RealView MDK 3.20 版正式发布!简体中文帮助
3964|9
 楼主| 小野狼 发表于 2008-2-16 11:56 | 显示全部楼层 |阅读模式
RealView&nbsp;MDK最新版本,帮助为简体中文版,下载请前往<a href="http://www.realview.com.cn/down-list.asp?id=326" target=_blank>http://www.realview.com.cn/down-list.asp?id=326</a><br /><br /><br />3.20版更新如下:<br /><br />[Device&nbsp;Support]&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;RTX&nbsp;support&nbsp;for&nbsp;TMS470&nbsp;in&nbsp;folder&nbsp;..ARMBoardsTITMS470R1B1MRTX_Blinky.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;example&nbsp;projects&nbsp;for&nbsp;NXP&nbsp;LPC2919&nbsp;in&nbsp;folder&nbsp;..ARMBoardsKeilMCB2900.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;support&nbsp;for&nbsp;STMicroelectronics&nbsp;STA2051.&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;support&nbsp;for&nbsp;AustriaMicroSystems&nbsp;AS3525&nbsp;&nbsp;in&nbsp;folder&nbsp;..ARMBoardsAMSAS3525.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;support&nbsp;for&nbsp;NXP&nbsp;(Sharp)&nbsp;LH79524&nbsp;in&nbsp;folder&nbsp;..ARMBoardsNXPLH79524.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;support&nbsp;for&nbsp;Winbond&nbsp;W90P710&nbsp;in&nbsp;folder&nbsp;..ARMBoardsWinbondW90P710.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Added:&nbsp;RTX&nbsp;Traffic&nbsp;example&nbsp;for&nbsp;STR9&nbsp;devices&nbsp;and&nbsp;corrected&nbsp;a&nbsp;problem&nbsp;with&nbsp;the&nbsp;interrupt&nbsp;controlled&nbsp;UART&nbsp;simulation&nbsp;of&nbsp;STR9.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Corrected:&nbsp;for&nbsp;Altera&nbsp;Cortex-M1&nbsp;driver&nbsp;the&nbsp;option&nbsp;Use&nbsp;Reset&nbsp;at&nbsp;Startup&nbsp;was&nbsp;not&nbsp;stored.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Corrected:&nbsp;RT-Agent&nbsp;configuration&nbsp;AT91SAM7X&nbsp;with&nbsp;interrupts&nbsp;in&nbsp;folder&nbsp;..ARMRT&nbsp;AgentRTXAT91SAM7X-EKBlinky.&nbsp;<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Corrected:&nbsp;Timer3&nbsp;and&nbsp;Timer4&nbsp;of&nbsp;LPC2101/2/3&nbsp;devices&nbsp;was&nbsp;incorrectly&nbsp;simulated.&nbsp;<br /><br /><br />[RTX&nbsp;-&nbsp;Problems&nbsp;Solved]<br />&nbsp;&nbsp;&nbsp;&nbsp;Corrected:&nbsp;core&nbsp;problems&nbsp;for&nbsp;Cortex-M&nbsp;devices.&nbsp;Handling&nbsp;of&nbsp;isr_xxx&nbsp;function&nbsp;calls&nbsp;was&nbsp;incorrect&nbsp;and&nbsp;could&nbsp;cause&nbsp;task&nbsp;locks.&nbsp;Wrong&nbsp;handling&nbsp;of&nbsp;task&nbsp;switches&nbsp;and&nbsp;__svc&nbsp;functions&nbsp;could&nbsp;cause&nbsp;sporadic&nbsp;application&nbsp;crashes&nbsp;if&nbsp;additional&nbsp;user&nbsp;interrupts&nbsp;were&nbsp;enabled.&nbsp;<br /> 相关链接:<a href='http://www.realview.com.cn/product/271.htm'>http://www.realview.com.cn/product/271.htm</a>
phoenixmy 发表于 2008-2-16 12:10 | 显示全部楼层
<br /><br />更新很快啊
hotpower 发表于 2008-2-16 12:11 | 显示全部楼层
对俺暂时用处不大~~~
LastNew 发表于 2008-2-16 12:17 | 显示全部楼层
顶下
弄来看看先
phoenixmy 发表于 2008-2-16 12:23 | 显示全部楼层
仔细看看内容还挺多
<br />Added:&nbsp;example&nbsp;projects&nbsp;for&nbsp;NXP&nbsp;LPC2919&nbsp;in&nbsp;folder&nbsp;..ARMBoardsKeilMCB2900.&nbsp;<br /><br />29xx的arm9~~~~~~~~~<br />以前还没有关注过<br /><br /><br />..&nbsp;Corrected:&nbsp;for&nbsp;Altera&nbsp;Cortex-M1&nbsp;driver&nbsp;the&nbsp;option&nbsp;Use&nbsp;Reset&nbsp;at&nbsp;Startup&nbsp;was&nbsp;not&nbsp;stored.&nbsp;<br /><br />altera也有cortex的核?
LastNew 发表于 2008-2-16 12:25 | 显示全部楼层
装这个
装这个就不用keil和realview了?
 楼主| 小野狼 发表于 2008-2-16 14:11 | 显示全部楼层
楼上的
RealView&nbsp;MDK的IDE本来就是uVision3啊
玄德 发表于 2008-2-17 12:17 | 显示全部楼层
AAA
对我而言,由于新版本已经不支持ULINK了,我将放弃KEIL的软件,转向IAR+JLINK。
古道热肠 发表于 2008-2-19 16:40 | 显示全部楼层
装上了,中文帮助不错!
是2K限制,限制太多了吧,能出个4K或8K代码长度的评估版吗?也让穷人先体验体验ARM的强大。
Swd21ic 发表于 2008-2-21 21:37 | 显示全部楼层
Re
使用IAR吧..<br /><br />转大部分的片子都可以用几乎同一个环境..<br /><br />要知道把一个IDE真正搞熟很费时间的.
