** 有阿南版主手把手教 太羡慕了
2667|7
 楼主| 新手额 发表于 2008-12-4 23:23 | 显示全部楼层 |阅读模式
S3C2440芯片<br /><br />;存储器控制寄存器的定义区<br />&nbsp;&nbsp;&nbsp;&nbsp;LTORG<br /><br />SMRDATA&nbsp;DATA<br />;&nbsp;Memory&nbsp;configuration&nbsp;should&nbsp;be&nbsp;optimized&nbsp;for&nbsp;best&nbsp;performance<br />;&nbsp;The&nbsp;following&nbsp;parameter&nbsp;is&nbsp;not&nbsp;optimized.<br />;&nbsp;Memory&nbsp;access&nbsp;cycle&nbsp;parameter&nbsp;strategy<br />;&nbsp;1)&nbsp;The&nbsp;memory&nbsp;settings&nbsp;is&nbsp;&nbsp;safe&nbsp;parameters&nbsp;even&nbsp;at&nbsp;HCLK=75Mhz.<br />;&nbsp;2)&nbsp;SDRAM&nbsp;refresh&nbsp;period&nbsp;is&nbsp;for&nbsp;HCLK&lt=75Mhz.<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;(0+(B1_BWSCON&lt&lt4)+(B2_BWSCON&lt&lt8)+(B3_BWSCON&lt&lt12)+(B4_BWSCON&lt&lt16)+(B5_BWSCON&lt&lt20)+(B6_BWSCON&lt&lt24)+(B7_BWSCON&lt&lt28))<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B0_Tacs&lt&lt13)+(B0_Tcos&lt&lt11)+(B0_Tacc&lt&lt8)+(B0_Tcoh&lt&lt6)+(B0_Tah&lt&lt4)+(B0_Tacp&lt&lt2)+(B0_PMC))&nbsp;&nbsp;&nbsp;;GCS0<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B1_Tacs&lt&lt13)+(B1_Tcos&lt&lt11)+(B1_Tacc&lt&lt8)+(B1_Tcoh&lt&lt6)+(B1_Tah&lt&lt4)+(B1_Tacp&lt&lt2)+(B1_PMC))&nbsp;&nbsp;&nbsp;;GCS1<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B2_Tacs&lt&lt13)+(B2_Tcos&lt&lt11)+(B2_Tacc&lt&lt8)+(B2_Tcoh&lt&lt6)+(B2_Tah&lt&lt4)+(B2_Tacp&lt&lt2)+(B2_PMC))&nbsp;&nbsp;&nbsp;;GCS2<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B3_Tacs&lt&lt13)+(B3_Tcos&lt&lt11)+(B3_Tacc&lt&lt8)+(B3_Tcoh&lt&lt6)+(B3_Tah&lt&lt4)+(B3_Tacp&lt&lt2)+(B3_PMC))&nbsp;&nbsp;&nbsp;;GCS3<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B4_Tacs&lt&lt13)+(B4_Tcos&lt&lt11)+(B4_Tacc&lt&lt8)+(B4_Tcoh&lt&lt6)+(B4_Tah&lt&lt4)+(B4_Tacp&lt&lt2)+(B4_PMC))&nbsp;&nbsp;&nbsp;;GCS4<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B5_Tacs&lt&lt13)+(B5_Tcos&lt&lt11)+(B5_Tacc&lt&lt8)+(B5_Tcoh&lt&lt6)+(B5_Tah&lt&lt4)+(B5_Tacp&lt&lt2)+(B5_PMC))&nbsp;&nbsp;&nbsp;;GCS5<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B6_MT&lt&lt15)+(B6_Trcd&lt&lt2)+(B6_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS6<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B7_MT&lt&lt15)+(B7_Trcd&lt&lt2)+(B7_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS7<br /><br /><br />看到它的汇编代码为<br />&nbsp;SMRDATA<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000424:&nbsp;&nbsp;&nbsp;&nbsp;22111120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;..&quot;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;571543840<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000428:&nbsp;&nbsp;&nbsp;&nbsp;00000700&nbsp;&nbsp;&nbsp;&nbsp;....&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;1792<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x0000042c:&nbsp;&nbsp;&nbsp;&nbsp;00000700&nbsp;&nbsp;&nbsp;&nbsp;....&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;1792<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000430:&nbsp;&nbsp;&nbsp;&nbsp;00000700&nbsp;&nbsp;&nbsp;&nbsp;....&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;1792<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000434:&nbsp;&nbsp;&nbsp;&nbsp;00000700&nbsp;&nbsp;&nbsp;&nbsp;....&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;1792<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;0x00000438:&nbsp;&nbsp;&nbsp;&nbsp;00000700&nbsp;&nbsp;&nbsp;&nbsp;....&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;1792<br /><br />就比如第一条就是&nbsp;DCD&nbsp;0X22111120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;按我的理解,就是在0x00000424这个地址位置初始化一块内存区域,区域中的值为0X22111120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />请问是不是这么理解。。<br /><br />还有,不管是不是这样,这好像没有对存储器进行什么操作啊,初学,谢谢!
