WinCE中如何删除一个驱动(原创小经验)<br /><br />在使用wince的过程中往往需要去掉不需要的驱动,精简系统。而很多菜鸟拿着bsp却不知道如何下手。 经过试验<br />本鸟 step by step 的总结了在wince中如何删除不需要的驱动,以下以camera 驱动为例给出详细过程供菜鸟学习。<br /><br />第一步 如下所示,删除掉文件 srcdriversdirs 中的 “ camera ”项<br />文件: srcdriversdirs <br /><br />Use of this source code is subject to the terms of the Microsoft end-user<br />license agreement (EULA) under which you licensed this SOFTWARE PRODUCT.<br />If you did not accept the terms of the EULA, you are not authorized to use<br />this source code. For a copy of the EULA, please see the LICENSE.RTF on your<br />install media.<br />!endif<br />DIRS=ceddk <br /> keybd <br /> pwrbutton <br /> pccard <br /> serial <br /> usb <br /> nleddrvr <br /> Battdrvr <br /> Backlight <br /> Display <br /> camera 删除该行<br /> IIC <br /><br /><br />第二步 如下所示,注释掉文件 Filesplatform.bib 中的camera相关内容 <br /><br />文件: Filesplatform.bib<br /><br />;-------- Camera Driver -----------------------------------------------------------------------<br />;IF BSP_NOCAMERA !<br />; camera.dll $(_FLATRELEASEDIR)camera.dll NK SH<br />;ENDIF BSP_NOCAMERA !<br />;----------------------------------------------------------<br /><br />第三步 如下所示,注释掉文件Filesplatform.reg 中的camera相关内容<br /><br />文件:Filesplatform.reg<br />;------------- Camera Driver ------------------------------------------------------------------------------------<br />;IF BSP_NOCAMERA !<br />;[HKEY_LOCAL_MACHINEDriversBuiltInCamera]<br />; "Prefix"="CIS"<br />; "Dll"="camera.dll"<br />; "Index"=dword:1<br />; "Order"=dword:1<br />; "IClass"="{A32942B7-920C-486b-B0E6-92A702A99B35}"<br />;ENDIF BSP_NOCAMERA!<br /><br /> |
