[Atmel] Getting started with Embedded Linux: Part one
963|0
 楼主| ddllxxrr 发表于 2015-6-16 20:11 | 显示全部楼层 |阅读模式
Learning Linux for embedded systems
I was recently asked how a person with experience in embedded systems programming with 8-bit processors, such as PIC, as well as 32-bit processors, such as PowerPC, but no Linux experience, can learn how to use Embedded Linux.
What I always recommend to such an embedded systems programmer is this: Look at Embedded Linux as two parts, the embedded part and the Linux part. Let's consider the Linux part first.
The Linux side
Operating systems abound and the choices are many for an embedded system, both proprietary and open source. Linux is one of these choices. No matter what you use for y**elopment host, whether Linux or Windows or Mac, you need to learn how to program using the target OS. In this respect, using Embedded Linux is not greatly different from using VXworks, WindowCE, or another OS. You need an understanding of how the OS is designed, how to configure the OS, and how to program using its application programming interface (API).
A few factors make learning how to program Linux easier than other embedded OSes. You'll find many books and tutorials about Linux, as well as Unix from which it is derived -- many more than for other OSes. Online resources for Linux are ample, while other OSes have a much smaller presence, or one driven by the OS manufacturer. Linux is open source, and you can read the code to get an understanding of exactly what the OS is doing, something that is often impossible with a proprietary OS distributed as binaries. (I certainly do not recommend reading Linux source to try to learn how to program Linux. That's like trying to learn to drive by studying how a car's transmission works.)
The most significant factor that sets Linux apart from other OSes is that the same kernel is used for all systems, from the smallest embedded boards, to desktop systems, to large server farms. This means that you can learn a large amount of Linux programming on your desktop in an environment, which is much more flexible than using a target board with all of the complexities of connecting to the target, downloading a test programming, and running the test. All of the basic concepts and most APIs are the same for your desktop Linux and your Embedded Linux.
Installing Linux
You could install a desktop Linux distribution on y**elopment system, replacing your Windows or Mac system, but that may be a pretty large piece to bite off at one time, since you would likely need to configure email, learn new tools, and come up to speed with a different desktop interface. You could install Linux in a dual-boot environment, where you use the old environment for email, etc., and use the Linux system for learning. This can be pretty awkward, since you need to shut down one environment to bring up the other. Additionally, doing either within a corporate environment may be impractical or impossible. IT folks prefer supporting a known environment, not one that you have chosen.
An easier way is to create a virtual machine environment on your current development system. For Windows hosts, you can install VMware Player or VirtualBox, and on the Mac, you can install Parallels or VMware Fusion. Using a VM offers you much more flexibility. You can install a desktop Linux distribution, like Ubuntu or Fedora. You can use this distribution to become familiar with basic Linux concepts, learn the command shell and learn how to build and run programs. You can reconfigure the kernel or load drivers, without the concern that you'll crash your desktop system. You can build the entire kernel and application environment, similar to what you might do with a cross-development environment for an Embedded Linux target.
If your VM running Linux crashes, you simply restart the VM. The crash doesn't affect other things which you might be doing on y**elopment system, such as reading a web page on how to build and install a driver, or that writing an email to one of the many support mailing lists.
Some of the VM products have snapshot features that allow you to take a checkpoint of a known working configuration, to which you can roll back if you can't correct a crash easily. This snapshot is far easier than trying to rescue a crashing desktop system or an unresponsive target board.
A Linux VM running on your desktop is not a perfect model for an Embedded Linux environment. The VM emulates the hardware of a desktop system, with a limited set of devices that are unlikely to match a real embedded target. But our objective at this point is not modeling a real target (something we'll discuss later) but creating an environment were you can learn Linux concepts and programming easily.
This is the first step: Create a VM and install a desktop Linux distribution on the VM. We'll pick from here in our next installment.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
