[技术问题解答] 编译image报错,求大神指点迷津
1511|0
 楼主| kaikaisi 发表于 2015-6-9 10:12 | 显示全部楼层 |阅读模式
| /bin/bash: line 1:  4336 Aborted                 (core dumped) /home/kaikai/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gcc-cross-initial/4.8.2-r0/gcc-4.8.2/build.i686-linux.arm-poky-linux-gnueabi/./gcc/xgcc -B/home/kaikai/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gcc-cross-initial/4.8.2-r0/gcc-4.8.2/build.i686-linux.arm-poky-linux-gnueabi/./gcc/ -dumpspecs > tmp-specs
| make[1]: *** [specs] Error 134
| make[1]: *** Waiting for unfinished jobs....
| ranlib  libbackend.a
| make[1]: Leaving directory `/home/kaikai/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gcc-cross-initial/4.8.2-r0/gcc-4.8.2/build.i686-linux.arm-poky-linux-gnueabi/gcc'
| make: *** [all-gcc] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/kaikai/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gcc-cross-initial/4.8.2-r0/temp/log.do_compile.3895)
ERROR: Task 631 (/home/kaikai/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_4.8.bb, do_compile) failed with exit code '1'
Currently 1 running tasks (160 of 6234):
0: linux-libc-headers-3.10-r0 do_fetch (pid 3894)
