } if(vars.timer0status==0) CCTL0 &=~CCIE; } interrupt[TIMERA1_VECTOR] void TA1_timer (void) { if ((TAIV|0x02)==0x02) { if( (vars.ComFlags & rtflag)==rtflag ) { ComFlagRAM |= sym_Comm; tx_prt(vars.rtByte[vars.lByte]); } else { switch(vars.rt_Bit) // 32.768k XT { case 0: CCTL0 &=~CCIE; CCTL1 &= ~(CAP+CM1); CCR1 =TAR+14;break; case 3:CCR1=CCR1+28;break; case 6:CCR1=CCR1+28;break; case 9:CCR1=CCR1+28;break; default:CCR1=CCR1+27;break; } vars.cFlag=0; // 清超时计时. if (vars.rt_Bit==1) { if ((P1IN&RX)==RX) goto looperr; // error return(9) else { vars.hByte = 0; vars.csByte = 0; goto loop0; } } if ((vars.rt_Bit>1)&&(vars.rt_Bit<=10)) // 7 or 8 bit: now 8 bit { if ((P1IN&RX)==RX) { vars.hByte |= 0x200; // 7 or 8 bit vars.csByte++; } vars.hByte >>=1; goto loop0; } if (vars.rt_Bit>10) // 7 or 8 bit { // COMIFGS[0] |=RB_L; // 字节结束,超时计时开始中。 vars.timer0status |= comovertime; CCR0 =TAR+0x8000; CCTL0 |= CCIE; vars.hByte &=0xFF; // 7 or 8 bit if ((vars.csByte&1)==0) goto loop1; else goto looperr; } loop0: vars.rt_Bit++; goto loopend; loop1: if((vars.lByte==0)&&(vars.hByte!=0x68)) goto looperr; ComFlagRAM |= sym_Comm; vars.rt_Bit = 0; vars.rtByte[vars.lByte]=vars.hByte; if ( vars.lByte == vars.rtByte[9]+11 ) { vars.lByte=0; CCTL0 &=~CCIE; // rtByte[rtByte[9]+11]=0; vars.Int_ID |= ComInt; } else { vars.lByte++; if(vars.lByte>42) goto looperr; } rx_cap_start(); // communication start goto loopend; looperr: vars.rt_Bit = 0; vars.lByte = 0; rx_cap_reseat(); // communication reseat loopend: _NOP(); } } if (TAIV|0x04) { CCTL2 &=~CCIFG; CCR2 =TAR+0x8000; if( !(P1IN&P1DISPLAY) ) { // if ( vars.LcdCtl.Switch==1 ) { vars.LcdCtl.Mode ^= 1; } else vars.LcdCtl.Switch++; // //LcdCtl.Mode ^= 1; } else { CCTL2 &=~CCIE; vars.LcdCtl.Switch = 0; } } } interrupt[PORT1_VECTOR] void p1_int (void) { if( (P1IFG&P1DISPLAY)!=0 ) { P1IFG &=~P1DISPLAY; CCR2 =TAR+0xFFF0; CCTL2 |= CCIE; vars.LcdCtl.SecCtr=0; if( vars.LcdCtl.PagePtr<23 ) vars.LcdCtl.PagePtr++; else vars.LcdCtl.PagePtr=0; vars.Int_ID |= KeyInt; } if( (P1IFG&P1REVP)!=0 ) { vars.CurrentRe.nTime[0]=vars.NowClk1.nMinute; vars.CurrentRe.nTime[1]=vars.NowClk1.nHour; vars.CurrentRe.nTime[2]=vars.NowClk1.nDay; vars.CurrentRe.nTime[3]=vars.NowClk1.nMonth; vars.E2PROM_SAVE |= UnCover_S; vars.Int_ID |=E2Int; P1IFG &=~P1REVP; } if( (P1IFG&P1IMPIN)!=0 ) { P1IFG &=~P1IMPIN; if (vars.PulseNum>=vars.MetConst) { vars.PulseNum=1; if((vars.Tariff.EC[0][0]&0x0F)>=9) // 电量增加 0.1,保存 { r_I2C_bytes(&vars.Tariff.EC[0][0],I2C_24CXX_P0,CuECTotal,4); vars.Tariff.EC[0][0] &= 0xF0; vars.Tariff.EC[0][0] += 0x09; vars.E2PROM_SAVE |= EC_S; vars.Int_ID |=E2Int; } if(P1IN&P1REVP) _BCD4INC((BYTE *)&vars.ECReAll[0]); _BCD4INC((BYTE *)&vars.Tariff.EC[0][0]); _BCD4INC((BYTE *)&vars.Tariff.EC[vars.bTmp+1][0]); // [vars.bTmp+1] } else _BCD1INC((BYTE *)&vars.PulseNum); } P1IFG =0; _NOP(); } interrupt[PORT2_VECTOR] void p2_int (void)/////////////////////////////////////////开盖记录 { if( P2IFG&P2UNCOVER ) { P2IFG &=~P2UNCOVER; vars.UnCover.nTime[1][0]=vars.UnCover.nTime[0][0]; vars.UnCover.nTime[1][1]=vars.UnCover.nTime[0][1]; vars.UnCover.nTime[1][2]=vars.UnCover.nTime[0][2]; vars.UnCover.nTime[1][3]=vars.UnCover.nTime[0][3]; vars.UnCover.nTime[0][0]=vars.NowClk1.nMinute; vars.UnCover.nTime[0][1]=vars.NowClk1.nHour; vars.UnCover.nTime[0][2]=vars.NowClk1.nDay; vars.UnCover.nTime[0][3]=vars.NowClk1.nMonth; vars.UnCover.nTimes++; _NOP(); vars.E2PROM_SAVE |= UnCover_S; vars.Int_ID |=E2Int; } if( P2IFG&P2POWERCHECK ) { P2IFG &=~P2POWERCHECK; vars.E2PROM_SAVE |= EC_S; vars.E2PROM_SAVE |= PulseNum_S; vars.Int_ID |=E2Int; } P2IFG =0; _NOP(); }
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
55
176
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
