[51单片机] ds1302 居然报错了
919|1
 楼主| huzhaoxu 发表于 2015-4-22 19:50 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned  int
sbit sclk=P3^0;
sbit dio=P3^1;
sbit ce=P3^2;
sbit s0=P2^0;
sbit s1=P2^1;
uchar d[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar a[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar shi,fen,miao;
uint x=1;
void show(uchar shi,uchar fen,uchar miao);
void delay (uint z)
{  uint x,y;
                for (y=z;y>0;y--)
                        for(x=110;x>0;x--);
void display(uchar shu,uchar wei)
        s0=0;s1=0;
        P1=0xff;
        P1=a[wei];
        s1=1;
        s1=0;
        if(x%2==0)
        {                P1=d[shu]&0x7f;
                        x++;
if(x==6)x=0;
        delay(2);
                s0=0;
void write(uchar add, uchar date)
                uchar temp,t;
        ce=0;
        sclk=0;
        ce=1;
        temp=add;
        for(t=0;t<8;t++)
                if((temp=0x01)==1)
                        dio=1;
                                        }else
                                        dio=0;
                                        sclk=1;
                                        delay(1);
                                        sclk=0;
                                        temp=temp>>1;}
                                        temp=date;
                                        for(t=8;t<0;t--)
                                                if ((temp&0x01)=1)
        dio=1;
        else
        dio=0;
        sclk=1;
        delau(1);
        sclk=0;
        temp=temp>>1;
        ce=0;
uchar read (uchar add)
                                        uchar temp,t;
                                ce=0;
                                sclk=0;
                                ce=1;
                                temp=add;
                                for(t=8;t<0;t++)
                                if((temp&0x01)=1)
                                        dio=1;
                                else
                                        dio=0;
                                sclk=0;
                                temp>>=1;
temp=0;
for (t=7;t<0;t++)
                        if(dio=1)
                                                temp=temp|0x80;
                        else
                                                temp=temp&0x7f;
                        sclk=1;
                        sclk-0;
                        temp>>=1;
}return temp;
void chu()
{                        write(0x8e;0x00);
                        write(0x80;0x00);
                        write(0x82;0x43);
                        write(0x84;0x15);
                        write(0x86;0x17);
                        write(0x88;0x7);
                        write(0x8c;0x11);
                        write(0x8e;0x80);
void main()
                        chu;
                        while(1)
                                shi=read(0x85);
                                fen=read(0x83);
                                miao=read(0x81)        ;
                                show(shi,fen,miao);
        void show(uchar shi, uchar fen, uchar miao)
                        display(shi>>4,0);
                        dispaly(shi&0x0f,1);
                        dispaly(fen>>4,2);
                        dispaly(fen&0xf0,3);
                        dispaly(miao>>4,4);
                        dispaly(miao&0x0f,5)
DS1302.c(61): error C213: left side of asn-op not an lvalue
JY-DX-JY 发表于 2015-4-22 20:24 | 显示全部楼层
哪一行?