阿南 发表于 2008-12-5 09:08 | 显示全部楼层
可以这样理解
在启动代码中,会找到的,找一下:SMRDATA&nbsp;
bigstrong 发表于 2008-12-5 09:19 | 显示全部楼层
关于DCD
0x00000424:&nbsp;&nbsp;&nbsp;&nbsp;22111120&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;..&quot;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;&nbsp;&nbsp;&nbsp;571543840<br />这句代表在0x00000424这个位置放了一个数0x22111120,这个数后面会用到,具体使用方法要看调用这个数的地方,找一个哪个地方使用了SMRDATA这个标号。<br />可以理解这里是生成一个结构体,结构体的名字是SMRDATA,结构体的地址是0x00000424.
playlinus 发表于 2008-12-5 16:34 | 显示全部楼层
同问...阿南能不能解释清楚点 ?
&nbsp;....
阿南 发表于 2008-12-5 23:59 | 显示全部楼层
摘自《ARM Linux入门与实践》:
5.3.6&nbsp;初始化内存控制器<br />初始化内存控制器其实就是对S3C2410A的Memory&nbsp;Bank[7:0]进行设置,使其用CS[7:0]扩展的存储器或外部设备能够被处理器通过内存控制器正确的读写。由于S3C2410A的最终应用程序是在SDRAM(Bank6)中运行,以及C语言变量等的用户数据,各种模式的堆栈,中断向量表等都被定位在SDRAM的空间,所以它必须在涉及这些处理之前被完成初始化工作。<br />1.参数配置<br />;************************************************&nbsp;<br />;&nbsp;NAME&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;MEMCFG.A<br />;&nbsp;DESC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;Memory&nbsp;bank&nbsp;configuration&nbsp;file<br />;&nbsp;Revision:&nbsp;02.28.2002&nbsp;ver&nbsp;0.0<br />;************************************************<br />……<br />;BANK0CON&nbsp;<br />B0_Tacs&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;0clk<br />B0_Tcos&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;0clk<br />B0_Tacc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x7&nbsp;&nbsp;&nbsp;&nbsp;;14clk<br />B0_Tcoh&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;0clk<br />B0_Tah&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;0clk<br />B0_Tacp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;<br />B0_PMC&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;normal<br />;Bank&nbsp;6&nbsp;parameter<br />B6_MT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x3&nbsp;&nbsp;&nbsp;&nbsp;;SDRAM<br />;B6_Trcd&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;2clk<br />B6_Trcd&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x1&nbsp;&nbsp;&nbsp;&nbsp;;3clk<br />B6_SCAN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x1&nbsp;&nbsp;&nbsp;&nbsp;;9bit<br />&nbsp;&nbsp;&nbsp;&nbsp;……<br />;REFRESH&nbsp;parameter<br />REFEN&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x1&nbsp;&nbsp;&nbsp;&nbsp;;Refresh&nbsp;enable<br />TREFMD&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;CBR(CAS&nbsp;before&nbsp;RAS)/Auto&nbsp;refresh<br />Trp&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x0&nbsp;&nbsp;&nbsp;&nbsp;;2clk<br />Trc&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x3&nbsp;&nbsp;&nbsp;&nbsp;;7clk<br />Tchr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;0x2&nbsp;&nbsp;&nbsp;&nbsp;;3clk<br />REFCNT&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;&nbsp;&nbsp;1113&nbsp;&nbsp;&nbsp;&nbsp;;period=15.6us,&nbsp;HCLK=60Mhz,&nbsp;(2048+1-15.6*60)<br />&nbsp;&nbsp;&nbsp;&nbsp;END<br />该部分的详细内容请参考memcfg.s文件,它直观的定义了内存控制器相关特殊寄存器的所有功能位的具体数值,当读者初次扩展一个外设或希望提高某个外设的读写速度时,就可以修改该文件的这些具体时序参数。<br />2.功能寄存器数值表的定义<br />SMRDATA&nbsp;DATA<br />;&nbsp;Memory&nbsp;configuration&nbsp;should&nbsp;be&nbsp;optimized&nbsp;for&nbsp;best&nbsp;performance&nbsp;<br />;&nbsp;The&nbsp;following&nbsp;parameter&nbsp;is&nbsp;not&nbsp;optimized.&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />;&nbsp;Memory&nbsp;access&nbsp;cycle&nbsp;parameter&nbsp;strategy<br />;&nbsp;1)&nbsp;The&nbsp;memory&nbsp;settings&nbsp;is&nbsp;&nbsp;safe&nbsp;parameters&nbsp;even&nbsp;at&nbsp;HCLK=75Mhz.<br />;&nbsp;2)&nbsp;SDRAM&nbsp;refresh&nbsp;period&nbsp;is&nbsp;for&nbsp;HCLK=75Mhz.&nbsp;<br />DCD&nbsp;(0+(B1_BWSCON&lt&lt4)+(B2_BWSCON&lt&lt8)+(B3_BWSCON&lt&lt12)+(B4_BWSCON&lt&lt16)+(B5_BWSCON&lt&lt20)+(B6_BWSCON&lt&lt24)+(B7_BWSCON&lt&lt28))<br />DCD&nbsp;((B0_Tacs&lt&lt13)+(B0_Tcos&lt&lt11)+(B0_Tacc&lt&lt8)+(B0_Tcoh&lt&lt6)+(B0_Tah&lt&lt4)+(B0_Tacp&lt&lt2)+(B0_PMC))&nbsp;&nbsp;&nbsp;;GCS0<br />DCD&nbsp;((B1_Tacs&lt&lt13)+(B1_Tcos&lt&lt11)+(B1_Tacc&lt&lt8)+(B1_Tcoh&lt&lt6)+(B1_Tah&lt&lt4)+(B1_Tacp&lt&lt2)+(B1_PMC))&nbsp;&nbsp;&nbsp;;GCS1&nbsp;<br />DCD&nbsp;((B2_Tacs&lt&lt13)+(B2_Tcos&lt&lt11)+(B2_Tacc&lt&lt8)+(B2_Tcoh&lt&lt6)+(B2_Tah&lt&lt4)+(B2_Tacp&lt&lt2)+(B2_PMC))&nbsp;&nbsp;&nbsp;;GCS2<br />DCD&nbsp;((B3_Tacs&lt&lt13)+(B3_Tcos&lt&lt11)+(B3_Tacc&lt&lt8)+(B3_Tcoh&lt&lt6)+(B3_Tah&lt&lt4)+(B3_Tacp&lt&lt2)+(B3_PMC))&nbsp;&nbsp;&nbsp;;GCS3<br />DCD&nbsp;((B4_Tacs&lt&lt13)+(B4_Tcos&lt&lt11)+(B4_Tacc&lt&lt8)+(B4_Tcoh&lt&lt6)+(B4_Tah&lt&lt4)+(B4_Tacp&lt&lt2)+(B4_PMC))&nbsp;&nbsp;&nbsp;;GCS4<br />DCD&nbsp;((B5_Tacs&lt&lt13)+(B5_Tcos&lt&lt11)+(B5_Tacc&lt&lt8)+(B5_Tcoh&lt&lt6)+(B5_Tah&lt&lt4)+(B5_Tacp&lt&lt2)+(B5_PMC))&nbsp;&nbsp;&nbsp;;GCS5<br />DCD&nbsp;((B6_MT&lt&lt15)+(B6_Trcd&lt&lt2)+(B6_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS6<br />DCD&nbsp;((B7_MT&lt&lt15)+(B7_Trcd&lt&lt2)+(B7_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS7<br />DCD&nbsp;((REFEN&lt&lt23)+(TREFMD&lt&lt22)+(Trp&lt&lt20)+(Trc&lt&lt18)+(Tchr&lt&lt16)+REFCNT)&nbsp;&nbsp;&nbsp;&nbsp;<br />DCD&nbsp;0x32&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;SCLK&nbsp;power&nbsp;saving&nbsp;mode,&nbsp;BANKSIZE&nbsp;128M/128M<br />DCD&nbsp;0x30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR6&nbsp;CL=3clk<br />DCD&nbsp;0x30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR7<br />这段程序的开始使用DATA伪操作指明SMRDATA标号处为一段数据,而非代码。接下来就都用DCD分配一个字的内存单元,且初始化成由memcfg.s文件中定义的参数运算得出的各寄存器值,共13个字(52字节)数据。<br />3.功能寄存器初始化<br />&nbsp;&nbsp;&nbsp;&nbsp;;Set&nbsp;memory&nbsp;control&nbsp;registers<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ldr&nbsp;&nbsp;&nbsp;&nbsp;r0,=SMRDATA<br />&nbsp;&nbsp;&nbsp;&nbsp;ldr&nbsp;&nbsp;&nbsp;&nbsp;r1,=BWSCON&nbsp;&nbsp;&nbsp;&nbsp;;BWSCON&nbsp;Address<br />&nbsp;&nbsp;&nbsp;&nbsp;add&nbsp;&nbsp;&nbsp;&nbsp;r2,&nbsp;r0,&nbsp;#52&nbsp;&nbsp;&nbsp;&nbsp;;End&nbsp;address&nbsp;of&nbsp;SMRDATA<br />0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;ldr&nbsp;&nbsp;&nbsp;&nbsp;r3,&nbsp;[r0],&nbsp;#4&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;str&nbsp;&nbsp;&nbsp;&nbsp;r3,&nbsp;[r1],&nbsp;#4&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;cmp&nbsp;&nbsp;&nbsp;&nbsp;r2,&nbsp;r0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;bne&nbsp;&nbsp;&nbsp;&nbsp;%B0<br />这段代码就是将上节定义的功能寄存器数值表的数据依次传送给实践的内存控制器的每个特殊功能寄存器,以达到对它们的初始化目的。&nbsp;&nbsp;&nbsp;&nbsp;<br />
playlinus 发表于 2008-12-6 09:41 | 显示全部楼层
第二条中定义了一段data , 它是怎么实现 什么功能的 ?
