关于一SPI的时序中 Hi-Z 位处理的讨论?
1885|0
 楼主| playlinus 发表于 2009-4-11 14:09 | 显示全部楼层 |阅读模式
The&nbsp;first&nbsp;6&nbsp;bits&nbsp;(A5&nbsp;~&nbsp;A0)&nbsp;specify&nbsp;the&nbsp;address&nbsp;of&nbsp;the&nbsp;register.&nbsp;And&nbsp;next&nbsp;bit<br />mean&nbsp;Read/Write&nbsp;command.&nbsp;“0”&nbsp;is&nbsp;write.&nbsp;“1”&nbsp;is&nbsp;read.&nbsp;And&nbsp;next&nbsp;cycle&nbsp;is&nbsp;turn-round<br />cycle.&nbsp;And&nbsp;the&nbsp;last&nbsp;8&nbsp;bits&nbsp;are&nbsp;for&nbsp;Data&nbsp;setting&nbsp;(D7&nbsp;~&nbsp;D0).&nbsp;The&nbsp;address&nbsp;and&nbsp;data&nbsp;are<br />transferred&nbsp;from&nbsp;the&nbsp;MSB&nbsp;to&nbsp;LSB&nbsp;sequentially.<br />The&nbsp;data&nbsp;is&nbsp;written&nbsp;to&nbsp;the&nbsp;register&nbsp;of&nbsp;assigned&nbsp;address&nbsp;when&nbsp;“End&nbsp;of&nbsp;transfer”<br />is&nbsp;detected&nbsp;after&nbsp;the&nbsp;16th&nbsp;SCL&nbsp;rising&nbsp;cycles.&nbsp;Data&nbsp;is&nbsp;not&nbsp;accepted&nbsp;if&nbsp;there&nbsp;are&nbsp;less<br />or&nbsp;more&nbsp;than&nbsp;16&nbsp;cycles&nbsp;for&nbsp;one&nbsp;transaction.<br /><br /><br /><br />我用普通的IO口模拟这个时序,第8位时该如何处理&nbsp;?<br /><br />
