* Function Name : FSMC_NOR_ReadID
* Description : Reads NOR memory's Manufacturer and Device Code.
* Input : - NOR_ID: pointer to a NOR_IDTypeDef structure which will hold
* the Manufacturer and Device Code.
* Output : None
* Return : None
void FSMC_NOR_ReadID(NOR_IDTypeDef* NOR_ID)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
NOR_WRITE(ADDR_SHIFT(0x05555), 0x0090); NOR_ID->Manufacturer_Code = *(vu16 *) ADDR_SHIFT(0x0000);
NOR_ID->Device_Code1 = *(vu16 *) ADDR_SHIFT(0x0001);
NOR_ID->Device_Code2 = *(vu16 *) ADDR_SHIFT(0x000E);
NOR_ID->Device_Code3 = *(vu16 *) ADDR_SHIFT(0x000F);
* Function Name : FSMC_NOR_EraseBlock
* Description : Erases the specified Nor memory block.
* Input : - BlockAddr: address of the block to erase.
* Output : None
* Return : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseBlock(u32 BlockAddr)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x0080);
NOR_WRITE((Bank1_NOR2_ADDR + BlockAddr), 0x30); return (FSMC_NOR_GetStatus(BlockErase_Timeout));
* Function Name : FSMC_NOR_EraseChip
* Description : Erases the entire chip.
* Input : None
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_EraseChip(void)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x0010); return (FSMC_NOR_GetStatus(ChipErase_Timeout));
* Function Name : FSMC_NOR_WriteHalfWord
* Description : Writes a half-word to the NOR memory.
* Input : - WriteAddr : NOR memory internal address to write to.
* - Data : Data to write.
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteHalfWord(u32 WriteAddr, u16 Data)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x00A0);
NOR_WRITE((Bank1_NOR2_ADDR + WriteAddr), Data); return (FSMC_NOR_GetStatus(Program_Timeout));
* Function Name : FSMC_NOR_WriteBuffer
* Description : Writes a half-word buffer to the FSMC NOR memory.
* Input : - pBuffer : pointer to buffer.
* - WriteAddr : NOR memory internal address from which the data
* will be written.
* - NumHalfwordToWrite : number of Half words to write.
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_WriteBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
NOR_Status status = NOR_ONGOING; do
/* Transfer data to the memory */
status = FSMC_NOR_WriteHalfWord(WriteAddr, *pBuffer++);
WriteAddr = WriteAddr + 2;
NumHalfwordToWrite--;
while((status == NOR_SUCCESS) && (NumHalfwordToWrite != 0));
return (status);
* Function Name : FSMC_NOR_ProgramBuffer
* Description : Writes a half-word buffer to the FSMC NOR memory. This function
* must be used only with S29GL128P NOR memory.
* - WriteAddr: NOR memory internal address from which the data
* will be written.
* - NumHalfwordToWrite: number of Half words to write.
* The maximum allowed value is 32 Half words (64 bytes).
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_ProgramBuffer(u16* pBuffer, u32 WriteAddr, u32 NumHalfwordToWrite)
u32 lastloadedaddress = 0x00;
u32 currentaddress = 0x00;
u32 endaddress = 0x00; /* Initialize variables */
currentaddress = WriteAddr;
endaddress = WriteAddr + NumHalfwordToWrite - 1;
lastloadedaddress = WriteAddr; /* Issue unlock command sequence */
NOR_WRITE(ADDR_SHIFT(0x005555), 0x00AA); NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055); /* Write Write Buffer Load Command */
NOR_WRITE(ADDR_SHIFT(WriteAddr), 0x0025);
NOR_WRITE(ADDR_SHIFT(WriteAddr), (NumHalfwordToWrite - 1)); /* Load Data into NOR Buffer */
while(currentaddress <= endaddress)
/* Store last loaded address & data value (for polling) */
lastloadedaddress = currentaddress;
NOR_WRITE(ADDR_SHIFT(currentaddress), *pBuffer++);
currentaddress += 1;
} NOR_WRITE(ADDR_SHIFT(lastloadedaddress), 0x29);
return(FSMC_NOR_GetStatus(Program_Timeout));
* Function Name : FSMC_NOR_ReadHalfWord
* Description : Reads a half-word from the NOR memory.
* Input : - ReadAddr : NOR memory internal address to read from.
* Output : None
* Return : Half-word read from the NOR memory
u16 FSMC_NOR_ReadHalfWord(u32 ReadAddr)
NOR_WRITE(ADDR_SHIFT(0x002AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0 ); return (*(vu16 *)((Bank1_NOR2_ADDR + ReadAddr)));
* Function Name : FSMC_NOR_ReadBuffer
* Description : Reads a block of data from the FSMC NOR memory.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the NOR memory.
* - ReadAddr : NOR memory internal address to read from.
* - NumHalfwordToRead : number of Half word to read.
* Output : None
* Return : None
void FSMC_NOR_ReadBuffer(u16* pBuffer, u32 ReadAddr, u32 NumHalfwordToRead)
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0); for(; NumHalfwordToRead != 0x00; NumHalfwordToRead--) /* while there is data to read */
/* Read a Halfword from the NOR */
*pBuffer++ = *(vu16 *)((Bank1_NOR2_ADDR + ReadAddr));
ReadAddr = ReadAddr + 2;
* Function Name : FSMC_NOR_ReturnToReadMode
* Description : Returns the NOR memory to Read mode.
* Input : None
* Output : None
* Return : NOR_SUCCESS
NOR_Status FSMC_NOR_ReturnToReadMode(void)
NOR_WRITE(Bank1_NOR2_ADDR, 0x00F0); return (NOR_SUCCESS);
* Function Name : FSMC_NOR_Reset
* Description : Returns the NOR memory to Read mode and resets the errors in
* the NOR memory Status Register.
* Input : None
* Output : None
NOR_Status FSMC_NOR_Reset(void)
* Function Name : FSMC_NOR_GetStatus
* Description : Returns the NOR operation status.
* Input : - Timeout: NOR progamming Timeout
* Output : None
* or NOR_TIMEOUT
NOR_Status FSMC_NOR_GetStatus(u32 Timeout)
u16 val1 = 0x00, val2 = 0x00;
u32 timeout = Timeout; /* Poll on NOR memory Ready/Busy signal ------------------------------------*/
while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) != RESET) && (timeout > 0))
timeout--;
} timeout = Timeout;
while((GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == RESET) && (timeout > 0))
timeout--;
/* Get the NOR memory operation status -------------------------------------*/
while((Timeout != 0x00) && (status != NOR_SUCCESS))
Timeout--; /* Read DQ6 and DQ5 */
val1 = *(vu16 *)(Bank1_NOR2_ADDR);
val2 = *(vu16 *)(Bank1_NOR2_ADDR); /* If DQ6 did not toggle between the two reads then return NOR_Success */
if((val1 & 0x0040) == (val2 & 0x0040))
return NOR_SUCCESS;
} if((val1 & 0x0020) != 0x0020)
} val1 = *(vu16 *)(Bank1_NOR2_ADDR);
return NOR_SUCCESS;
else if((val1 & 0x0020) == 0x0020)
return NOR_ERROR;
} if(Timeout == 0x00)
status = NOR_TIMEOUT;
} /* Return the operation status */
return (status);
} /******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