2.功能寄存器数值表的定义<br />SMRDATA&nbsp;DATA<br />;&nbsp;Memory&nbsp;configuration&nbsp;should&nbsp;be&nbsp;optimized&nbsp;for&nbsp;best&nbsp;performance&nbsp;<br />;&nbsp;The&nbsp;following&nbsp;parameter&nbsp;is&nbsp;not&nbsp;optimized.&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />;&nbsp;Memory&nbsp;access&nbsp;cycle&nbsp;parameter&nbsp;strategy<br />;&nbsp;1)&nbsp;The&nbsp;memory&nbsp;settings&nbsp;is&nbsp;&nbsp;safe&nbsp;parameters&nbsp;even&nbsp;at&nbsp;HCLK=75Mhz.<br />;&nbsp;2)&nbsp;SDRAM&nbsp;refresh&nbsp;period&nbsp;is&nbsp;for&nbsp;HCLK=75Mhz.&nbsp;<br />DCD&nbsp;(0+(B1_BWSCON&lt&lt4)+(B2_BWSCON&lt&lt8)+(B3_BWSCON&lt&lt12)+(B4_BWSCON&lt&lt16)+(B5_BWSCON&lt&lt20)+(B6_BWSCON&lt&lt24)+(B7_BWSCON&lt&lt28))<br />DCD&nbsp;((B0_Tacs&lt&lt13)+(B0_Tcos&lt&lt11)+(B0_Tacc&lt&lt8)+(B0_Tcoh&lt&lt6)+(B0_Tah&lt&lt4)+(B0_Tacp&lt&lt2)+(B0_PMC))&nbsp;&nbsp;&nbsp;;GCS0<br />DCD&nbsp;((B1_Tacs&lt&lt13)+(B1_Tcos&lt&lt11)+(B1_Tacc&lt&lt8)+(B1_Tcoh&lt&lt6)+(B1_Tah&lt&lt4)+(B1_Tacp&lt&lt2)+(B1_PMC))&nbsp;&nbsp;&nbsp;;GCS1&nbsp;<br />DCD&nbsp;((B2_Tacs&lt&lt13)+(B2_Tcos&lt&lt11)+(B2_Tacc&lt&lt8)+(B2_Tcoh&lt&lt6)+(B2_Tah&lt&lt4)+(B2_Tacp&lt&lt2)+(B2_PMC))&nbsp;&nbsp;&nbsp;;GCS2<br />DCD&nbsp;((B3_Tacs&lt&lt13)+(B3_Tcos&lt&lt11)+(B3_Tacc&lt&lt8)+(B3_Tcoh&lt&lt6)+(B3_Tah&lt&lt4)+(B3_Tacp&lt&lt2)+(B3_PMC))&nbsp;&nbsp;&nbsp;;GCS3<br />DCD&nbsp;((B4_Tacs&lt&lt13)+(B4_Tcos&lt&lt11)+(B4_Tacc&lt&lt8)+(B4_Tcoh&lt&lt6)+(B4_Tah&lt&lt4)+(B4_Tacp&lt&lt2)+(B4_PMC))&nbsp;&nbsp;&nbsp;;GCS4<br />DCD&nbsp;((B5_Tacs&lt&lt13)+(B5_Tcos&lt&lt11)+(B5_Tacc&lt&lt8)+(B5_Tcoh&lt&lt6)+(B5_Tah&lt&lt4)+(B5_Tacp&lt&lt2)+(B5_PMC))&nbsp;&nbsp;&nbsp;;GCS5<br />DCD&nbsp;((B6_MT&lt&lt15)+(B6_Trcd&lt&lt2)+(B6_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS6<br />DCD&nbsp;((B7_MT&lt&lt15)+(B7_Trcd&lt&lt2)+(B7_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS7<br />DCD&nbsp;((REFEN&lt&lt23)+(TREFMD&lt&lt22)+(Trp&lt&lt20)+(Trc&lt&lt18)+(Tchr&lt&lt16)+REFCNT)&nbsp;&nbsp;&nbsp;&nbsp;<br />DCD&nbsp;0x32&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;SCLK&nbsp;power&nbsp;saving&nbsp;mode,&nbsp;BANKSIZE&nbsp;128M/128M<br />DCD&nbsp;0x30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR6&nbsp;CL=3clk<br />DCD&nbsp;0x30&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR7<br />这段程序的开始使用DATA伪操作指明SMRDATA标号处为一段数据,而非代码。接下来就都用DCD分配一个字的内存单元,且初始化成由memcfg.s文件中定义的参数运算得出的各寄存器值,共13个字(52字节)数据。<br /><br />这一段始终不能搞得很明白,定义一段data就实现了功能吗,实现了什么功能呢&nbsp;?
