IAR EWARM下的44B0X板的FlashLoader程序,分享一下
3786|0
jhb_mail|  楼主 | 2007-8-5 22:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IAR EWARM下44b0x的FlashLoader
Flash Loader 是用IAR Embedded Workbench 开发的本地应用程序。其任务是通过文件I/O 从主机读取应用程序的二进制映象,将映象拆包,并写进Flash 存储器。Flash Loader 可以分成两个部分。一是所有Flash Loader 所共用的框架部分,其源代码由IAR Systems提供并包含在IAR Embedded Workbench 中;二是驱动部份,它是一小段用于实际烧写Flash 存储器的小程序。在IAR Embedded Workbench 中已经包含了一组用于各种内含FLASH的芯片的Flash Loader 驱动程序。而对于S3C44B0X,就得自己写Flash Loader 驱动程序了。本文主要针对44b0x + SST39VF160 (1M*16Bit FLASH) 目标板,在IAR-EWARM下的FLASHLOADER程序提供实例。
;bank0 FLASH: SST39VF160 (1Mb*16)
;bank1
;bank2 16bit IDE
;bank3 rtl8019
;bank4
;bank5 ext
;bank6 16bit SDRAM
;bank7 16bit SDRAM
#include <stdio.h>
#include <stdlib.h>
#include <ios3c44b0x.h>
#include "FlashS3C44B0x.h"
//#include "Interface.h" // The flash loader framework API declarations.
//#include  "C:Program FilesIAR SystemsEmbedded Workbench 4.0 EvaluationARMsrcflashloaderframeworkInterface.c"
#define int8 signed char
#define int16 signed short
#define int32 signed long
#define int64 signed double
#define uint8 unsigned char
#define uint16 unsigned short
#define uint32 unsigned long
#define uint64 unsigned double
#define EmiWrite(addr, dat)  *((uint16 *)(addr))=(uint16)dat
#define EmiRead(addr) *((uint32 *)(addr))
void cmd_toggle_bit()
 uint8 dat1, dat2;
 dat1 = EmiRead(0x1000<<1);
 dat2 = EmiRead(0x1000<<1);
 while((dat1^dat2) & 0x40) {
  dat1 = dat2;
void cmd_exit()
  EmiWrite(0x5555<<1, 0xAA);
  EmiWrite(0x2AAA<<1, 0x55);
  EmiWrite(0x5555<<1, 0xF0);
uint32 cmd_getid()
  EmiWrite(0x5555<<1, 0x90);
  return EmiRead(0x0000<<1);
//--- 2K WORD,4K BYTE, per sector.
//-- sst39VF160 has 512 sectors
void cmd_sector_erase(uint32 sector)
  EmiWrite(0x5555<<1, 0x80);
  EmiWrite(sector<<12, 0x30);
//--- 32K WORD,64K BYTE, per block.
//-- sst39VF160 has 32 blocks
void cmd_block_erase(uint32 block)
  EmiWrite(block<<16, 0x50);
void cmd_chip_erase()
  EmiWrite(0x5555<<1, 0x10);
void cmd_word_program(uint32 ads, uint16 dat)
  EmiWrite(0x5555<<1, 0xA0);
  EmiWrite(ads, dat);
 // 512 个扇区状态,标识是否已经擦除过,默认没有
 uint16 secBitMap[512] = {0};
__root void FlashWriteByte(uint32 addr, int byte)
    static uint16 cnt = 0;
 uint16 dat = byte;
 uint16 sector;
    cnt++;
 if(addr > 0xfffff) { // 超过FLASH的1MB范围
  *((char *)addr) = byte;
 }else {
  if(byte == -1) return;
  sector = addr>>12; // 所在扇区
  if(secBitMap[sector]==0) {
   cmd_sector_erase(sector);
   cmd_toggle_bit();
   secBitMap[sector]=0xffff;
  if(addr & 01) {
   dat <<=8;
   dat |= 0x00ff;
  }else {
   dat |= 0xff00;
        addr>>=1;
  cmd_word_program(addr<<1, dat);
  cmd_toggle_bit();
    return;
    char msg[80];
    sprintf(msg, "第 %d 次:FlashWriteByte(0x%X, 0x%X) ", cnt, addr, byte);
    FlMessageLog (msg);
void FlashDriverInitialize(int argc, char const* argv[])
 const char* str;
 // Register the flash write function.
 FlRegisterWriteFunction(FlashWriteByte);
 // See if user has passed a clock speed option.
 // If not, the default CCLK value is used.
 str = FlFindOption("--clock", 1, argc, argv);
 if (str){
  clock = strtoul(str, 0, 0);
