sst29sf040作为数据存储器时,为何掉电后数据恢复为初始化的
2039|0
ccjchen|  楼主 | 2007-9-25 08:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
sst29sf040不是flash吗,难道数据会丢失吗?我仿真时看到数据也写进了sst29sf040阿,为什么一烧写进芯片后掉电数据就会恢复为初始化的值呢?
下面是我改变数组 syn 的值并存储到sst29sf040的程序
void  ByteProgram(uchar data SrcByte,uint Dst)
    XBYTE[0x0555] = 0xAA;
    XBYTE[0x02AA] = 0x55;
    XBYTE[0x0555] = 0xA0;
    XBYTE[Dst]   = SrcByte;
    wait(1,9);//等待25us
int Erase_One_Sector(uint Dst)
        /*  Issue the Sector Erase command to 39SF040   */
        XBYTE[0x0555] = 0xAA; /* set up address to be 555h    */
                             /* write data 0xAA to the address     */
        XBYTE[0x02AA] = 0x55; /* set up address to be 2AAh    */
                             /* write data 0x55 to the address     */
        XBYTE[0x0555] = 0x80; /* set up address to be 555h    */
                             /* write data 0x80 to the address     */
        XBYTE[Dst]   = 0x20; /* set up starting address to be erased */
                             /* write data 0x30 to the address     */
        wait(85,134);        /* check DATABOOK for the most  */
                             /* accurate value -- Tse        */
uchar ByteRead(uint addr)
    uchar GetData;
    GetData = XBYTE[addr];
    return(GetData);
void sst_save()//用于保存易丢失数据
     uchar i;
    Erase_One_Sector(128);
           for(i=0;i<4;i++)
              ByteProgram(syn[2*i+1],0x0080+i);
              syn[2*i+1]=ByteRead(0x0080+i);
void main()
   sst_save();