biehoff 发表于 2008-12-6 10:41 | 显示全部楼层
** 有阿南版主手把手教 太羡慕了
楼主你初始化代码没看完吧?<br /><br />SMRDATA&nbsp;DATA<br /><br />;&nbsp;1)&nbsp;Even&nbsp;FP-DRAM,&nbsp;EDO&nbsp;setting&nbsp;has&nbsp;more&nbsp;late&nbsp;fetch&nbsp;point&nbsp;by&nbsp;half-clock<br />;&nbsp;2)&nbsp;The&nbsp;memory&nbsp;settings,here,&nbsp;are&nbsp;made&nbsp;the&nbsp;safe&nbsp;parameters&nbsp;even&nbsp;at&nbsp;66Mhz.<br />;&nbsp;3)&nbsp;FP-DRAM&nbsp;Parameters:tRCD=3&nbsp;for&nbsp;tRAC,&nbsp;tcas=2&nbsp;for&nbsp;pad&nbsp;delay,&nbsp;tcp=2&nbsp;for&nbsp;bus&nbsp;load.<br />;&nbsp;4)&nbsp;DRAM&nbsp;refresh&nbsp;rate&nbsp;is&nbsp;for&nbsp;40Mhz.&nbsp;<br /><br />;bank0&nbsp;&nbsp;&nbsp;&nbsp;16bit&nbsp;BOOT&nbsp;ROM<br />;bank1&nbsp;&nbsp;&nbsp;&nbsp;8bit&nbsp;NandFlash<br />;bank2&nbsp;&nbsp;&nbsp;&nbsp;16bit&nbsp;IDE<br />;bank3&nbsp;&nbsp;&nbsp;&nbsp;8bit&nbsp;UDB<br />;bank4&nbsp;&nbsp;&nbsp;&nbsp;rtl8019<br />;bank5&nbsp;&nbsp;&nbsp;&nbsp;8bit&nbsp;usb&nbsp;host<br />;bank6&nbsp;&nbsp;&nbsp;&nbsp;16bit&nbsp;SDRAM<br />;bank7&nbsp;&nbsp;&nbsp;&nbsp;16bit&nbsp;SDRAM<br />&nbsp;&nbsp;&nbsp;&nbsp;[&nbsp;BUSWIDTH=16<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;0x11010101&nbsp;&nbsp;&nbsp;&nbsp;;Bank0=16bit&nbsp;BootRom(AT29C010A*2)&nbsp;:0x0&nbsp;8bit&nbsp;usb&nbsp;host!][20:23]=0<br />&nbsp;&nbsp;&nbsp;&nbsp;|&nbsp;;BUSWIDTH=32<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;0x22222220&nbsp;&nbsp;&nbsp;&nbsp;;Bank0=OM[1:0],&nbsp;Bank1~Bank7=32bit<br />&nbsp;&nbsp;&nbsp;&nbsp;]<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B0_Tacs&lt&lt13)+(B0_Tcos&lt&lt11)+(B0_Tacc&lt&lt8)+(B0_Tcoh&lt&lt6)+(B0_Tah&lt&lt4)+(B0_Tacp&lt&lt2)+(B0_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS0<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B1_Tacs&lt&lt13)+(B1_Tcos&lt&lt11)+(B1_Tacc&lt&lt8)+(B1_Tcoh&lt&lt6)+(B1_Tah&lt&lt4)+(B1_Tacp&lt&lt2)+(B1_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B2_Tacs&lt&lt13)+(B2_Tcos&lt&lt11)+(B2_Tacc&lt&lt8)+(B2_Tcoh&lt&lt6)+(B2_Tah&lt&lt4)+(B2_Tacp&lt&lt2)+(B2_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS2<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B3_Tacs&lt&lt13)+(B3_Tcos&lt&lt11)+(B3_Tacc&lt&lt8)+(B3_Tcoh&lt&lt6)+(B3_Tah&lt&lt4)+(B3_Tacp&lt&lt2)+(B3_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS3<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B4_Tacs&lt&lt13)+(B4_Tcos&lt&lt11)+(B4_Tacc&lt&lt8)+(B4_Tcoh&lt&lt6)+(B4_Tah&lt&lt4)+(B4_Tacp&lt&lt2)+(B4_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS4<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B5_Tacs&lt&lt13)+(B5_Tcos&lt&lt11)+(B5_Tacc&lt&lt8)+(B5_Tcoh&lt&lt6)+(B5_Tah&lt&lt4)+(B5_Tacp&lt&lt2)+(B5_PMC))&nbsp;&nbsp;&nbsp;&nbsp;;GCS5<br />&nbsp;&nbsp;&nbsp;&nbsp;[&nbsp;BDRAMTYPE=&quot;DRAM&quot;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B6_MT&lt&lt15)+(B6_Trcd&lt&lt4)+(B6_Tcas&lt&lt3)+(B6_Tcp&lt&lt2)+(B6_CAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS6&nbsp;check&nbsp;the&nbsp;MT&nbsp;value&nbsp;in&nbsp;parameter.a<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B7_MT&lt&lt15)+(B7_Trcd&lt&lt4)+(B7_Tcas&lt&lt3)+(B7_Tcp&lt&lt2)+(B7_CAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS7<br />&nbsp;&nbsp;&nbsp;&nbsp;|&nbsp;;&quot;SDRAM&quot;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B6_MT&lt&lt15)+(B6_Trcd&lt&lt2)+(B6_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS6<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((B7_MT&lt&lt15)+(B7_Trcd&lt&lt2)+(B7_SCAN))&nbsp;&nbsp;&nbsp;&nbsp;;GCS7<br />&nbsp;&nbsp;&nbsp;&nbsp;]<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;((REFEN&lt&lt23)+(TREFMD&lt&lt22)+(Trp&lt&lt20)+(Trc&lt&lt18)+(Tchr&lt&lt16)+REFCNT)&nbsp;&nbsp;&nbsp;&nbsp;;REFRESH&nbsp;RFEN=1,&nbsp;TREFMD=0,&nbsp;trp=3clk,&nbsp;trc=5clk,&nbsp;tchr=3clk,count=1019<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;0x10&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;SCLK&nbsp;power&nbsp;down&nbsp;mode,&nbsp;BANKSIZE&nbsp;32M/32M<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;0x20&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR6&nbsp;CL=2clk<br />&nbsp;&nbsp;&nbsp;&nbsp;DCD&nbsp;0x20&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;MRSR7<br /><br />看着有点象吗?这是44b0x的初始化&nbsp;<br />自己在前面找找看&nbsp;有没有一句<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;;****************************************************<br />&nbsp;&nbsp;&nbsp;&nbsp;;*&nbsp;&nbsp;&nbsp;&nbsp;Set&nbsp;memory&nbsp;control&nbsp;registers&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;;****************************************************<br />&nbsp;&nbsp;&nbsp;&nbsp;ldr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;r0,=SMRDATA<br />&nbsp;&nbsp;&nbsp;&nbsp;ldmia&nbsp;&nbsp;&nbsp;r0,{r1-r13}<br />&nbsp;&nbsp;&nbsp;&nbsp;ldr&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;r0,=0x01c80000&nbsp;&nbsp;;BWSCON&nbsp;Address<br />&nbsp;&nbsp;&nbsp;&nbsp;stmia&nbsp;&nbsp;&nbsp;r0,{r1-r13}<br /><br />知道是干什么用的了吧·······
playlinus 发表于 2008-12-6 13:47 | 显示全部楼层
TKS biehoff
