[技术问答]
新手上路:M052的ADC采集问题
1873|6
xinshou666|  楼主 | 2015-4-13 16:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己修改的新唐例子程序,但发现无法采集,程序如下 ,求大神解答
#include <stdio.h>
#include "M051Series.h"
#include "lcd_driver.h"
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
     SYS_UnlockReg();
    /* Enable ADC and PWM23 clock */
    CLK->APBCLK = CLK_APBCLK_PWM23_EN_Msk | CLK_APBCLK_ADC_EN_Msk;
    /* ADC clock source is 22.1184MHz, set divider to (3 + 1), ADC clock is 22.1184/4 MHz */
    CLK->CLKDIV |= (3 << CLK_CLKDIV_ADC_N_Pos);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Set P1.0 to AIN0 function */
    SYS->P1_MFP = SYS_MFP_P10_AIN0;
    /* Disable digital input path of analog pin AIN0 to prevent leakage */
    P1->OFFD |= 1 << GPIO_OFFD_OFFD_Pos;
    /* Lock protected registers */
     SYS_LockReg();
void ADC_Init(void)
    /* Set to convert ADC channel 0 */
    ADC->ADCHER = 0x1;
    /* Enable the ADC converter */
    ADC->ADCR = ADC_ADCR_ADEN_Msk;
/* Main function  */
int main(void)
    uint32_t u32Data, u32Sum, u32Count;
//     char adc_value[20];
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init ADC to get the value of variable resistor */
    ADC_Init();
                u32Data = 0 ;
    u32Count = 0;
    u32Sum = 0;
    while(1)
        /* Start convert */
        ADC_START_CONV(ADC);
        /* Waiting for convert complete */
        while(ADC_IS_BUSY(ADC));
        /* Read the result from ADC */
        u32Data = ADC->ADDR[0] & ADC_ADDR_RSLT_Msk;
        /* Determine the sum */
        u32Sum += u32Data;
        u32Count++;
        if(u32Count == 128)
            /* Determine the average */
            u32Data = u32Sum / 128;
            /* Reset count and sum */
            u32Count = 0;
            u32Sum = 0;
quray1985| | 2015-4-14 21:53 | 只看该作者
楼主这种问题有点难回答,贴了这么多的代码,大家谁有空看呢
不如把具体的问题写出来,让大家分析一下
734774645| | 2015-4-14 23:46 | 只看该作者
搞不懂楼主采集完后怎么查看的,莫名其妙的感觉。
建议楼主先调试好一个串口的程序,然后在这个基础上再做这个,这样就可以通过串口读取转换的结果了。
xinshou666|  楼主 | 2015-4-25 14:08 | 只看该作者
不如把具体的问题写出来,让大家分析一下 ...
能说一下QQ么   有具体的想问你
稳稳の幸福| | 2015-4-25 16:53 | 只看该作者
:lol应该问题不大,这个芯片没用过,用过058
quray1985| | 2015-4-28 23:34 | 只看该作者
xinshou666 发表于 2015-4-25 14:08
能说一下QQ么   有具体的想问你
707205943,你加我吧
