[数据传输]
68013数据传输过程中发生丢失
1765|2
sianmin123|  楼主 | 2015-4-29 01:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我使用FPGA直接向上位机传输8位不断循环自加的数据...然后通过68013不断向PC传输这些数据...可是我用Streamer观察数据的发现数据"跳"了,或者说丢失了吧。。反正不连续~请问这是什么问题?上源代码~
-- Company: Cypress Semiconductors
-- Engineer: Hridya Valsaraju
-- Create Date:    03:28:52 12/18/2009
-- Design Name:  FX2LP-FPGA interface
-- Module Name:    test - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity fpga_master is
  Port (
    fdata : inout  STD_LOGIC_VECTOR(15 downto 0);  --  FIFO data lines.
    faddr     : out STD_LOGIC_VECTOR(1 downto 0); --  FIFO select lines
    slrd      : out STD_LOGIC;                    -- Read control line
    slwr      : out STD_LOGIC;                    -- Write control line
    gstate    : out STD_LOGIC_VECTOR(3 downto 0); -- debug lines
    flagd     : in  STD_LOGIC;                    --EP6 full flag
    flaga     : in  STD_LOGIC;                    --EP2 empty flag
    clk       : in  STD_LOGIC;                    --Interface Clock
    sloe      : out STD_LOGIC                     --Slave Output Enable control
end fpga_master;
architecture rtl of fpga_master is
signal faddr_i    : STD_LOGIC_VECTOR(1 downto 0);
signal slrd_i     : STD_LOGIC;
signal slwr_i     : STD_LOGIC;
signal gstate_i : STD_LOGIC_VECTOR(3 downto 0);
signal MasterState : STD_LOGIC_VECTOR(3 downto 0);   -- Counter to sequence the fifo signals.
signal sloe_i : STD_LOGIC;
shared variable cnt : integer range 0 to 9 := 0 ;
CONSTANT A: STD_LOGIC_VECTOR (3 DownTo 0) := "0000";
CONSTANT B: STD_LOGIC_VECTOR (3 DownTo 0) := "0001";
CONSTANT C: STD_LOGIC_VECTOR (3 DownTo 0) := "0010";
CONSTANT D: STD_LOGIC_VECTOR (3 DownTo 0) := "0011";
CONSTANT E: STD_LOGIC_VECTOR (3 DownTo 0) := "0100";
CONSTANT F: STD_LOGIC_VECTOR (3 DownTo 0) := "0101";
CONSTANT G: STD_LOGIC_VECTOR (3 DownTo 0) := "0110";
CONSTANT H: STD_LOGIC_VECTOR (3 DownTo 0) := "0111";
begin
        slrd        <= slrd_i;
        slwr        <= slwr_i;
        faddr <= faddr_i;
        gstate<= gstate_i;
        sloe         <= sloe_i;
process(clk)
variable fdatawe : natural := 0;
variable fifodatabyte : STD_LOGIC_VECTOR(15 downto 0) := "0000000000000000";  -- Local for now.
begin
        if(rising_edge(clk)) then
                case MasterState(3 downto 0) is
                        when A =>  -- IDLE STATE
                                sloe_i <= '1';
                                faddr_i <= "10";
                                slrd_i  <= '1';
                                slwr_i  <= '1';
                                MasterState <= E;
                                fdatawe := 0;
                                gstate_i <= "0001";
                        when E =>
                                faddr_i <= "10";
                                slrd_i  <= '1';
                                sloe_i <= '1';
                                if (flagd = '1')   then                 -- if Full flag is in a deasserted state
                                        slwr_i  <= '0';                         --assert slave write control signal
                                        fdatawe := 0 ;
                                        fdata <= fifodatabyte;
                                        fifodatabyte := fifodatabyte + '1';
                                        MasterState <= E;                       -- stay in state E
                                else
                                        slwr_i  <= '1';
                                        MasterState <= A;                                  --when Full flag gets asserted, move to state A
                                end if;
                                gstate_i <= "0110";
                        when others =>--if an undefined state move to IDLE
                                faddr_i <= "00";
                                slrd_i  <= '1';
                                sloe_i <= '1';
                                slwr_i  <= '1';
                                gstate_i <= "1000";
                                MasterState <= A;
                end case;
        end if;
end process;
end rtl;
sianmin123|  楼主 | 2015-4-29 01:11 | 只看该作者
不好意思。。。写错了..是16位的数据...自己顶一个
sianmin123|  楼主 | 2015-4-29 12:08 | 只看该作者
来个大神指导一下...
