[STM32F1] sc51p1816和stm32f103那个功能更强,用着信号的采集处理上面
1528|1
 楼主| trybye 发表于 2015-3-18 08:56 | 显示全部楼层 |阅读模式
其实就是一个简单的信号采集放大电路
airwill 发表于 2015-3-18 16:26 | 显示全部楼层
SC51P1816 is an 8-bit MCU with LCD driver.  It uses SC51 core with built-in 16K-byte OTP and 512-byte RAM. SC51P1816 integrates PLL to generate 4.194MHz main clock from the 32768Hz low frequency clock, which reduces the system cost and avoids the interference of external high frequency oscillator in noise-sensitive applications. So, this IC is particularly suitable for low-noise and low-power applications.
STM32 作为 32  位机, 这8位机来比就完全不是一个档次
