[STM8] STM8S208C8芯片的GPIOC.4管脚是否比较特殊
3012|4
 楼主| zhzzh18 发表于 2015-6-8 11:43 | 显示全部楼层 |阅读模式
目前用STM8S208C8芯片,发现初始化GPIOC.4管脚为推挽输出,程序运行出错提示:error:gdi-error[40127]:flash memory not accessible while core is running.
把GPIOC.4管脚设置为上拉输出,程序运行部报错,但是输出不了高电平;
把GPIOC.4管脚设置为推挽输出,去掉外围电路,又正常了
代码:
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT_PP_HIGH_FAST;//GPIO_MODE_OUT_OD_LOW_FAST;//
    GPIO_InitStructure.GPIO_Pin = GPIO_PC4;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_Init_TypeDef* GPIO_InitStruct)
  /* Check the parameters */
        assert_param(IS_GPIO_MODE_OK(GPIO_InitStruct->GPIO_Mode));
        assert_param(IS_GPIO_PIN_OK(GPIO_InitStruct->GPIO_Pin));
  /* Input/Output mode selection */
        if ((((u8)(GPIO_InitStruct->GPIO_Mode)) & (u8)0x80) != (u8)0x00) /* Output mode */
                if ((((u8)(GPIO_InitStruct->GPIO_Mode)) & (u8)0x10) != (u8)0x00) /* High level */
                        GPIOx->ODR |= GPIO_InitStruct->GPIO_Pin;
                else /* Low level */
                        GPIOx->ODR &= (u8)(~(GPIO_InitStruct->GPIO_Pin));
    /* Set Output mode */
                GPIOx->DDR |= GPIO_InitStruct->GPIO_Pin;
        else /* Input mode */
        /* Set Input mode */
                GPIOx->DDR &= (u8)(~(GPIO_InitStruct->GPIO_Pin));
  /* Pull-Up/Float (Input) or Push-Pull/Open-Drain (Output) modes selection */
        if ((((u8)(GPIO_InitStruct->GPIO_Mode)) & (u8)0x40) != (u8)0x00) /* Pull-Up or Push-Pull */
                GPIOx->CR1 |= GPIO_InitStruct->GPIO_Pin;
        else /* Float or Open-Drain */
                GPIOx->CR1 &= (u8)(~(GPIO_InitStruct->GPIO_Pin));
  /* Interrupt (Input) or Slope (Output) modes selection */
        if ((((u8)(GPIO_InitStruct->GPIO_Mode)) & (u8)0x20) != (u8)0x00) /* Interrupt or Slow slope */
                GPIOx->CR2 |= GPIO_InitStruct->GPIO_Pin;
        else /* No external interrupt or No slope control */
                GPIOx->CR2 &= (u8)(~(GPIO_InitStruct->GPIO_Pin));
出错代码:GPIOx->CR1 |= GPIO_InitStruct->GPIO_Pin;
电路:
 楼主| zhzzh18 发表于 2015-6-8 11:44 | 显示全部楼层
附上GPIOC.4的外围电路
 楼主| zhzzh18 发表于 2015-6-8 11:47 | 显示全部楼层
再说一个,就是这个代码在STM8S208R8上没问题,原先是用R8芯片的,程序运行没问题,现在要用C8芯片替换,代码是不变的。
mmuuss586 发表于 2015-6-8 12:26 | 显示全部楼层
这个感觉是硬件问题,多焊几块板子看看;
 楼主| zhzzh18 发表于 2015-6-8 13:50 | 显示全部楼层
to:mmuuss586
已经焊了两块,两块都一样的。
